Question about Briggs & Stratton Garden
I have a Rover Quattro 40 and I need to replace the three bolts surrounding the centre bolt which attach the blade plate. Because they have sheered of I don't no what size they are. Does any one k
    Sergeant:
  • 322 Answers
If I am understanding you correctly you are talking about the spindle and the hold down bolts for it. Most spindles use a 5/16 course thread 1 1/2 inches long with a 1/2 inch head size
Posted on Jan 17, 2013
  • 86 Answers
SOURCE: change rotory blade on craftsman 917377794
This is a nice mower, it has a Honda engine. The blade bolts onto a "blade brake clutch" which is why you see 3 bolts. Removing the two outer bolts should release the blade. Normally these bolts are about 1/4" to 5/16" diameter at the threads, and have split washers to prevent them from accidentally coming loose from vibration or impact.
Here's the steps I use when replacing the blade:
  1. Pull the spark plug wire off the spark plug.
  2. Lay the mower over on it's side (gas filler cap should be up, so whichever side allows the gass filler cap to end up on the high side of the engine).
  3. Find a wrench that properly fits the blade bolts.
  4. If right-handed; wearing a garden or protective work glove on the left hand, grasp the blade.
  5. Unbolt both bolts by turning in a counter-clockwise direction (left circular direction).
  6. Remove the bolts being sure not to lose the locking washers.
  7. Pull the blade off the blade mount (sometimes a light tap is necessary to loosen the blade from the blade mount).
  8. Replace the blade with the exact Sears part number (diagram and parts list attached below).
  9. Thread the bolts back on using your fingers to get them started - don't force them if they start to bind or you'll cross-thread them; bad thing).
  10. Snug the bolts down tight, sufficient to compress the locking washers flat.
  11. Don't overtighten, they need to be tight, but if you use a long handle wrench or ratchet drive you can cause them to break or fail while the balde is spinning, another bad thing. Tighten them snug assuring the washers compressed flat.
  12. Turn the mower back upright onto its wheels.
  13. Replace the spark plug wire back onto the spark plug.
  14. Leave sit for 30 minutes before starting to assure the oil has returned level in the engine before you attempt to start the engine.
Here's your diagram and parts list:
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=917377794&productCategoryId=1500600&brandId=0247&modelName=Gas,-Walk-Behind-Lawnmower&diagramPageId=00001&componentDescription=ENGINE/HOUSING/HANDLE/BAG/BLADE&documentId=P0401287&backToLink=Return%20to%20Sub%20Components%20list
Thanks for using FixYa, please take a minute to rate my answer?
Gregg
Posted on Apr 04, 2009
  • 68 Answers
SOURCE: Hello, I have a Craftsman Model 917.377790
Sounds like you lost the drive key out of the crankshaft, it's usually half-moon shaped and keeps the blade hub and the crankshaft turning together, the bolt just holds it all on the end of the crankshaft.
Hope this helps!
Posted on Jul 04, 2009
  • 1114 Answers
SOURCE: Cant remove blade on lawn mower
Follow directions. See if this works;
Blade Maintenance
�� Warning! Switch off, remove the isolator
key, battery and grassbox before adjusting
or cleaning.
�� Always wear gardening gloves when handling
or working near the sharp blades.
Turn the machine on its right side and inspect
the blade; if blunt or damaged, replace.
Use the following procedure to remove and replace
the blade:
Insert a screwdriver into hole 26 to lock the
drive. Hold the blade 30 using gardening gloves
(not provided) and use a spanner (not provided)
to remove the blade bolt 29, blade washer 28
and blade 30.
Fit the blade 30, blade washer 28 and the blade
bolt 29. Ensure that the blade is the correct way
up (so that this symbol can be seen located
as in figure I) and tighten the bolt 29 firmly.
Ensure the screwdriver is removed before attempting
to turn the machine on.
