Question about Mitsubishi WD-60C9 60" DLP HDTV
Unit won't pass the welcome screen
Originally, this unit would come to the splash screen and then shut off. If you continued to turn the unit on after it shut off, it would turn on and work perfectly until you turned it on again. You would have to go through turning it on several times again until it finally stayed on. Later, I found several people that had this type of issue, and they were advised to update the software. I extracted the needed files to a thumb drive and followed the instructions to install it. When the splash screen came on, it never turned off, and the green light simply continued flashing. I repeated the process twice, and the issue remained. Please help.
ctf1800
  • 4402 Answers
SOURCE: half of screen blacks out
sounds like power supply caps or caps in the dm board
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Posted on Jan 08, 2008
Slinteriors
  • 8617 Answers
SOURCE: Blinking green power light & shut down
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
Posted on Apr 07, 2008
SOURCE: Mitsubishi WS-65513 Flashing green light
please send me info on cap replacement, to fix flashing green light problem.
fitzz47@comcast.net
Thanks in advance.
Posted on Sep 26, 2008
SOURCE: ws65711,8 years old, working great with out
SD TECH,
Just started experiencing convergence problem with my Mits ws-65711. I have decided to try to repair on my own and have the service manual. I see also you have step by step instructions for the repair and perhaps photos of the fuses. I could really use this info if you are able to provide.Thanks in advance. I did the self check by holding in MENU and INPUT buttons and got 1 green blink followed by 2 shorter/quicker green blinks?
Posted on Nov 18, 2009
  • 59 Answers
SOURCE: Blinking green timer light does not go off, cannot turn on tv
this problem on these tv's can be caused by a couple of things one is some bad caps in the power supply the other is the bad caps in the dmd board then in that case you normally would need to have the dmd chassis replace at a repair center.
Posted on Jan 25, 2010
2009 murano radio won't shut off
Is it a aftermarket unit , if so you might have to join the yellow wire from back of the unit to the red live wire , the yellow wire is continuity from your ignition and some time needs powering off the live to your unit to work
Feb 24, 2013 | 2009 Nissan Murano LE
Paslode nail gun ,fan won't shut off
replace circuit mold assembly or spark unit its probably the spark unit
Jul 08, 2012 | RTO PasLode 900420 Impulse Framing Nailer
Philips dvdr3390/37 won't power on
Your unit being stuck in standby mode is an indication that its having a power problem. Remove its plug from the wall and fix it back into the wall, then turn it on again. If its still stuck in safe mode, then the power supply board in the unit is the cause of the problem.
The power supply board might be defective and maybe that's why the unit won't power up. Its receiving power but it cannot transfer the current to the necessary part of the unit because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the unit might not come on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Jan 05, 2012 | Philips DVDR3390/37 DVD Recorder
My toshiba tablet won't let me go past the welcome screen
If this is under warranty take it back. If it isn't power the unit on with just the battery powering the unit. When you see the Windows splash screen drop the battery out after the screen goes black put the battery back in and press the power button. This should bring up the on screen menu telling you it failed to start or shut down correctly. Select, Boot in Safe Mode and see if the system will power on. If that fails you need to do a system restore. To access system restore options power the unit on and press and hold the F10 key, this will bring up the restore Windows options. From that menu select to restore your operating system. If that fails you will have to do a complete restore to factory default settings. If that fails you will have to replace the hard drive.
Dec 25, 2011 | Toshiba Tablets & eReaders
Ink system has failed. Unable to copy. Refer to printer Documentation. Error 0xc18a0101
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
If this reset won't work ...open the front door ..and move the carriage to look for any paper left from a previous jam or so ...Make sure there is nothing blocking the ink carriage ..and than close the door and make the reset again ..
print a calibration if it asking for ..
BY the way ...it may be a good idea to reinstall the software again too ..
If this will not work ..try this ..:
A. - Press and hold the "*" key.
B. - Press the "#" key and release both keys.
Display should say "Enter Special Key Combo"
C. - Press and release in sequence the "1", "2" and "3" buttons
Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE".
Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS".
Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
If it shows improper shut down ..press on to shut down ..
Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
message: "welcome to photo-smart express"
Using the Power Button, please turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Now plug the power cable into the wall outlet first and then into the back of the printer.
Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
Print the report and if it is all OK ..it will work ..
Jul 29, 2011 | HP Photosmart 3210 Printer
My dehumidfier won't shut off. I check everything out and it's good but it just won't shut off it keep running.
It may be, that you have it running in continuous mode, rather than timed mode. Also, most dehumidifiers fans will run almost continually, to keep the air moving, so the humidity sensor can pickup and increase in humidity, if there is one.
If the above doesn't seem to be the problem with your unit, turn The Master ON/OFF Switch to OFF and unplug the unit for 12-15 minutes. This will give the electronics time to reset themselves, if necessary.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 23, 2011 | Fedders A7DH45B2A Dehumidifier
My Creative Zen started freezing a couple weeks ago. I would press the restart button at the bottom left and that seemed to solve it. Now though, when I turn it on, the Creative Zen welcome screen comes...
It sounds like the hard drive is damaged I have a archos 605 wifi it froze up on me so i turned it off and turned it back on and it wouldn't load pass the archos welcome screen come to find out my hard drive was damaged.Hopfully yours is still under warranty otherwise you'll have to send it in and pay to get it fixed but i would say the hard drive is damaged.
Nov 28, 2008 | Creative Labs Zen Touch MP3 Player
Touch screen issues
Has the unit ever been really wet or is there a hole in the touch screen foil? If not have you ever done a cold reset?
. First turn the unit OFF, then HOLD your thumb on the furthest bottom right hand corner of the screen, push as far into the corner as you can on the screen itself. While holding your thumb/finger on the screen press and hold the POWER ON button until you see the ZUMO splash screen, once the splash screen is up you can release the power, but continue to hold your thumb in the right corner of the screen for another 5 - 10 seconds, you should see a window that pops up and asks "Do you really want to erase all user data?", make sure to answer YES to this window, if you don't see this window, then turn unit OFF and try the above instructions again, ensuring your thumb is in the furthest portion of the bottom right hand corner of the touch screen.
Jul 23, 2008 | Garmin zumo 550 GPS Receiver
Mitsubishi WD-60C9 60" DLP HDTV Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
