Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
Sound does not end
When i put on the tv or radio on i must turn off the whole computer to get raid of the sound
  • mustey_2005 Feb 02, 2009
    and if i replace the motherboard will it end
  • 62 Answers
Thats just because of the emi(eletro magnetic interferense ) your computer is generating no solution to the problem .The only way is to turn off or put the speakers of radio or tv as far as you can from computers also if it doesnt solve your householed wiring may have a problem of earthing
Posted on Jan 19, 2009
Recently I had replaced one of HDD of my DL580 service Raid 5 configuration. After that everything working fine including user connectivity and database access. My question is both the LEDs on replace
After you replaced the drive, did you rebuild the RAID array? Some of the higher end RAID controllers will try to rebuild automatically (if set to do so) but most must be rebuilt manually.
Dec 22, 2014 | HP ProLiant DL580 G5 (438087-001) Server
Blinking red light and beep sound coming from the front blade Slot 1.
That drive has failed, is it set up with a RAID configuration? Do you have the Dell monitoring software installed? Is it set up with Hot Plug drives? If so replacing the drive with a new one will start the RAID rebuild. Otherwise one way to turn off the bleep is to reboot and go into the RAID controller configuration
Dec 05, 2013 | HP ProLiant Computers & Internet
Storage Drive 2: Drive slot sensor for storage drive fault was asserted
Sounds like you have a RAID. Take a look at the RAID management software and see if the RAID is degraded. If it is degraded you probably have a bad drive on your hands. Replace the drive and the RAID should rebuild. If it is not degraded. I would turn the server off for a sec remove all the drives and blow out the RAID carriage. I tend to do this anyway on our servers every quarter to keep the system clean and cool.
Hopefully this helps.
Oct 18, 2013 | Dell PowerEdge T610 Server (bqdwe2k1
My main Raid device is critical and subsequently the computer won't start. The computer tries to start up but after advising the Raid 1 is critical closes down and tries to restart again. It messages to...
Your RAID device is specifying that it has no confidence in the data and subsequently won't show the disk to the OS. It's doing the right thing.
What you need to do is to get your RAID controller to force-mount the array. In this mode, it will just show whatever it can get from the disks to the OS. Boot from a live CD of choice and get the data off via network or USB. Each RAID controller has a different way to go about this, so you'll have to figure that out.
If your RAID controller can't do that, then you'll end up needing special software to do it. http://www.diskinternals.com/raid-recovery/ has a trial available that you can decide whether or not it's worthwhile
Sep 21, 2013 | Computers & Internet
Wont boot says array controller wont start and no bios dell power edge 2500 server
Sounds like the RAID controller has failed. I would replace this first as RAID controllers are less expensive than replacing the system board, or the server as a whole.
Suggested: PERC 5i (RAID 0/1/5) or PERC 5iR (RAID 1 or 0 only)
Jan 03, 2010 | Dell PowerEdge 2500 Server
I have a asus AV7 with a amd 64 bit processor 2 gigs of ram windows Xp Pro 7 dvd burners NEC 16x and 2 120 gig 133HZ.sata drives and 4 133 ATA hard drives 133 maxtor 120 gig configured in a raid stripped 0...
There is a glitch on those AV7 boards ata controler I think. Check the website for the new drivers supposedly they help, but all they did was crash my raid after I installed them. I ended up cloning the whole raid over to a single large sata drive and put in an ide to sata card (non raid unfortunately) and the problem went away. I only had the problem under very heavy disk loading. It seemed to not be quite so bad when I added some additional cooling aimed at the motherboard. As to if it will help your software problem I am unsure. However the only time mine did the mini dump was when I was doing heavy video editing work and after nixing the raid it fixed it, But then again a bad drive in a raid can cause that also.
Sep 10, 2009 | ASUS Computers & Internet
ACER Aspire M5620 System Serial Number: PTS860X0227410A4022700 I want to put windows XP on it but it has window Vista. So to put Xp on the computer i went into the bios and try to change the setting...
You cannot just switch from RAID to IDE!!!
This has nothing to do with the operating system!
It is a hard disk control and arrangement protocol for transmitting and storing data.
RAID: Redundant Array of Independent Disks
IDE: Integrated Drive Electronics
It is a hard disk drive interface and RAID is commonly used in servers for data redundancy and faster access. There are several versions of RAID. RAID Wikipedia
if you want to install Windows XP first of all set in the BIOS back to IDE (or simply choose default settings)
Start up your computer save any data you might want to save.
Reformat your hard disk (you will lose anything you had not backed up) and install XP presumably from a CD you have.
ultimately you can install XP and just tell her during install to reformat the hard disk.
Nov 07, 2017 | Acer Computers & Internet
Little dots all over the screen
Sounds like something might be heating up
you could get a can of freeze from radio shack and spay it on the ic's one at a time till the problem goes away to locate the bad part.
Oct 13, 2007 | Philips 60PP9202 60" Rear Projection...
Sound not recorded
You need an 1/8" male jack plug (both ends) cable. One end plugs to audio out on TV card, the other end plugs to audio in on the sound card. Or is it the other way around. Anyway, thats what you need. I think Radio Shack sells them maybe BestBuy or Circuit City.
Jul 02, 2007 | Philips SAA7130 TV Tuner/FM Radio/Video...
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
21 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