If this procedure does not work then try the following;
It is not uncommon for the blade bolt to become seized onto the shaft due to all the gunk and moisture on the underside of the deck. Try to soak the bolt several times over with penetrating oil ( WD 40, PB Blaster, etc). Spray the bolt head, the top of the blade where it contacts the shaft, etc. Do this several times and let the penetrating oil soak in. Hit the bolt head gently several times with a hammer to loosen up the corrosion. Then try to remove the bolt per directions.
Hope this helps, if so Please rate, Thanks, and Good Luck!
Posted on Aug 02, 2009
wireguy212
  • 1627 Answers
SOURCE: Auger blades won't turn
You need what they call a "friction wheel" replaced.
Posted on Oct 31, 2009
kel1guy2002
  • 3740 Answers
SOURCE: need manual to see what size bolt is that holds on
Hi and welcome to FixYa. I am Kelly,
It appears your model number is 74370 There are 3 bolts one for each blade and the part number is 26-0671 or 260671 for the blade mount.
Part look up:
http://www.jackssmallengines.com
then enter part number 260671 $6.31 ea.
You can not use just any bolt for this. They are hardened bolts with an NF thread. If you use a non hardened bolt the blade will fly off when the bolt shears.
This bolt is available at most all Lawn Mower Parts Supply sources. Toro uses the same bolt on most all of their mowers.
If you do not have a Lawnmower Parts Supply near by, you might be able to go to an Autoparts supply source with yet one of the other blade bolts in hand and have them match the markings on the bolt head with yours so that you have the exact replacement bolt.
Any other parts for your mower can be found here:
http://www.jackssmallengines.com/help.cfm
Use the Search model window. each line below is a drop down window
Toro
Riding
74370 <- there are numerous models up to 74704
enter your model number if different.
Thanks for using FixYa.
Kelly
Posted on Apr 27, 2010
How to remove four blade base plate from masport 450 series
use hole where bolt for blade goes insert a large screwdriver or steel rod and get it to catch on the casting or at the grass throw end with base locked you can now undo lock nut. should be lefty loosy.
Feb 26, 2017 | Cars & Trucks
On a 3.8L what is the aspec diagram and tourque for the racker arm
Hi Juan, I'm AL the owner of Big As Auto Repair
Below is the torque specs for the rocker arm as you requested.
SPECIFICATIONS - TORQUE
DESCRIPTION N·m Ft. Lbs. In. Lbs. Camshaft Sprocket-Bolt 54 40 - Camshaft Thrust Plate-Bolts 12 - 105 Forged Connecting Rod Cap-Nuts 54 +¼ turn 40 +¼ turn - Cracked Connecting Rod Cap-Bolts (Refer to 9 - ENGINE/ENGINE BLOCK/PISTON & CONNECTING ROD - INSTALLATION) Crankshaft Main Bearing Cap-Bolts 41 +¼ turn 30 +¼ turn - Crankshaft Main Bearing Cap Cross Bolts (3.8L) 61 45 - Crankshaft Oil Seal Retainer Rear-Bolts 12 - 105 Crankshaft Damper-Bolt 54 40 - Cylinder Block Drain Plugs 20 15 - Cylinder Head-Bolts (Refer to 9 - ENGINE/CYLINDER HEAD - INSTALLATION) Cylinder Head Cover-Bolts 12 - 105 Flex Plate to Crankshaft 88 65 - Engine Mounting (Refer to 9 - ENGINE/ENGINE MOUNTING) Powertrain Torque Strut 54 40 - Exhaust Manifold-Bolts 23 - 200 Exhaust Crossover Pipe-Bolts 54 40 - Intake Manifold - Lower-Bolts 23 - 200 Intake Manifold - Lower Gasket Retainer-Bolts 12 - 105 Intake Manifold Upper-Bolts 12 - 105 Lifter Yoke Retainer-Bolts 