SOURCE: Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed. Try turning off the tap for the hot water then setting the washer to just cold wash and then hot washif you get nothing on the cold and cold water when set to hot they are probably reversed. Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
SOURCE: water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
SOURCE: hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
SOURCE: I have a Defy Laundromaid
Error E9 means a problem with your water pressure sensor. Check the sensor by pulling the hose attached to the
bottom part of the tub and blow on it and test the terminals of the
sensor if it will close or open.
Hope helps.
