SOURCE: Saeco Primea Cappuccino Touch Plus Coffee Maker fill water tank
The Primea do not have a float, it have a magnet and inside the machine there are a printed circuit card, this send a signal to the powerboard.
SOURCE: Saeco Roayal Sup 016
Hi
I am assuming your machine grinds, then clicks twice, then the brew drive starts but you never hear the pump.
If this is so? The there is a lever at the top center of the door on the right. Pull the lever back 1 click, and try again.
SOURCE: I have a Saeco Primea Cappuccino Touch Plus. how
Yes, you can adjust the sizes and aroma according to your taste,just hold the the product without releasing your finger,the screen will show programming.Then follow the instructions on the screen. Easy.
SOURCE: milk is not dispensing hot enough from saeco
If you use cold milk, I don't think it has enough heating power to make it hot enough. What I find works best is using long life milk from a carton which is room temperature, or making the milk room temperature warm in the microwave first before pouring into the milk containter