12 - 105 Oil Filter Attaching Fitting 54 40 - Oil Cooler Attaching Fitting 27 20 - Oil Filter 20 15 - Oil Filter Adapter-Bolts 28 - 250 Oil Gallery Plug 27 20 - Oil Pan-Bolts 12 - 105 Oil Pan Drain-Plug 27 20 - Oil Pressure Switch 23 - 200 Oil Pump Cover Plate-Screws 12 - 105 Oil Pump Pick-up Tube-Bolt 28 - 250 Oil Dipstick Housing-Bolts 48 35 - Rocker Arm Shaft-Bolts 23 - 200 Spark Plug 16 12 - Thermostat Housing 12 - 105 Timing Chain Case Cover -M8 Bolt 27 20 - -M10 Bolt 54 40 - Water Pump-Bolts 12 - 105 Water Pump Pulley-Bolts 28 - 250
Should you need extra help visit my website here: http://www.bigasautorepair.com/
Apr 15, 2015 | 2005 Chrysler Pacifica
What the torque settling on a 1.8spi vauxhall cavalier 1994
Cylinder head Renew bolts: Yes Tighten: 25 Nm Tighten: 90° Tighten: 90° Tighten: 90° Other engine tightening torques Main bearings Renew bolts/nuts: Yes Main bearings Stage 1: 50 Nm Main bearings Stage 2: 45°-60° Big end bearings Renew bolts/nuts: Yes Big end bearings Stage 1: 35 Nm Big end bearings Stage 2: 45°-60° Oil pump to cylinder block : 6 Nm Sump bolts : 15 Nm Sump drain bolt : 55 Nm Flywheel/driveplate :
  • Use new bolts and tighten as follows:
      • 1,4/1,6 = 35 Nm + 30° + 15°
      • 1,8/2,0 = 65 Nm + 30° + 15°
  • "Pot"-type flywheel = 65 Nm + 30° + 15°
  • Tighten drive plate to 60 Nm.
Clutch pressure plate : 15 Nm Crankshaft pulley/damper centre bolt : Use new bolts. Tighten centre bolt to 130 Nm + 40°-50°
Camshaft sprocket/gear : 45 Nm Camshaft/rocker cover : 8 Nm Inlet manifold to cylinder head : 22 Nm Exhaust manifold to cylinder head : 22 Nm Spark plugs : 25 Nm Lambda sensor (Oxygen) : 30 Nm Chassis tightening torques Front hub :
  • Tighten nut in three stages:
    1. 130 Nm
    2. Slacken off
    3. 20 Nm + 80°-90°.
Steering track rod end : New nuts 60 Nm Brake disc to hub Front: 4 Nm Brake caliper to carrier Front: 30 Nm Brake caliper/carrier to hub Front: 95 Nm Brake caliper/carrier to hub Rear: 80 Nm New bolts ABS sensor Front: 8 Nm ABS sensor Rear: 15 Nm Road wheels : 110 Nm
There you go pretty much covers everything hope that helps
Jan 11, 2015 | Vauxhall Cars & Trucks
How to fit bosch PHO 15-82 planer base plate
my 15-82 has only one blade.There is a plate with three allen bolts to undo.Under that are two more allen key bolts to to undo.The blade moves although these two bolts are tight.The plane when looking at the drum has 6 inline holes.
Dec 17, 2012 | Bosch Tools & Hardware - Others
How do I change the blades on a vermeer 1600A chipper
Place the chute over the rotor. Remove all the clamp bolts for one blade. This will allow you to remove the old blade and clamp bar. Clean clamp bar and blade slot. Install new blade with clamp bar. You will need a knife gauge for this. Use the knife gauge at each end of the blade. Torque clamp bolts to 280 ft. lbs. After blades are installed it is necessary to adjust the bed knife by loosening the three bed knife bolts. Use the set screws to adjust the bed knife to 1/16 in. above the lower feed plate. Torque the bed knife bolts to 250 ft. lbs. Then use the other two bolts to adjust the lower feed plate to .013 to .016 between the bed knife and the rotor blades. Put the chute back into place and you are good to go.
Dec 08, 2011 | Garden
How do you replace water pump?
Assuming this is a 460 Ford Big Block:
REMOVAL
-Drain cooling system.
-Remove drive belts.
