Question about Stoves 720EF Electric Double Oven
Stoves genus 900 will not switch on
I bought a stoves genus 900 in June 2008 on 22 Dec 2008 it refused to respond to any of the touch buttons. I have since found out the cooker was manafactured in mar 2006 even though I bought it on 23 June 2008. A month later the cooker is still not working. Stoves thought I bought a demo but I didnt it appears it had been in the wholesalers for over 2 yrs. Do not buy this cooker as I have one warranty and a month later it is stil not working
I have a power supply for one and also a front panel dont know if this helps.
Posted on Nov 10, 2010
Bought a prima superchef oven, when I plug it in the electricity trip switch cuts off the power.
or a wire is touching the casing. If it is new, call the retailer. If it is secondhand call an appliance technician.
If it is a UK or Australian cooker, and the wires a fixed into terminals behind a cover on the wall, you have it wired wrong.
Big volts and amps can kill.
http://www.askmediy.com/wiring-diagram-for-a-stove-plug/
wiring diagram for stove plug AskmeDIY
Aug 21, 2016 | Ovens
Jenn-air oven not responding
Get out the owners manual and there are some symptoms solutions
If you can't find the answer there there is a customer service support line telephone number. You can give them the model number of the stove and he'll give you a method to find out what's wrong it may just be a fuse
Nov 26, 2014 | Jenn-Air Ovens
F2 shows on display on whirlpool gas stove
Keyboard Failure
Error Code: F 2
Component:
To localize the fault - disconnect the switches from the display unit. If the fault is gone - replace the switches.
Touch buttons - replace control panel assy
Tactile switches - replace control panel assy
Dado
May 14, 2014 | Whirlpool RBS305PDS Electric Single Oven
I have a Caloric Heritage Series gas stove in which the oven will not light but the broiler does work. This stove has a analog clock and we have no idea what the model is. Please help us. Thank you,...
We replaced the igniter which I bought from the appliance repair service. We now have a working oven.
Thankyou for responding to my email.
Cheryli
Dec 29, 2009 | Ovens
Hi I have just got my new Genus m/f oven the multi funcition I am fine with but I find I have no instructions or recipes for the Genus.Can anyone tell me where I can get some. or download some I am in...
As a US consumer, I am not very familiar with Genus ovens, but I think they are manufactured by Glen Dimplex. Their website is www.gdha.com or try their phone at 0871 222 2502. They may be able to supply you with additional info for your oven. Hope this helps.
Apr 19, 2009 | Stoves Ovens
Oven comes on of it's own accord following power failure
no you are not over reacting that could have burnt your house down I would demand a new one sometimes you just got to be pure hateful with these manufacturers and tell them you going to give bad ratings all over the net hope you get somewhere with them Please give high rating
Jan 05, 2009 | Ovens
Stoves oven genus 900 error codes
Hi phill6x6...try turning on the oven by the main button, and press and hold button 7 until it beeps. Hope this helps you, and a few others!!
Nov 18, 2008 | Stoves 720EF Electric Double Oven
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Stoves 720EF Electric Double Oven Logo
398 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
