I am seeking the WAP code so I can can connect the unit via wifi to the internet
  • 32,281 Answers
Network security key
Some later model wireless routers have the Password (ie.Encryption key) and the SSID already configured in the wireless router and this information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adapters in your computer/laptop.
If these settings do not suit you, then it can be changed to suit your requirements.
The encryption key secures your data and wireless connection from unauthorized access.To configure the wireless settings in the router, connect a LAN cable from your computer to the wireless router, then open a Browser on your computer and enter the router's configuration IP address, then enter the admin login and password and then go to the wireless settings and configure the SSID and Encryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2 key.If you use the Passphrase method select either WEP or WPA or WPA2 to generate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to 63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born in January 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop, configure the wireless card in your computer/laptop with the router's wireless settings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptops can communicate with your wireless router. http://www.fixya.com/support/r10267861-network_security_key
Posted on Jan 03, 2013
Why i can't connect my kyocera loft s2300 to the web
Your phone does not have WiFi connectivity. It is a WAP (Wireless Application Protocol) that offers limited Internet using a WAP browser. For more information on WAP topics:
What is WAP Phone with pictures
Dec 14, 2014 | Kyocera Cell Phones
My nokia 2680's-2 phone can't connect to internet.
Via WIFI or data connection, if WIFI check security key is in put correctly, turn off phone and WIFI unit, wait a couple of minutes and try again
Apr 15, 2014 | Nokia Cell Phones
Tablet connected to Wifi but does access websites
It looks like the wireless part of your wireless router is damaged.
If your friend's wireless computer/laptop cannot detect a wireless signal from your wireless router then this confirms the wireless fault.
Dec 04, 2012 | Computers & Internet
Unable to connect to the internet
First of all you should ensure yourself that your phone is able to connect to the Internet.
After that, you should make sure that your WiFi is enabled.If you are about to connect via 3gp or WAP, then contact with the company and ask if those services are enabled for your SIM card. Hope this helps :)
Dec 28, 2010 | LG Cell Phones
I have zyxel p-600 series router and i managed to connect to internet via cable (wired).then internet works on my ubuntu 10.04 but only when i write sudo dhclient in terminal. then internet works but i...
when going wifi
you have to go to internet connections or options in the control panel and click on the LAN settings button
the wifi modem will have a security code on the back and the wifi connection area code
click on the found area code on the back of the modem then enter the security code
Jun 04, 2017 | Zyxel Prestige 600WH Wireless Router...
How to make vista act as router? without using any outside router !! the inbuilt wifi syatem should act as router..
Yes well IF you use two network cards, a WiFi Adapter & an Ethernet Adapter, you can do this, now with a WiFi adapter, as you say, What you do is connect to the internet on the PC, and "Share" the internet connection via the WiFi. You set up the WiFi as either an "Access Point" or a an "Ad Hoc" network, if you want to communicate with the "Other" PC's, and have then communicate with you, as well as access the Internet. So setup is simple, using the manufacturers DVD install the WiFi. card, then, Set it up as you wish, the PC's that connect should be in the same Workgroup, have sharing enabled and be passworded too then as said connect to the Internet and the "Other" pc's will be able to "Burrow" out through you Internet, through the ADSL Modem attached to the "Main" PC. Usually via the Ethernet port. You still need to set up an SSID and use a WAP/WEP key for security. on the WiFi card.
Mar 08, 2010 | Microsoft Windows Vista Home Premium with...
I'm trying to connect to internet via wifi and it's asking for a device password. what is that? this is a d430 dell.
I suspect the device that is asking for a password will be your wireless router. Normally, the password, or key, is printed on a label on the side or bottom of the router.
Nov 21, 2009 | Dell Latitude D430 Notebook
Internet connection
hello there! thanks for using Fixya.com!
I suggest that you should contact your Network Service Provider. Usually, WAP application is already featured from your mobile phone but you should activate it the GPRS to access the internet. Please check with your Network Service to send you this setting manually or over-the-air!
This application WAP browser provides all of the basic services of a computer based web browser but simplified to operate within the restrictions of a mobile phone, such as its smaller view screen. WAP sites are websites written in, or dynamically converted to, WML (Wireless Markup Language) and accessed via the WAP browser.
Hope this will help!
Feb 16, 2009 | Motorola Mobility W230 Phone US with...
Problems with second computer connecting to the internet
First, is your kids computer trying to connect via the WiFi connection? If so, do you have any encryption enabled on the Belkin? (WEP, WAP, etc.) Can the computer 'see' the WiFi Access Point, meaning can it see the SSID (or WiFi name)? Are you using the Built-in XP Zero Wifi Config Utility, or did you install a proprietary utility from Belkin?
Since you have already soft reset the router (power cycle), you may have to do a hard reset using the Reset Button on the back of the router.. you will loose all your configurations, so be ready to setup your WiFi connection again..
Dec 19, 2007 | Belkin (F5D5231-4) Router
WiFi Cards and Dell
They allow you to use your PDA on a wireless internet network.
Sep 13, 2005 | Dell Axim X5 Pocket PC
 Grubhead
Grubhead
