Question about Sony Ericsson XPERIA X10 Cell Phone
Cannot turn on because of error sign
Cannot open because of image error sign
    Master:
  • 520 Answers
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Posted on Jan 03, 2013
Error code e1 showing at xerox pro 420? solution..
rror codes If the printer's front panel displays a message Error XX, find the error code in this table and follow the instructions for resolving the problem. If problems persist, check the Xerox web site www2.tek.com/TekSMART/ or contact service.
Error User Corrective Action Error 01
  • Remove and re-install the black Toner Cartridge, then turn the printer off and on.
  • Replace the black Toner Cartridge, then turn the printer off and on.
Error 02
  • Remove and re-install the cyan Toner Cartridge, then turn the printer off and on.
  • Replace the cyan Toner Cartridge, then turn the printer off and on.
Error 03
  • Remove and re-install the magenta Toner Cartridge, then turn the printer off and on.
  • Replace the magenta Toner Cartridge, then turn the printer off and on.
Error 04
  • Remove and re-install the yellow Toner Cartridge, then turn the printer off and on.
  • Replace the yellow Toner Cartridge, then turn the printer off and on.
Error 05, 10, 11,12, and 13
  • Turn the printer power off, then on.
Error 20
  • Remove and re-install the Imaging Unit (make sure that Imaging Unit is locked in place). Turn the printer off, then on.
  • Remove and re-install the Main Charge Grid. Turn the printer off, then on.
  • Remove and re-install the Transfer Kit. Turn the printer off, then on.
  • Remove and re-install each of the Toner Cartridges. Turn the printer off, then on.
  • Replace the Main Charge Grid. Turn the printer off, then on.
  • Replace the Imaging Unit (make sure that Imaging Unit is locked in place). Turn the printer off, then on.
  • Replace the Transfer Kit. Turn the printer off, then on.
  • Replace the Toner Cartridges. Turn the printer off, then on.
Error 21, 22, 30,and 32
  • If a problem persists for Error 30, clean the sensor. See Cleaning Phaser 750 Printers.
Error 33
  • Check for jammed paper throughout the paper path (especially in paper feeder).
  • Remove and re-install the paper feeder and Transfer Kit. Turn the printer off, then on.
Error 40, 41, 42,and 43
  • Check for jammed paper in the Fuser. Re-install the Fuser. Turn the printer off, then on.
  • Make sure that you have the correct Fuser for your local printer power supply:
    110-Volt Fuser Part Number 016-1839-00
    220-Volt Fuser Part Number 016-1840-00
  • Replace the Fuser. Turn the printer off, then on.
Error 50, 51
  • Turn the printer off, then on.
Error 52
  • Remove the Duplex Unit (if installed).
  • Check for paper under the Upper Tray.
  • Turn power off, then on.
Error 53
  • Open left door and remove any jammed media.
  • Tun the printer off, then on.
Error 60
  • Remove the media from the Multi-Purpose Tray. Turn the printer off, then on.
  • Reinstall the media. Make sure you do not overfill the tray.
Error 61
  • Remove and re-install each Toner Cartridge. Turn the printer off, then on.
  • Replace each Toner Cartridge. Turn the printer off, then on.
Error 62
  • Check for jammed paper throughout the paper path (especially in the paper feeder and Fuser).
  • Remove and re-install the Fuser. Turn the printer off, then on.
  • Slide out and re-insert the paper feeder. Turn the printer off, then on.
Error 63
  • Remove and re-install the Imaging Unit. Turn the printer off, then on.
  • Replace the Imaging Unit. Turn the printer off, then on.
Error 70, 71, and72
Error 73
Error 74
Error 80, 81, 82,83, and 84
  • Make sure that all four toner cartridges are installed in the printer.
Error 01p through
Error 47p
  • Make sure that installed memory DIMM(s) are compatible with printer's image processor board and that they are installed in the proper slot(s).
  • you can helpful
Oct 09, 2014 | Xerox Phaser Office Equipment & Supplies
How do i get the imaging tool box for my v105 printer on windows 7
Hi, the software disc when loaded onto the computer for my Dell V105 printer/scanner would not let me open the toolbox. I kept getting a message. Microsoft.NET framework version 2.0 error message. SIGNED in to Dell Website and downloaded http://www.dell.com/support/home/us/en/19/product-support/product/dell-v105/drivers
It now opens the toolbox and works great.
Mar 23, 2011 | Dell Office Equipment & Supplies
I can not get my Lexmark printer to print out an email I rec'dI have the Lexmark printer X2650 please help me. i unpluged it and truned it off and back on again nothing happens.
To be sure that the issue was caused by the enabled Image Sharpening option, do the following:
Go to Control Panel > Administrative Tools > Event Viewer > Application, and look for entries that start with the Error sign, as in the table below:
Windows XP pattlnk_5142009_1243-err.jpg Windows Vista pattlnk_5142009_1244-err_v.jpg
After opening it, look for entries that report faulting application, such as spoolsv.exe, and the faulting module is lx??ibuf.dll. See image.
If using Windows Vista 64-bit, one might also see this error message (click on the link to view image).
Solution
Windows XP Click Start, then select Printers and Faxes. Right-click the Lexmark printer, and from the drop down menu select Printing Preferences.
Go to Image Enhancement and deselect the Image Sharpening option. See image.
Windows Vista Click Start (Ribbon), then select Control Panel. Click on Hardware and Sound and from the list select Printers. Right-click the Lexmark printer, and from the drop down menu select Printing Preferences.
See image.
Jan 18, 2011 | Lexmark X2600 InkJet Printer
Many DLL error messages on start up
Your Operating System is corrupted, probably by a virus or a program you recently installed.
The best solution would be to reinstall your Operating System (OS).
Remember to back up your data before OS installation.
Dec 29, 2009 | Microsoft Windows XP Home Edition
Outlook express error (mhtml://0000002/
i hav a solution try this
Open Outlook Express -> Open Tools -> Open Options -> Open Security tab -> Uncheck "Block images and other external content in HTML email."
Don't worry, you'll still get all of the images and external content that was sent to you.
Turn those firewall's back on!
Apr 22, 2009 | Microsoft Windows XP Home Edition
Sharp 5316 showing paper jam sign at right door but no paper
Shut it off, wait 30 seconds, turn it back on. If the path IS clear, the error will be gone.
Feb 23, 2009 | Sharp AR-5316 Advanced Digital Imager...
Camera turns on but shutter does not open. green light comes on then it beeps twice and shuts down. You can view pictures fine though
You mean SD400 camera doesn't show any error sign and it just doesn't have live view to shoot picture?
If yes, its problem of bad CCD imager and Canon will provide free of cost repair facility for SD400 camera.
Click Canon CCD Advisory for details.
Oct 24, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon image runer 3200 error sign
This error has to do with the Fixing Assy overheating. The sub code "0004" is indicating there is difference in temperature between the two thermistors. Pull open the access drawer on the left side and undo the two screws that secure the fixing assy. Once removed, see if there any small pieces of paper hanging out possibly stuck between either sensor causing the temp difference. If any of this seems beyond your capabilites just order a new fixing assy and save the labor charge. Good luck.
Nov 03, 2007 | Office Equipment & Supplies
Lens cover not open and blank screen
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor..i know it is free for replacing that sensor cause that is one of the model that sony recall produc and the cover not open error message is a poor contact of the lens cover switch...
Sep 09, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony Ericsson XPERIA X10 Cell Phone Logo
16 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
