Question about Nokia 3110 Cellular Phone
Found new hardware Nokia 3110c
But hardware could not be install because the wizard could not find the necessary software
  • sachinvd Jan 20, 2009
    Nokia 3110c connected but error in driver
  • 4 Answers
Just download pc suite from nokia site.
Posted on Feb 26, 2009
Download Nokia PC suite for Nokia 3110c from " http://www.nokia.co.in/ "
i also had the same problem but after downloading Pc suite for 3110c problem solved.
Posted on Feb 27, 2009
How to re instl my nokia 3110c software
To reinstall the device software you can do so using the Software Update feature from Nokia Suite. Refer to the link below:
http://www.nokia.com/global/support/nokia-suite-specifications/?view=detail
1.Make sure you have the latest version of Nokia Suite installed and running on your PC
2.Connect the device to your PC using the USB data cable
3.Open Nokia Suite and select from the menu Tools > Software update
4.On the Software Updates page, under your device click the reinstall link to start the wizard that will guide you through the re installation of your device software
Before installing a software update or reinstalling your current device software it's a good idea to perform a backup of your data:
1.Connect your device to Nokia Suite
2.From the menu select Tools > Backup
3.Follow the wizard to create the backup.
To restore the data from a backup go into Nokia Suite, Select Tools > Restore and follow the wizard to restore your data.
Sep 28, 2012 | Nokia 3110 Cellular Phone
Henever i open my music player it updates and then shows no music files found. my model is 3110c. plz help me. thanks in advance
Actually I want to know the size of the memory card. Anyway Make back-up all the necessary data to mmc etc.and follow the procedure below.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / for detailsClick here1 . thanks for visiting fixya. Good luck.
Sep 04, 2011 | Nokia 3110 Cellular Phone
How to flash nokia 3110c
Jaf box supports Nokia 3110C and many more other Newer nokia models, you can flash it using Jaf box with all the necessary cables and database. If you don't know what is jaf box and what is meant by flashing, I don't think you can do that. Flashing needs specific hardware and software, you can't simply flash it on your computer unless you have the required softwares and hardwares.
Note: Jaf box and all it's accessories will cost you twice the cost of Nokia 3110c and most importantly, you need training and experience to use them.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 01, 2011 | Cell Phones
I am getting "Invalid Application"
DOWNLOAD THE APPLICATION TO YOUR PC
AND THEN INSTALL USING NOKIA PC SUITE
Jan 20, 2011 | Nokia 3110 Cellular Phone
Contect service in nokia 3110c how can i solve i am mechenic
Install Nokia Pc Suite software on you PC and do not connect the USB connectivity cable before or during the Pc Suite installation. When the Nokia Pc Suite installation is finished, Nokia Pc Suite will automatically launch the Get Connected Wizard. The on screen instruction will guide you to connect the USB connectivity cable to your PC and to your Phone. The default connection setting will appear on your phone screen. Select Pc Suite.
Nokia Pc Suite will install the cable drivers. This installation may take a few moments and you may be asked to accept the multiple driver installation. Once your Nokia Pc Suite have been installed, you can connect to the internet using "One Touch Access"
Jun 18, 2009 | Nokia 3110 Cellular Phone
Unable to connect Nokia 3120 Classic with PC
Souns like you need to reinstall the Nokia software. Just pop in the CD and run the setup wizard again. Reboot computer when you are done and try connecting your phone.
If you need further assistance, let me know.
Regards,
Jedi
Mar 20, 2009 | Nokia 3110 Cellular Phone
I can't transfer data from Nokia device to PC by USB cable.
u can transfer data in nokia 3110c by connecting the phone by a cable then u can select the option "DATA STORAGE" from de menu then it will work.
Mar 18, 2009 | Nokia 3110 Cellular Phone
Nokia 3110c music player not working
my nokia 3110c music player updates continuously but does not start
Feb 09, 2009 | Nokia 3110 Cellular Phone
Me again
HI.
DO U HAVE THE NOKIA PC SUITE CD..
IF U DON'T HAVE.. TAKE THIS LINK DOWNLOAD THIS ONE. AND INSTALL IT WILL SOLVE THE PROBLEM. www.softpedia.com/get/Mobile-Phone-Tools/Nokia/Nokia-PC-Suite.shtml
THANK SIR,
IF ANY DOUBT , I AM THERE TO ASSIST U.
DON'T FORGET TO VOTE ME..
Sep 04, 2008 | Dopod 818 Pro Smartphone
I recently bought a HNC model CTGJD2028 3D Optical USB Plug and Play Mouse for my Compac Deskpro EN running XP Pro. Plugged mouse into usb port. Get a Popup Bubble – Found New Hardware – Mouse. Message...
UPDATE YOUR WINDOWS SOFTWARE FROM MICROSOFT OR YOUR VENDORS SITE, THERE MAY BE MORE SOFTWARE PATCHES FROM THE VENDOR TO FIX THAT TYPE OF PROBLEM
Aug 11, 2008 | Computers & Internet
Nokia 3110 Cellular Phone Logo
337 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
