Question about Umax ActionBook 340T
I need driver for my pca - Umax ActionBook 340T
  • Alex Smallwood
    Alex Smallwood May 11, 2010
    More Info needed mate if you want some help
    computer make , model , manufacturer
    operating system
    hardware that you want the driver for
Hey dont worry i will give you a link try it and see if you can find it their.ok
http://laptop-notebooks-drivers.com
try it nw.
Posted on Jan 19, 2009
Upper PCA problem
Please RUN the software calibration for eady diagnostic and fix it. God bless you
However follow this steps and fix it. God bless you
Probable Cause 1. A failure in the upper PCA overloads the low voltage power supply and causes it to drop below the preset level.
2. A fault in the interconnect cable (upper PCA to lower PCA) causing the input voltage to the upper PCA to be too low. Corrective Action
  1. If the error message is continually displayed when the unit is powered up, the upper PCA needs replaced.
    External causes may make the error appear intermittently.
    1. If the AC input of the unit dips significantly during power up test sequences, the test could fail causing the error to appear.
    2. A treadmill connected to a non-dedicated AC circuit can experience this error intermittently.
  2. Determine if the interconnect cable is the cause by substituting a know good cable in place of the current cable. For test purposes, the substitute cable needs to be connected directly between the upper and lower PCA's, without routing the cable internally.
Nov 22, 2013 | Precor 9.27 Treadmill
Precor error 12
Precor Error 12, Watchdog (Lower PCA) Probable Cause 1. A failure in the lower PCA overloads the low voltage power supply and causes it to drop below the preset level.
2. A fault in the interconnect cable (upper PCA to lower PCA) causing the low voltage power supply of the lower PCA to be too low.
3. A failure in the upper PCA that overloads the lower PCA low voltage power supply causing it to be too low.
Corrective Action
  3. Determine if the upper PCA is the cause by substituting a know good upper PCA for the existing upper PCA.
Precor Error Code 12 12 Watchdog Lower PCA
May 04, 2013 | Precor EFX 546i Elliptical Version 4
I have a PROMASTER PROSELECT treadmill it stop, and error came up #30
Description
Errors 30 through 33 all indicate the loss of communications or erratic communications between
the microprocessors in the upper PCA and the lower PCA. The trouble shooting procedures for
all of the are essentially the same. Error 30 is defined as upper PCA not receiving from lower
PCA. Error 31 is defined as faulty data received from lower PCA. Error 32 is defined as lower
PCA not receiving from upper PCA. Error 33 is defined as faulty data received from upper PCA
Possible Causes
1. An upper PCA to lower PCA interconnect cable is bad.
2. The interconnect cable at the upper PCA was mistakenly plugged into the CSAFE connector.
3. A 5.17 EFX equipped with version 1.01 upper and lower software.
4. A 5.17 with mismatched upper and lower software.
5. A defective lower PCA.
6. A defective upper PCA.
Possible Remedies
1. Substitute a know good interconnect cable between the upper and lower PCAs to determine
if the interconnect cable is defective.
2. Remove the interconnect cable from the CSAFE connector and insert it in the correct upper
PCA connector.
3. Replace the 5.17 upper and lower software with the most current software versions.
4. If only one of the upper or lower software is version 1.01, replace the version 1.01 software
with the most current version of software.
5. Substitute a known good lower PCA to determine if the lower PCA is defective.
6. Substitute a known good upper PCA determine if the upper PCAs defective.
PCA =printed circuit assembly. test it and fix it.
God bless you
Feb 22, 2013 | Exercise & Fitness
Advantech PCA-6186VE-00B2E vga driver for windows 98
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
if you dont have the drivers you will ned to download them
http://download.cnet.com/1t2xw26-exe/3000-2122_4-120557.html
http://download.cnet.com/acjxw01-exe/3000-2108_4-120624.html
hope it helps
Apr 03, 2012 | Advantech PCA-6186VE-00B2E: PICMG Single...
I want a driver for com1 and com2 ports in the PCA-6003v motherBoard !! could u please help us ?
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
you might have to expand your devices to see your com1 and com2 ports
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
hope this helps
Aug 10, 2011 | Advantech PCA-6003V-00A1 Motherboard
Error 12 appears on display? What do I do?
Corrective Action
Jul 12, 2011 | Precor EFX 546i Elliptical Version 4
57.70 error will not print
This error points to the Fuser Fan see below for more details
Error 57.XX points to a fan problem in general
57.X
The printer detects that a fan motor
has failed.
X description
1 = cartridge fan (FM 3)
3 = low-voltage power supply fan (FM5)
5 = face-up delivery paper path fans (FM1 or FM6)
6 = paper-path fan (FM2)
7 = fuser fan (FM4)
9 = ozone/exhaust fan (FM7)
1 - Turn the printer off, and then turn the printer on again to clear the error.
2 - Check the indicated fan, and check for correct movement of the blades and motor.
3 - Check the connectors that apply to theX error:
1: J3078 and J820 on theT driver PCA.
3: J3 on the low-voltage power supply, and J102 on the DC controller PCA.
5: J3079 and J3087 at the fans, intermediate connector J086, and J811 on the T driver PCA.
6: J818 on the T driver PCA.
7: J819 on the T driver PCA.
9: J3089 at the fan, and J823 on the T driver PCA.
4 - Check connector J1 on the low-voltage power supply, J210 and J202 on the high-voltage power supply, J608 and J612 on the P driver PCA, and J806 on the T driver PCA.
5 - Replace the fan if voltage is supplied to it at power on and it fails. See chapter 6.
6 - Replace the T driver PCA. See" T-crg (print cartridge) drive assembly" on page 296.
7 - Replace the DC controller PCA if X = 3 (FM5). See "DC controller" on page 300.
To view the online service manual click here
Oct 19, 2010 | HP LaserJet 9500n Printer
Marca error 60,02
60.2
The tray 2 lifter-motor is not functioning.
1 Turn the printer off and then on.
2 If the error persists, turn the printer off.
3 Verify that the tray 2 lifter wire-harness
is full seated in its connector on the
dc controller PCA (location J93).
4 Replace the tray 2 lifter-driver
assembly. See Tray 2 lifter-drive
assembly.
5 Replace the dc controller PCA. See
Dc controller PCA.
Aug 09, 2010 | HP LaserJet 4250dtn Printer
HP 3600 error59.63
Yellow Print cartridge Drive motor or the Driver PCA.
Driver PCA = RM1-2581-000CN
Nov 12, 2009 | HP LaserJet 3600n Printer
Bad Hard drive
if your HD don't had a head crash you will have a chance to copy your data to a new HD.
You need exactly the same disk with exactly the same controll PCA revision. Take a look at ebay or a second hand dealer.
In case you get one, built the new contoll PCA into your dead HD.
Be very carfull about foil cables and connectors between the HD case and the PCA.
I had a similar problem with a blown motor driver chip in a Maxtor drive and changed the PCA. All worked fine and I could save the data.
Good luck !
There are also companies who are specialized for data recovery but the are very expensive.
Jul 13, 2008 | Computers & Internet
Umax ActionBook 340T Logo
54 people viewed this question
Top Umax Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
tdk1988
Are you an Umax Computer and Internet Expert? Answer questions, earn points and help others
