Question about Sony KP-57WS500 57" Rear Projection Television
No cable or video signal in left window only component inputs 5&6
Only inputs 5 & 6 work in the left window of twin view and i can only watch what's in the left window in fullscreen. cable signal, videos 1 & 2 etc do not work in the left window only the right and i cannot watch anything in the right window in fullscreen. what's the problem?
4 Suggested Answers
  • 11 Answers
SOURCE: Problems using component video cables with Sony KDF-50WE655
Is your source in progressive scan?
Posted on Dec 13, 2007
SOURCE: Input 6 - HD Input - Green Screen. Audio Only. No picture.
I am having a similar problem with the inputs. I have a cable box plugged in to cable antenna, DVD to video 6 using HDMI, Mac computer plugged in to video 7 - using HDMI (TV does not recognize this) and then Nintendo Wii hooked up to Video 1. My problem is that Sony only realizes 2 additional components like the video 1 (wii) and DVD on video 6, it does not play the other components. I have to niw manually switch the cables to have them work...
Posted on Sep 26, 2009
Slinteriors
  • 8617 Answers
SOURCE: my component inputs lost picture
Thats an issue with the U board ( inputs) You can get the replacement U board from www.tvrepairworld.com under the sony circuit board catagory
Posted on Jul 25, 2011
Static & no picture from UHF input / Component Video fine
there is sinal interferences from laser products pc mobile transmitters or video games get high quality vcr and cable tv cables move or switch off any video games cd players energy saving lamps or pc and microwaves n motors like pumps change the position of installation of cable and antenna to avoid path of interference
Jul 18, 2013 | Sony KV-36XBR450 36" TV
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
I plugged in the normal 3 Video inputs and it still doesn't work.
More info is needed, please. When you say 3 video inputs, what are you referring to? I believe the Sanyo has the HDMI, RGB/YPbPr component video, S-video component, RCA composite video and Coaxial connections, though I'm not sure how many of each. So lets start with the best quality to least.
HDMI: This is one cable that provides both audio & video and produces the best picture quality. It comes in different lengths and is a wide, flat connection. A must for 1080p resolution signals.
Component video, RGB or YPbPr analog component cables: 5 separate RCA cables, 3 of which are video that separate the video signal & 2 audio cables. The 3 video cables are generally red, green and blue (RGB) or marked individually with the letters Y, Pb/Cb & Pr/Cr . The audio cables are red & white. You may see these on the back of DVD players often. They will carry a signal up to 1080i but not 1080p.
S-video component: One cable for video, it is a round connection with several pins in it and will only plug in one way. You must use 2 RCA cables for audio with this cable, red & white again.
Composite video: 3 separate cables; Red, White & Yellow. Red & White are audio, left and right while yellow is video.
And finally there is coaxial which it the cable that is identical to the cable from the pole/ cable box or your dish. It is the poorest quality.
What can happen is you are using 3 standard RCA cables and have them plugged into the component input & they will not carry the signal, or one end in component input and the other end in the composite output or vice versa. Another is that you have the wrong input selected on the menu. Check all your cables and connections, plus the input you have selected on the TV itself.
Dec 09, 2010 | Sanyo 42 in. LCD TV
Dear Technician, I have 4 components that I am trying to connect together, a Panasonic HDTV model #TC-L32X1, a GO Video DVD/VCR model #DV2130, a Yamaha stereo receiver model#RX-690, and a Scientific...
Hi and welcome to FixYa,
Unfortunately, size limitation of what could be attached prevents posting a connection diagram. Still, proposed connection scheme:
  • 4250HDC's HDMI to Panasonic's HDMI 1 or 2;
  • 4250HDC's VIDEO OUT to GoVideo's LINE IN 1 VIDEO;
  • 4250HDC's AUDIO OUT to 2 pcs of RCA Splitters (shown below);
  • 1 pair from the 2 splitters to GoVideo's LINE IN 1 R-AUDIO-L;
  • the other pair to Yamaha's LD/TV L & R;
  • GoVideo's LINE OUT VIDEO to Panasonic's VIDEO IN 1 VIDEO;
  • GoVideo's LINE OUT R-AUDIO-L to 2 more RCA Splitters;
  • 1 pair from the 2 splitters to Panasonic's VIDEO IN 1 L-AUDIO-R;
  • the other pair to Yamaha's VCR 1 IN L & R;
  • to watch cable TV in HD quality, set Panasonic to HDMI 1 or 2 by pressing Panasonic remote's INPUT button, then 3 (or 4), then OK;
  • to hear cable TV programs on Yamaha's speakers, set Yamaha to LD/TV;
  • to watch DVD or VHS, set Panasonic to Video 1 by pressing Panasonic remote's INPUT button, then 6, then OK;
  • to hear DVD or VHS on Yamaha's speakers, set Yamaha to VCR 1;
  • to record cable TV programs, press GoVideo remote's TV VIEW button a couple of times to cycle through the signal sources or until Line 1 is displayed.
