Question about Isuzu Vehicle Parts & Accessories
Hi there this is Riaan again .My Isuzu 250 start every time but only run for 3 seconds and then engine stops.I thought that it was the immobilizer that cuts the diesel but i have already changed the unit and it does exactly the same the starter is also dead now.can somebody help please?
Is your key a programed key you might check sometimes if you are useing just a door key thats not programed to the ignition it will start but not stay running
Posted on Jan 04, 2013
My isuzu 4hf1 engine failed to start?
not starting can be from several reasons
cam/crank position sensors failing--wiring -units ---broken timing belt /chain
immobilizer not working properly--flat battery in key fob-- fuse has been removed and replaced
ignition control module failure
injector problems
low fuel pressure from pump not working
the idea is to run the fault codes to get some idea of the area to start checking and work from there
Jul 10, 2016 | Isuzu Cars & Trucks
Where is the emergency fuel cut off switch located on 1999 Isuzu trooper
no engine stated..
i guess you like to search on rumors?
there is inertial switch. but no country stated nor engine nor drive line.
first check for spark not fuel
the ECU cuts Fuel anytime it sees spark fail (3 ways)
to stop TV like crash and burn,
check for spark if its good x4 or x6 , (depends on engine size)
and if that is good, check that engine runs for 3 seconds on test fuel, if thats good? then we check fueling system.
see?
we have posted this answer on ISUZU vast times.
and not one poster ever once, told what engine is there or they country.
or insert scan too
crank for 5 seconds, Got P03xx codes, that is the BINGO for no starts, right? ever scan a car? its a cheap tool all mech have.
and all savvy DIY have.
here is a power search in fixya.
1200 answers ON TOPIC
https://www.google.com/webhp?gws_rd=ssl#q=isuzu+inertia+site:http://www.fixya.com/
some cars have it, mostly not.
fords have
and is rumored some ISUZU, but not ours.
but ive not had all engine options, on a 1999.
so will look yours up, 1999 and pretend USA model. (not canada)
some isuzu do have this red electric switch
so lets see if the 99 usa has it.
that means if its missing in the pump page, its not there.
drum rollllllll
no switch. 1998 usa trooper.
end easter egg hunt 1200.
the pump runs off the fuel pump relay DIRECT
the relay IS ONLY controlled by the ECU,
Sep 20, 2015 | Isuzu Cars & Trucks
Isuzu 250 start every time but only run for 3 seconds and then engine stops.I thought that it was the immobilizer that cuts the diesel but i have already changed the unit and it does exactly the same the...
It sounds like an incorrect wire connected. Normally the glow plug wire would supply power for a short period and then the relay switches off.
I suspect you have connected this wire to the diesel pump.
Jan 03, 2013 | Isuzu Vehicle Parts & Accessories
I have a 2006 I280 iszuzu pickup the antitheft was engaged and won't start how do I fix it?
MAKE SURE YOU USING THE RIGHT KEYS. TRY ANOTHER IGNITION KEY.PLACE KEY IN THE SWITCH. TURN IGNITION SWITCH TO ON POSITION UNTIL IMMOBILIZER WARNING LAMP ILLUMINATES FOR 2 TO 3 SECONDS. IF IMMOBILIZER WARNING LAMP ILLUMINATES FOR 2 TO 3 SECONDS THEN FLASHES RAPIDLY.KEY CODE NOT RECOGNIZED.REMOVE KEY AND TRY AGAIN. IF ALL FAILS TAKE CAR TO DEALERSHIP THEY HAVE TO USE DIAGNOSTIC EQUIPMENT TO FIX CAR.PROBLEM COULD BE IN THE IGNITION SWITCH,BCM,FAULT IN THE ECM OR IMMOBILIZER CODE INCORRECT.
Jul 04, 2011 | Isuzu i-280 Cars & Trucks
Isuzu wizard 4jx1 engine is crank but not running
hi how can you help me coz i hit the pot hole with my isuzu wizard and the engine run off, i tried to start it again several time and it wont what could be the problem.please help.
Dec 19, 2010 | Isuzu Trooper Cars & Trucks
I own a 2004 Isuzu Rodeo 3.2L V6 2WD. On saturday it died on me. at first i thought it might be the fuel pump because the engine turned over but wouldn't engage. Gas level was good as was the battery. ...
my problem was electrical, removing the batt (neg. terminal) for a few seconds resets the Engine Control Module (ECM) which operates the full pump relay, there should be a fuse in the relay box in under the hood labeled ECM or ECU. Pulling that fuse for 10 secs. or so also resets the ECM, try this and if it immediately works I suggest to drive it locally until it will not start again and repeat the removal of the ECM fuse. If this work out I suggest that you ECM is receiving a sensor signal to shut down the pump relay so I've been told, is the check engine lite on
Dec 07, 2010 | 2004 Isuzu Rodeo
2003 cts won't start - we changed the fuel filter and it started
Many cars these days are equipped with an immobilizer. (you can find more information about the immobilizer in your owner's manual). The immobilizer allows the engine to run only if the correct key is used. If your car has an immobilizer, you probable see a "Security" or Key-shaped light coming on on the dashboard every time you turn the ignition ON. If this light is flashing when you turn the ignition ON, it could mean that there is some problem with an immobilizer or the system does not recognize the key. If the immobilizer doesn't recognize the key, the engine wold not start at all, or would start and then die in few seconds.
You can try a spare key, if it won't work, your dealer is the place to call. Sometimes, the key is just need to be reprogrammed. On some cars you can find the information how to reprogram the key in the owner's manual.
Aug 24, 2009 | 2003 Cadillac CTS
MY CAR DOESNT WANT TO START UP..THE LIGHTS ON THE DASHBOARD GOES ON. RADIO ON..BUT IT DOESNT START! SOMETIMES I HAVE TO WAIT 5 MINUTES AND TRY AGAIN.THEN IT STARTS UP?? CAN ANYONE HELP ME? KIA RIO 2002
hi..
You can try a spare key, if it won't work, your dealer is the place to call. Sometimes, the key is just need to be reprogrammed. On some cars you can find the information how to reprogram the key in the owner's manual...
thank u
rate me
Aug 19, 2009 | 2002 Kia Rio
My f250 will not start. Cranks over, but will not start. This is the 6.0 2005 model.
thank u
rate me!!
Jul 28, 2009 | 2005 Ford F 250 Super Duty
4JX1 engine cut off while test drive after oiland filter change and not starting
That pop noise is ok just the flap in the throttle body coming open when the car stops .
The engine may have stopped because its low on oil so the oil pump for the injectors wont work - takes about 7 u.s. quarts of 5/30 fully synthetic oil at service time to run right.
It can also stop if the pressure sensor in the injector rail packs up or the oil pick up pipe for the injector system falls off due to cracking the mount .
Oct 28, 2008 | 1999 Isuzu Trooper
Vehicle Parts & Accessories Logo
73 people viewed this question
Top Isuzu Vehicle Parts & Accessories Experts
Randy Ohler
George Agios
George Agios
SriPhi
Are you an Isuzu Vehicle Part and Accessory Expert? Answer questions, earn points and help others
