Question about Video Game Consoles & Games
The sensor bar or the remotes r broken how can I fix this?
  • 22 Answers
Go through to menu and set your screen size to either auto resize or do it manually
Posted on Jan 03, 2013
Remote wont connect to sensor bar
Try taking a picture of it with a cell phone or a digital camera. If there are no lights that show on the screen then it may be the battery's are dead. If you had put in new battery's then the sensor bar is broken. The wii sensor bar is just a row of infrared L E D's and dose not sync to the controller. The controller has a camera in it and will see the lights and determine where to put the courser on the screen. You cant see the lights because its not within the light spectrum humans can see.
Jan 20, 2014 | Eforcity Wireless Ray Sensor Bar For...
My control for the wii will bring up the menu but the courser that you use to make selections does not appear.
Make sure the sensor bar is correctly plugged into the Wii, and that the Wii Remote has a clear path to the sensor bar. Move the Wii Remote around, as the positioning of the sensor bar may not be precise. If you are sure everything is how it should be, it may be that your sensor bar is damaged and/or broken. You may have to buy a new one.
Aug 20, 2011 | Nintendo Wii Console
Cant get past language screen
Here are instructions from Nintendo on how to fix this issue. It's most likely related to the sensor bar. Good Luck!
If your screen appears frozen at the Language select screen, we have found that to be related to the Sensor Bar. Please try the following:
Ensure that the Sensor Bar cord is plugged snugly to the back of the console, and is placed properly at the center of your TV screen. For detailed directions on setting up the Sensor Bar, please click here.
Check to be sure the Wii Remote is synced to the console, by using the Power button on the Wii Remote to turn the console on. (The power button is the small white button with the red symbol in the top-left corner, just above the Control Pad). If this doesn't work, try to sync the Wii Remote. Once synced, try to turn the power on the console on and check for proper response.
Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup). Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
If you are still experiencing problems after trying the steps above, there could be a problem with your Sensor Bar. Please read the following:
The Sensor Bar has five infrared lights on each side of the bar that the Wii Remote uses to determine its position. If these lights aren't working, then the Wii Remote cursor will not display on the screen, and you won't be able to navigate the setup screens.
To see these lights, you will need a digital camera or cell phone camera with an LCD display . After making sure the Sensor Bar is plugged in and the power to the console turned on, direct the camera at the Sensor Bar so that it is displayed in the LCD of the camera. If the five infrared lights can be seen on both sides of the Sensor Bar, the Sensor Bar is working. While the position/angle of the camera may need to be adjusted slightly, the lights are fairly easy to see in the LCD display.
Nov 20, 2009 | Nintendo Wii Console
Wii Remote Turning Funtion Doesn't Work on Mario Kart
Your wii sensor bar probably went out, replace it. They sell wireless ones at wal-mart for $20. If you want to make absolute sure that the bar is broken, take a video camera and take a quick video of the wii bar while it's connected and the wii is on. If you see four little blue lights on each side then you're wii bar is ok, if any are gone it should be replaced. The fact that all the buttons are still working means that your wii is still communicating with remote using bluetooth, but since it's not sensing any motion, it probably means that the problem is sensor bar related.
Aug 25, 2009 | Nintendo Wii Console
Remote dont work. lights just flash. tried to sync did not work. Bought a new remote and went to sync it now it is doing the same thing the other remote did> Any suggesions?
Basic Question: Did you set up the sensor bar?
I'm assuming you follow the instructions to plug in the Wii and to attach the sensor bar to the console and position the sensor bar so it is either below or above the television.
The Wii remote flashes (more specifically the bottom row of four lights that indicate which player each remote belong to flashes) when a button is pushed on the control while the Wii is off.
If the Wii is on and simply sleeping (as evident by a blinking yellow light on the power button on the console) pushing the power button the control should turn on both the console and the remote. Be sure to aim the remote at the console when "waking" the Wii up and at the sensor bar once the Wii Menu loads. The remotes automatically turn off with lack of interaction.
To recap: Your remotes sound to be working fine. I would assume it might be a problem with the interaction between your console and the remotes or the setup of the console. The Wii Information Guide has pictures and pretty clear connection instructions that should help fix your problem.
If everything is set up correctly as per the instructions and your system still does not interact your sensor bar may be faulty or your console as I believe you're remotes work fine.
Jun 26, 2009 | Nintendo Video Game Consoles & Games
No connection from remote to screen
Your sensor bar is definitely burned out, you can get a new wireless one at wal-mart for $20. Often wii sensor bars burn out because people put it directly on the tv instead of using the stand, the tv gets hot and the LED lights in the sensor bar burn out. If you want make sure that it's the sensor bar that's broken, get a video camera and video tape the sensor bar while it's plugged in and the wii is on, if you can't see four LED lights on each side then it's broken.
Jun 14, 2009 | Nintendo Wii Console
Wii remote not working.
Get some regular alkaline AA batteries and try your Wii Remote using them -- the blue lights on the Wii remote should light up and register with the Wii console (this is via wireless / bluetooth) -- As for the sensor bar, it is really only an infra red emitter - so if you have it properly connected to your Wii, the Wii Remote (with working batteries) can sense where it is by "seeing" the lights emitted from your sensor bar.
If the alkaline batteries work - You may need to get some new NiMH AA batteries to use in your charger - changers are usually third party devices; Nintendo does not ship charging stations with the Wii.
If the Wii remote appears to be working (blue lights and all) and your sensor bar is properly connected, you may have a dirty or damaged IR port. First clean the top of the Wii remote, just to make sure. If it still does not work, borrow a friends Wii Remote and check to see if it works with your system. If you do everything above and your Wii remote does not work while a seperate one does, the problem is most likely a broken Wii remote.
Jan 01, 2009 | Nintendo Wii Console
Wii Handset Motion Sensor Not Working
It could be one of a few things.
1. Your sensor bar is no good, can you get the pointer icon on the wii's main menu to work properly?
To fix this you'll need to contact Nintendo and get a new sensor bar or buy one of the third party ones, Nintendo should help you out though.
2. The accelerometer in the wii is stuck, which does happen from time to time.
To fix this turn the Wii remote so the buttons face towards the floor and slap the back of the remote firmly(not too hard!) with the palm of your hand. It should work if that is the problem.
3. The accelerometer is broken or otherwise rendered useless.
To fix this you'll have to contact Nintendo.
To get a hold of Nintendo 1-800-255-3700 they're very friendly and it never takes very long(I got helped in 5 minutes the day after Wii was released.) Best of all, Nintendo doesn't outsource!
Dec 31, 2008 | Nintendo Wii Console
Broken wii remote
Try windex on the sensor bar on top of your TV. Also check that the sensor bar is properly connected, it's not reading that particular remote.
Nov 28, 2008 | Nintendo Wii Console
Sensor bar / remote issues with Golf games
Has the sensor bar perhaps been moved? Is it becoming obstructed by furniture or something else?
Sep 09, 2007 | Nintendo Wii Console
Video Game Consoles & Games Logo
20 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
