Question about Bosch HBL 435 Stainless Steel Electric Single Oven
I have a Bosch hbl435 electric wall oven. The time started fading the other day and yesterday it went dark. We were able to use the oven but not its totally not working. I took the panel off and when I did the screen came back on. The oven would work as well. When I pushed the panel back in it went off. Arghhh! I looked for loose wires but didn't see any. When I moved the panel back and forth the screen would flicker on then off. Now it's totally off. I can't get it to come back on at all. Any ideas? Main mother board? Bad relay? Thanks for any help or suggestions,
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Posted on Dec 17, 2008
barkencoa
  • 3463 Answers
SOURCE: cannon oven not working
If the fan is working o/k, then it is sure to be the oven element that is faulty, a common fault with fan ovens, replace element, and it should be o/k.
Please rate my soluti9on.
Thanks.
Posted on Jul 19, 2009
barkencoa
  • 3463 Answers
SOURCE: Our Bosch electric oven is 5 years old. We
Either you have not refitted the door back correctly, or the door hinge springs are weak, a common problem.
This being the case, then the only solution is to replace door hinges.
Posted on Feb 11, 2010
Macmarkus
  • 2605 Answers
SOURCE: I have a Bosch built-in
Welcome to FixYa,
I'm looking at the diagram for your oven and I do not see a P17 connection, however you said it is a connection on a relay. Can you identify which relay it is connecting to i.e. K5, K3, K7 or K8 ?
K5 is the bake element or "DE" ( down ele. )
K3 is the convection element or "RE" ( ring ele. )
K7 is the inner broil element or "RE" ( internal up ele. )
K8 is the outer broil element or "EUE" ( external up ele. )
I should be able to help move you forward in this regard if you can clarify this matter. I'll watch for your reply.
Regards,
Macmarkus :)
Posted on Dec 02, 2010
No digital display and nothing works, like there is no power, however there is power going to oven What could be the issue?
Bosch HBL5450UC information from Consumer Reports
www.consumerreports.org > ... > Ratings
Consumer ReportsThis Bosch 30-inch electric wall oven has the following: ... We have had problems with it not working properly numerous times and have had it serviced directly ...
Aug 05, 2015 | Bosch Ovens
How do I set the clock
Set the clock by following these steps: a). Touch TIME pad. b). Turn rotary knob clockwise until CLOCK appears. c). Touch TIME pad. d). Turn rotary knob in either direction. The time displayed will change in 10-minute increments and indicate AM or PM. Turn the knob in the opposite direction and the display will change in one-minute increments. e). Touch TIME pad. The clock is now set. in some units there is button instead of knob in that case the clock indicating button has to be pressed . This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 06, 2010 | Bosch Appliances 27 in. Wall Oven Electric...
Bosch oven function error e124
Can you provide a model number for your oven. Is it a single oven or double ? Wall oven or free standing range ?(conventional with cooking surface)
Unfortunately the error codes for Bosch are different depending on the model of the unit.
Thank you, I`ll look for your reply.
macmarkus :)
Jan 09, 2010 | Bosch Ovens
I have a built in electric oven and yesterday the power went out all day and the temperature is in C not F, and the clock will not set
find the main breaker for the oven turn it off for about a minute and then turn it back on ...yep some times you have to reboot even your oven
Good Luck
Oct 10, 2009 | Ovens
Clock fades
Sorry the only way to repair is to replace the control board
Mar 28, 2009 | Frigidaire 27" Built-In Single Electric...
Bosch convection double oven,ovens won't heat,only broilers work
Thanks.
Dec 17, 2008 | Bosch Ovens
Bosch HBL 435 Stainless Steel Electric Single Oven Logo
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
