Question about Intimus 385 se Shredder
Broken teeth on drive gear wheels Taros paper shredder Taros 31.8
Need to purchase two replacement 11.5 cms gear drive wheels for above paper shredder as teeth are broken on both. Used parts ok if serviceable.
  • 35 Answers
New gears are $88.50 plus freight. You won't find any used gears because these usually break first. I can help.
Posted on Feb 23, 2009
Runs but doesn't feed paper and shred
Hi, If the shredder teeth / cutters arent moving, then there is most likely a broken/stripped gear or a gear with broken teeth.
If the cutters are moving, then look to see if there is something obstructing the entrance slot where you place the paper.
Good luck.
Mar 12, 2015 | Office Equipment & Supplies
My paper shredder will not shred or grab the paper?
If the motor is spinning, it's probable broken teeth on the drive gear. The drive gears are usually the first thing to break on a shredder.
If the motor doesn't spin. The paper may be clogged in the grinder claws. You may have to turn the shredder over (after you remove the power cable from the wall outlet). Then remove the papers from underneath.
Hope this helps.
Feb 28, 2015 | Shredder Office Equipment & Supplies
My shredder has the sound like it is working, but it is not shredding.
From your description, it sounds like when you insert the paper the motor turns on, but the paper is not pulled into the shredder, indicating the two shredder cylinders are not turning. The most likely cause of this is a stripped (missing teeth) main nylon gear. These can be replaced but require some effort.
Apr 17, 2014 | Royal Office Equipment & Supplies
Thanks! I have a 7x Crosscut Paper Shredder, Model # PCUA:29053U. The teeth are jammed due to I believe a build up of paper. I have run it on reverse & tried to pick out the paper. The motor runs but...
If the motor runs but the cutting teeth dont turn then you have stripped or broken a gear in the drive train. You can get replacement parts from Royal at 1-800-524-0799.
Oct 19, 2010 | Royal Office Equipment & Supplies
RE; Durabrand Paper Shredder. Model Number WM6X. The motor works in reverse mode only, but the blades don't turn, Help
You have broken gears. Call customer service at 800-327-8508 and they will send you 2 gears for $10 including postage. I got mine in less than a week. Easy install.
Nov 05, 2009 | Office Equipment & Supplies
Where do I get a gear to turn the shredder
Her
Date: Thu, 9 Jul 2009 11:16:33 -0400
Subject: TS4500 from Winsource Ind.
To:
Rick,
This TS4500 shredder had been discontinued for more than 5 years. The factory did not make any spare parts for this model.
Thanks,
Victor
Customer service
e is my response
Mar 22, 2009 | Tech Solution TS-4500 Shredder
Office max paper shredder
You need to find out who made the shreddr, Fellows, GBC, etc. parts are available to brand name machines...
Jun 03, 2008 | Office Equipment & Supplies
Shear pin ??
You most likely have several teeth broken off the drive gear that drives the cutting block. Not too difficult to replace but you need some special tools. A deep well socket (I think it's about a 3/8") to remove the cutting block and replace the broken gear. The gear should be available from a Fellowes dealer, or they might sell it to you direct if there is no dealer near you.
Let me know if this helps.
Aloha,
Bill Monroe
Oct 15, 2007 | Fellowes 220C-2 Shredder
Intimus 385 se Shredder Logo
1,113 people viewed this question
Top Intimus Office Equipment & Supplies Experts
ray gallant
Lonnie Arks
misterpj2u
Are you an Intimus Office Equipment and Supply Expert? Answer questions, earn points and help others
