Question about Twinhead Computers & Internet
My Twinhead Slimnote 9100 was working fine with Windows 95. Now it says there is no operating system and it says there is no hard drive. I can get to the Bios, but that is it. What could have happened
It is a Slimnote 9100CV
  • Twinhead Master
  • 7,627 Answers
Bad HDD, remove and test. Replace if necessary.
Posted on Jan 03, 2013
  • Kitty Sutton
    Kitty Sutton Jan 04, 2013
    I am fairly handy with tools, but I can't seem to find a way into the inside. Do you know of anyplace online that has instructions for just getting the case open?
  • max carson
    max carson Jan 05, 2013
    I can't find any support for your machine. Usually if you Look at the bottom of the laptop you will dee "bay" doors. There will be small icons for the components inside HDD, Memory. It mat be a dead HDD, if your laptop is getting old, you may want to change the CMOS battery, check Memory, check the HDD.
SOURCE: Hello, I have an older
I would suggest the same better go for a new one.
Antolo
www.pecsol.com
Posted on Nov 29, 2008
  • 68 Answers
SOURCE: need to install operating system on laptop with no cd rom or driv
I believe this model of laptop was designed for Windows 95, which can be installed using only floppy disks. That would be just about your only solution. I would not recommend trying to install XP or anything on it, due to the outdated hardware. If it has a PCMCIA Slot on it (most do) you can buy a USB adapter that goes in there. But, as I stated before, I would just install Windows 95 on it (or possibly 98SE) Good Luck!
Posted on Dec 08, 2008
rajak2009
  • 527 Answers
SOURCE: new hard drive operating system loaded, now cant find hard drive
check the cables it properly connected or not. after start up press F8 key to check the installed hard drive is detected or not. if it is not, check with BIOS settings
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on May 09, 2009
  • 64 Answers
SOURCE: My Twinhead Slimnote SX25 won't start windows up.
It probably got a virus. Does it say NTLR or something like that with a blinking cursor? If it does, you need to get your Recover CD or DVD if it came with it, or find someone who has one. You can also try to go get a copy in eBay, but better find a friend who can help you with it. I also advice people to burn important info like pictures and music library, etc on a DVD or CDR so even if your system crashes, you can reinstall a new system as long as the problem is not a broken hard drive.
Posted on Sep 09, 2009
leusnerdus
  • 54 Answers
SOURCE: old twinhead slimnote 5100c do not start
Try removing its HDD and another removable disk. Finally the RAM module. If does not, take it for repairs.
Posted on Apr 28, 2010
Laptop comes on great and seems to make all the right noise but the screen looks like the old vhf/uhf tv screens from the 60's....wont show a thing encept "fuzzy static"...it's a slimnote...
Hmmm, well either your Video Driver needs to be re-installed or you need to change the windows resolution settings.
XP: Right click the desktop and left click properties. Clickthe Settings tab and you will see a slider bar in the middle left. Move the barto the right or left one at a time and eventually you will hit the correctsettings for the monitor.
Vista/Win7: Right click the desktop and left click on Screen Resolution. Whereit says Resolution, you can change the settings to the Recommended settings foryour specific monitor.
Cheers!
Oct 28, 2010 | Twinhead Slimnote N12PI (N12PICC01) PC...
Old twinhead slimnote 5100c do not start
Apr 28, 2010 | Twinhead SlimNote N12PI Notebook PC
When i on the notebook, that appear error system
you need to reinstall your operating system again...no other go...try installing with the help of the operating system CD provided along with the computer...
Mar 29, 2010 | Twinhead SlimNote N12PI Notebook PC
Will not boot (twinhead)
Have you tried booting in safe mode pressing F8 when starting up just after you power up, then a menu appears & you can try sytem restore from there or safe mode if you know what to get rid of on the system.
If not boot with a copy of windows in the drive & start again from fresh!
Hope this help's !
Sep 23, 2009 | Twinhead SlimNote N12PI Notebook PC
My Twinhead Slimnote SX25 won't start windows up. What do I do? What windows version is on it?
Sep 09, 2009 | Computers & Internet
Twinhead A5010 shows blank screen, no sounds after power-on
maybe some files is missing due to not booting the system...
or corrupting files did you try this bellow
step 1.. try to refomat your computer using the os/operating system
step 2. if you don't know how to format find the tec man who know it.
step 3. try to chick the (IDE) CABLE OR SATA CABLE if properly
can you that from the hard disk to motherboard connncetor
try to unplug & plug again
thank you... felix from ph
Jul 04, 2009 | Twinhead SlimNote N12PI Notebook PC
Need to install operating system on laptop with no cd rom or driv
Dec 08, 2008 | Twinhead SlimNote N12PI Notebook PC
Will not boot ??
sounds like a problem i had with a philips laptop (which appears to be a twinhead repackaged as a philips)
This might sound weird but it works........
Take the battery out and disconnect from the ac
Press and hold the power button for about 40secs
connect the ac but don't replace the battery and press the power button
then replace the battery and turn it on. it should work
Apr 09, 2008 | Twinhead SlimNote N12PI Notebook PC
Computers & Internet Logo
49 people viewed this question
Top Twinhead Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alun Cox
Carl Rick
Are you a Twinhead Computer and Internet Expert? Answer questions, earn points and help others
