I puchased a Fireplace mantel from Fingerhut last March. Now all of a suddent theres no flame or heat. The on button goes on but nothing else works. The name on the fireplace is FEBE FLAME. Im getting nowhere with Fingerhut. I need to know is there a fuse in the fireplace. Is this worth fixing or should I just throw it out. Im so mad I paid 500.00 for this set. Your help would be very much appreciated. Thank you.
detox101
SOURCE: Gas fireplace pilot flame won't stay lit.
Hi , you can try and pull the panel on the bottom of fireplace out and check the adapter in fireplace. Sometimes they go bad. When you open in also check to see if there is an adapter plugged in and a option to use the battery operated function. If this goes bad the pilot will not stay lit.
Posted on Jan 14, 2009
SOURCE: gas fireplace will not stay lit
there is a probe that is in the one of the flame... This once heated builds up enough pressure do to the heat to keep the shut/off valve open... (reason, if the flame went out the gas would continue to flow) this "thermocouple is replaceable !! contact me at homeprohandyman@verizon.net
Posted on Feb 23, 2009
SOURCE: electric fireplace does not heat
I have a cheap electric fireplace bought in SuperCentre store-heater no longer works. It says its a one piece system. Can these heaters be replaced or repaired(probably made in China) or am i better off scrapping it and buying a new one?
Posted on Oct 18, 2009
  • 3368 Answers
SOURCE: My propane fireplace pilot light goes out when the
I am just guessing but it may be set to low. The rush of air when it extinguishes could be blowing it out.
Good Luck,
Gilshultz
Posted on Nov 30, 2009
  • 6 Answers
SOURCE: I have a pyromaster electric fireplace model HEF
Unplug the motor wire connector and jump it with a 9V. battery. If the motor spins it's good. Chances are the FLAME SPEED CONTOL (Part Number 10001589) circuit board is bad. I had to replace mine. It's at the bottom of the fireplace behind the contols panel.
Good Luck
Perry Gibbs
Posted on Dec 05, 2009
Lighting the pilot, starting the fireplace
Turn on the gas, hold the pilot flame button down and light the pilot flame, continue to hold the button for at least three min's, release the button pilot should stay lighted.
Jan 06, 2017 | Majestic Heating & Cooling
Flames wont move
There should be a small electric motor that turns the wheel that looks like flames. That little motor may not be working making it look like the flames don't work. May have to replace the motor.
Dec 03, 2014 | Classic Flame Nantucket Corner or Flat...
Can ignight but when button is released flame goes out?
you have a problem with security valve you can find a small pin next to the ignition candle, make sure that this pin is close to the fire when pressing the button, this pin needs to heat to generate a low voltage to the valve in order to keep providing gas.
Mar 24, 2014 | Leisure HOMEPRIDE Electric Fireplace...
The flame effect quit working in my Brittany Electric Stove Heater, Model #BESBY-1500. How can I replace or repair the flame effect?
Typically the flame effect is accomplished when a motor turns a rod with polished metal strips on it. The strips then reflect the light onto the back of the glass. The the rod rotates, the reflection moves giving the effect of the flames moving. If the lights work on your unit then the motor has most likely stopped. It would need to be replaced. A quick internet search turned up nothing for that company so you may need to go back to the store where you purchased the unit to get the part. Once you have the part, you will need to disassemble the unit. Some units are simple (like removing the fake logs) and some units are more involved (like removing access panels from the back or bottom).
Mar 10, 2014 | Vendor Development Group Inc Borgen...
The flame effect quit working in my Brittany Electric Stove Heater, Model #BESBY-1500. How can I get a replacement flame effect?
I purchased a mantel fireplace from Fingerhut last March. The name on fireplace is FEBO FLAME. Now the on switch lites on but theres no flame or heat. The buttons on fireplace or remote do nothing. Id...
Since it can be a potential hazard, it must have safety protocols in place. If you have the owners manual, Read it's instructions carefully. Look through manual for TROUBLESHOOTING then look for safety locations, there you should find all the answers to your questions. Good Luck too you.
Jul 05, 2017 | Heating & Cooling
My electric fireplace model # HEF33WDG, the heat works, but the flames dont move. Can someone help me.
go to ebay and put in electric fireplace heater parts, the flame motor is around 20 bucks, and the heater element around 50 bucks Good luck
Oct 21, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Gas fireplace will not stay lit
Feb 22, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Chicagao electric fireplace heater doesn't work
MY HEATER NOT WORKING,BLOWER AND LIGHT COME ON NO HEAT
Oct 25, 2008 | Heating & Cooling
Electric fireplace 39EB364GRS
do a search on the web for model of fire place.
Oct 10, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
