Question about Hitachi 50UX57B 50" Rear Projection Television
Blue and red shadows on screen
Hello, there is a blue shadow that appears on the left bottom side of tv screen, and there is a red shadow that appears in the middle of the screen. Any ideas? Thanks.
  • Anonymous Mar 28, 2014
    two strips (like shadow) on the right screen and also a bleu spot in the middle
  • 398 Answers
This sounds like one of the convergence IC's has cracked loose or burned out, and should be replaced and realigned by someone with experience.
Posted on Jun 27, 2007
Blue and red shadows on the TV picture
open up the TV then clean up the silver screen and the 3 light bulbs inside its probably just dirty.
Oct 05, 2009 | Philips Magnavox 51MP392H Rear Projection...
Red and blue overlap shadowing
Sounds like a convergence ic problem, normaly i tell people to replace the ic's but in your case try to re-solder the pins on the ic first, you may just have some pins broken loose from the board. Locate the stk392 ic's there will be two of them located on a heat sink, unplug the tv and get to the bottom side of the board and re-solder the pins. if this does not work, then replace the ic's
Sep 02, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Distorted Color and geometry of Picture
replace stk 392-110 ( or stk 392-150 same number) , check resistor 2.2 ohms for open or burn beside STK IC's
Apr 13, 2009 | Panasonic PT-47WX53 47" Rear Projection...
RCA HD52W59 Crooked Convergence
Convergence power supply needs to be rebuilt as its no longer available new. You can get the board rebuilt at the following link and its fully guaranteed.
http://servicemanuals.vstore.ca/
Mar 04, 2009 | RCA HD52W59 HDTV Projection Television
Blue Shadow
YOU CAN TRY TO ADJUST THE COVERSION POINTS USING THE MENU OPTIONS IF THIS DOES NOT WORK THEN YOUR CONVERSION CHIPS HAVE TO BE REPLACED IT COST AROUND 200 TO 250 DOLLARD
Dec 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Blue Convergence
Hello All Above,
Your one and only problem is a bad convergence Amp board. Changing it will fix your set. You can contact http://www.interactiverepair.com for step by step assistant with installation of this board.
List price $100
Part Number: BP95-00142P
Best regards
circuitcity
Mar 11, 2008 | Samsung HCN653W 65" Rear Projection...
Picture problem
might need to get a tech to align it in what is called service mode
Jan 01, 2008 | Philips 60PP9202 60" Rear Projection...
Blue shadows
Sony Too green,red or blue
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Nov 25, 2007 | Sony KP-53HS10 TV
Yellow and Blue shadow on left side of screen
Blue convergence off = needs convergence IC's replaced =
Would you like step - by - step how to ??????
Nov 07, 2007 | Toshiba 51H84 51" Rear Projection...
Hitachi 50UX57B 50" Rear Projection Television Logo
205 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
