Question about Panasonic KX-Mb3020 Multi-Function Laser Printer
Panasonic mb3020 error call service 2 - Panasonic KX-Mb3020 Multi-Function Laser Printer
How can I solve a service 12 error
Call Service 12 means that the color motor rotation detection signal (LD) does not go Low.
After the LCD indicates this error turn the power off/on & perform the motor test by pressing the MENU, #, 9000, *556 and press 2 & set buttons. See if this helps you with this issue.
May 24, 2014 | Panasonic DP-MC210 Color Copier
Call service 2
Call Service and Communication Errors are usually relating to an internal mechanical fault that needs to be addressed by a Authorized local Panasonic servicer.
You may try to reset the unit using code: [MENU] [*][8][0] [SET] or [START]
You may also call - 1800-211-7262 for Panasonic's capable Technical Support; be sure to have the serial number of the product ready.
Nov 07, 2012 | Panasonic KX-FP81 Plain Paper Fax
Call Service 2 Panasonic Error Kx Mb772
Well here I give you the manual with the full list of errors.
Panasonic KB-MBxxx Manual
Jul 06, 2012 | Panasonic Office Equipment & Supplies
Error code is call service 3 on the Panasonic fax kx-fl422
You need to contact Panasonic Service personnel to resolve any error code that begins with "call service." Please call or e-mail using the following contact information:
Obtain Product Information and Operating Assistance; locate your nearest Retailer/Dealer or Service Center; purchase Parts and Accessories; or make Customer Service and Literature requests at:
http://www.panasonic.com/help
E-mail Panasonic tech support via:
http://www.panasonic.com/contactinfo
For in Limited Warranty programming and Troubleshooting Support:
Office Advantage assistance and Service Location finder: 1-800-211-PANA (7262)
If the Limited Warranty has expired, contact Continued Services Technical Support Line at 1-800-435-7329, for fee based technical support. A credit card will be used to charge this fee.
Mar 07, 2011 | Panasonic Office Equipment & Supplies
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic sa -ak 27
This is a common error for these Panasonic units. I work at an authorized Panasonic service center and have repaired many of these.
This error is caused by either 1 of these 2 problems, both of which will require service for replacement of parts.
1. The amplifier IC is bad and needs to be replaced.
2. There are a couple of smaller components in the amp circuit that need to be replaced. One is a zener diode and the other is a resistor.
The F61 error is caused by a bad amp circuit or power supply circuit. In most cases it is the amp circuit. More often than not, it is the zener diode and resistor that are bad. This would be preferable since the amplifier IC is very expensive and a total repair cost would be close to $200. The zener diode and resistor repair would be closer to about $100 depending on the rates of the service center.
I know this may not be the answer you were hoping to get, but it is the problem you have.
If you found this information helpful in making a decision on what to do with your stereo a FixYa! rating would be appropriate and very much appreciated, after all, it is the only reward we get for offering free help to people like yourself.
If I can be of any further help just reply to the post and I will get back to you as soon as I am able.
Good luck with your stereo, I hope you found this information to be helpful.
Dave
Sep 05, 2008 | Panasonic SC-AK17 Shelf System
Panasonic fax KX-FT73
I THINK THAT IS MECHINACIAL PROBLEM .CHECK DEEPLY ALL SENSORS AND ALL GEARS .ANY MISHANDLING IN MACHANICAL.mian akhlaq
Aug 07, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-Mb3020 Multi-Function Laser Printer Logo
60 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