The use of the splitter shown below would effectively double the AUDIO OUT of the cable box and the DVD/VCR combo to feed both the TV and the stereo. Additionally, this would allow use of the cable box and/or the DVD/VCR combo with or without the Yamaha.
dd46b75.jpg or
27340be.jpg or
Good luck and thank you for asking FixYa.
Apr 27, 2010 | GoVideo Go Video DVD/VCR Combo
HOW DO I CONNECT A AN EZPRO 610 PROJECTOR TO A LAPTOP COMPUTER.
1. You will need a VGA or S-video cable and a 1/4 inch stereo plug that will go from the earphone jack to the EZpro then out to a amplified system for the sound.
2. I believe the EZpro has connections for HDMI which will supply sound as well as High definition video. You should have an adapter for the HDMI also if you
3. connections port as follows:
1. USB Connector (Connect to PC for Remote Mouse function)
2. RS-232 Connector
3. Audio Input Connector
4. S-Video Input Connector
5. DVI-I Input Connector
(PC Digital (HDCP)/PC Analog/Component Video Input)
6. VGA In/SCART Connector (PC Analog Signal/Component
Video Input, HDTV/SCART Input)
7. VGA Output Connector (Monitor Loop-through Output)
8. Power Socket
9. KensingtonTM Lock Port
Looking at the usb port go counter clockwise the numbers are in succession. 1- 9
1 Power Cord
2 VGA Cable
3 DVI-I to VGA Cable (Optional accessories)
4 Audio Input Cable (Optional accessories)
5 RS232 Cable (Optional accessories)
6 USB Cable (Optional accessories
Apr 24, 2010 | CTX Optoma EzPro 610 Multimedia Projector
Forcing audio only signal through component
You cannot get AUDIO from Component Video, as it is only VIDEO, you must get another set of Cables RED & WHITE, and connect them from the AV, AUDIO Jacks, OUT on the "Sender" to the AV AUDIO IN on the TV. So you will have 5 Cables connecting BOTH Video & Audio. The Component Video, uses Blue, Green, & Red, these go color to color on the RCA Jacks at BOTH ends PLUS the Red & White Audio, color to color at BOTH ends. .Hope that clears things up.
Feb 14, 2010 | Samsung LN-S4051D 40 in. LCD Television
Aug 04, 2009 | Sony KDS-R50XBR1 50" HDTV
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
HD channles
Hi Scan 1080: Enables you to receive the 1080i, 720p, 480p and 480i digital TV formats. By using the VIDEO 5/6 IN jacks, you can connect a DTV (digital television) receiver to view DTV programs. q DRC Multi-Function: Unlike conventional line doublers, the DRC feature doubles vertical and horizontal lines, resulting in four times the density for quality sources such as DVD, Satellite and Digital camcorder. q CineMotion: Using the 2-3 Pull-Down technology, the CineMotion feature allows you to obtain a smooth picture movement when playing back movies or other video sources on film. q Twin View: Using Multi-Image Driver (MID-X), Twin View allows you to watch two programs side by side with the ability to zoom in one picture and listen to selected window. You can watch pictures from two different sources (1080i, 720p, 480p or 480i) simultaneously. q 16:9 Enhancement: Vertical Compression technology that maximizes picture resolution on “anamorphic” or “enhanced for wide screen” sources, including selected DVDs. q Steady Sound: Equalizes volume levels so there is consistent output between programs and commercials. q Parental Control: V-Chip technology allows parents to block unsuitable programming for younger viewers. q Component Video Inputs: Offers the best video quality for DVD (480p, 480i) and Digital Set-top box (1080i, 720p, 480p, 480i) connections. q S-VIDEO Inputs: Provides a high-quality image for connected equipment. q Favorite Channel Preview: Preview up to eight favorite channels
Jun 02, 2008 | Sony KP-61HS20 TV
No input detected on projector
it sounds like the A/V reciever does not upconvert the component signal to HDMI. Not many do. The Marantz recievers will (SR6001, SR8001, etc..). Also bear in mind that HDMI cables are finicky and may require amplification over a few meters long.
Dec 04, 2007 | Hitachi PJTX100 Multimedia Projector
Sony KP-57WS500 57" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