-Remove bolts attaching fan shroud to radiator.
-Remove fan blade from fan clutch and remove fan shroud.
-Remove fan clutch and water pump pulley from water pump.
-Remove four bolts and one nut attaching A/C compressor mounting bracket to cylinder head and water pump. Do not remove A/C compressor or power steering pump from A/C compressor mounting bracket.
-Pull A/C compressor mounting bracket forward to remove from stud on water pump.
-Remove bolt attaching generator adjusting arm to water pump. Remove four bolts attaching generator mounting bracket to cylinder head, cylinder block and water pump.
-Remove remaining water pump attaching bolts and remove water pump from engine front cover.
-Remove water pump cover from water pump. Discard water pump housing gasket and water pump cover gasket.
INSTALLATION
-Remove any gasket material from water pump cylinder front cover and separator plate mating surfaces.
-Position new water pump housing gasket and water pump cover gasket coated on both sides with Perfect Seal Sealing Compound B5A-19554-A or equivalent water-resistant sealer meeting Ford specification ESE-M4G115-A.
-Position water pump and water pump cover onto engine front cover. Install bolts and tighten to16-24 Nm (12-18 ft. lbs.).
-Install generator mounting bracket to cylinder head, cylinder block and water pump with four attaching bolts. Install generator adjusting arm to water pump with one attaching bolt. Tighten 7/16-inch bolts to 54-71 Nm (40-53 ft. lbs.) and 3/8-inch bolts to 41-54 Nm (30-40 ft. lbs.).
-Position A/C compressor mounting bracket over water pump stud and secure to cylinder head with four bolts tightened to 54-71 Nm (40-53 ft. lbs.) and secure nut to water pump to 41-54 Nm (30-40 ft. lbs.).
-Install water pump pulley and fan clutch to water pump hub with four bolts. Install fan blade to fan clutch with four bolts. Tighten water pump pulley, fan clutch hub bolts, and fan-to-fan clutch hub bolts to 16-24 Nm (12-18 ft. lbs.). Install fan shroud.
-Install drive belts.
-Fill and bleed the cooling system.
-Start the engine and check for leaks
Jan 10, 2011 | 1997 Ford F350 Crew Cab
Hit steel rod. bent blade. replaced blade, runs but vibrates,bad. and when you try to start it the pull cord, jerks your hand back
probably sheered fly wheel key also check to make sure crank shaft is not bent. lay mower on side air cleaner up remove spark plug wire have some one watch blade bolt while u pull rope bolt should turn with out wobble.
Aug 12, 2010 | Garden
My 2012NB has served me well for about 10 years, but lately lumber does not feed through smoothly and the result is a "ribbed cut" - there are gouges running across the board at about 2 inch intervals. My...
I just read the owners manual online at Makitausa.com and I don't see the reference to the feed rollers and pressure.. I would look at the condition of the planer blades to ensure they are sharp and not pitted. Then I would look at the feed rollers for being out of round. Let me know, it has been a couple years since I worked on one of them.
Jun 30, 2010 | Makita 2012NB Electric Planers
Oct 31, 2009 | Garden
Need help fitting a clutch on a VW GTI Golf
undo centre wheel hub nut 30mm/32mm, socket. undo lower wish-bone outer bolts, disconect battery,/remove starter motor,/remove transmission mounting bolts to body frame ,/ remove all surrounding bolts around bell housing transmission,/ remove clutch cable from transmission,/ remove drive shafts from centre hub and transmission,/ make sure car is standing on axle stands at front of jacking points,/use a trolley jack to suport engine sump with a piece of wood,/ slide transmission away from flywheel,/lower transmision on floor,/undo all clutch plate preasure bolts 10mm,/remove thrust bearing located on centre transmision shaft ,.also make sure if fitted speedo cable needs to be removed.new clutch plate should indicate flywheel ,without fitting clutch plate wrong way round/otherwise transmision will not bolt to engine block.,
May 17, 2009 | 1999 Volkswagen GTI
Garden Logo
208 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
