Question about Lowrance LC X-15MT Sonar
Sonar Problem I can't get my sonar to come up.
Try a soft reset first, if that doesn't correct it try a hard reset. BE SURE and Save Data before th eHard Reset, it clears all waypoints and such.
Soft Reset Hard Reset
LCX 15mt Reset 1. Turn unit OFF 1. Turn unit OFF 2. Press and hold the PAGES key 2. Press and hold the ZIN&ZOUT Keys at the same time 3. Press and hold the PWR key 3. Press and hold the PWR key 4. Release both buttons when the USA map appears 4. Release both buttons when the USA map appears
Posted on Aug 29, 2008
How do i disable the depth sonar
There is a selection either under sonar options or the main menu sonar tab that allows you to turn the sonar off. Article Details
here is a link to Lowrance to download your users manual in a PDF format.
Oct 17, 2014 | Lowrance Elite-4 DSI Combo with 455/800kHz...
Intermittent sonar ping
sonar on a pc? now i've heard everything
1st level solution
respond with the actual model number of this hp
describe this sonar ping and where it is coming from
Jun 13, 2012 | HP Computers & Internet
Need serial number to sonar home studio 7
It is something you get when you purchase the software. If you have already purchased the software, contact Cakewalk support for assistance.
May 28, 2012 | Cakewalk SONAR Home Studio 7 XL for PC
Trying to find the manufacturer of My Sonar hearing aid. On the box it says 3m Tecnology but not who makes it. Are they still in business? Thank You.
Sonar was a 3M spin off. Sonar was then purchased and merged with Resound Hearing Aids out of California. Sonar was officially closed in 2008/2009. I would contact ReSound Hearing Aids and see if they can fix it.
Jul 29, 2010 | 3M Health & Beauty
Computer stops responding or sound just stops on Sonar 7 with Vista. Confused whether to set Sonar to use ASIO driver or MME or the other one I can't think of now. Dan
Hi
The most compatible driver would be the one detected by Vista in Windows Update. Give that a try and see if it can find a hardware device driver for the Sonar. Ensure the Sonar is connected and on before you check for updates (Start > All Programs > Windows/Microsoft Update).
Oct 11, 2009 | Tascam US-144 Sound Card
I downloaded a sonar cakewalk program to my computer but there is no sound. How do i fix this?
First check your speakers with any media player. If this sounds OK then keep the volume level up/same sothat you can hear any sound from speaker. Now Check the input & output devices in sonar (Select the appropriate device). Put any audio file in a track in Sonar & check...
If you are not a regular user of Sonar then it is better to switch to another DAW which are better (at least in my openion) before you are used to Sonar.
I'd suggest "Nuendo" of Steinberg, it is highly professional, far better & far more user friendly than Sonar. I've used both...
Aug 16, 2009 | Cakewalk SONAR 4 Producer Edition for PC
Me and some buddies record with sonar home studio 6 and i bought a new pc custom built for recording well our computers on tha same day and time started having problems with sonar popping and glitching...
Sounds like what is called a latency problem. You need to go into the settings in Sonar and under audio, adjust the Latency to a higher number...I don't know sonar home studio, or I would tell you the exact area to go in the menu's to adjust latency..Hope this helps!
Mar 06, 2009 | Cakewalk SONAR 4 Producer Edition for PC
I have a recording software called Sonar 6 and every time i try to start it, i get an error message saying "sonar has stopped working". I have had the software for a few months and it's only just...
HAI,SONAR 6 SOAFTWARE WORKING PROPERLY IN THE MIDDLE IT'S NOT WORK OR FIRST YOU HAVE INSTALL THE SOAFWARE THAT TIME WILL NOT WORK.ANY WAY UNINSTAL SONAR AND REINSTAL IT'S WORK FINE.
UNINSTAL :
START>CONTROL PANNEL>ADD REMOVE PROGRAMS>SONAR>REMOVE.
RE-INSTAL :
DOUBLE CLICK FOR EXE SETUP PROGRAM FOR SONAR>SELECT TARGET AREA(DEFAULT C:\)>FINISH.
RESTART SYSTEM AND USE SONAR.
Jul 05, 2008 | Computers & Internet
Boating Logo
554 people viewed this question
Top Lowrance Boating Experts
dduncan54
dduncan54
Level 1 Expert
Phil Walker
Phil Walker
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
