Question about Raritan 17in lcd cat 5 kvm swch 8pt opt 2nd user tmcat1728
Raritan tmcat1728 8port password reset - Raritan 17in lcd cat 5 kvm swch 8pt opt 2nd user tmcat1728
Raritan icerette model 84.
Make sure you have it in a cool area. also make sure the door gaskets are sealing good if warm air is penetrating the box it will keep it running. also make sure cold control is working properly if it is not sensing a cold enough box it will keep if running.
Oct 13, 2014 | Raritan Icerette Automatic Ice Cube Maker
D2CIM-VUSB can use USB 1.0?
They should work, but I would use the PS2 connectors to be sure.
May 15, 2014 | Raritan Computer KVM Extenders...
I need rest i tried backside rest button but icant
Press and hold the reset button for about 20 seconds, it should reset.
Dec 27, 2012 | Raritan Computer DKX2-108-PAC - Raritan...
Raritan SW2USB. Has been working for several years. Today started normally, but suddenly the keyboard was not visible to the switch or either computer. Checked cables, rebooted, etc. Bought a new keyboard...
It sounds like the main switching IC on the board has gone bad...seen it happen before.
Your best bet is to replace it, I would check on Ebay for a good replacement a little cheaper than retail
Aug 20, 2011 | Raritan CompuSwitch CS2 (CS2-PENT) 2-port...
My icemaker will get cold but wont make ice.
Hi and welcome to FixYa, I am Kelly
Here is what the manual says:
3. Icer-ette freezes but water does not come into mold; no ice production.
_____________________________________________________________
3A. Nonfunctioning water valve assembly. 3A. Clean or replace solenoid valve assembly.
3B. Mold heater assembly. 3B. Contact Raritan Technical Support.
3C. Water supply turned off. 3C. Provide pressurized water.
3D. Icemaker module. 3D. Replace icemaker module.
3E. Cold control. 3E. Replace cold control.
3F. Bad wiring harness plug contacts. 3F. Contact Raritan Technical Support.*
Although this is for troubleshooting non optical sensor refrigerators:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
The troubleshooting procedures for cycling the unit are exactly the same,
The ice maker module part number for the 120V unit is PN 628366 (do a net search for this part number and save yourslef a bumch of money if you fetermine your moduleis bad) You start the harvest cycle by removing the front cover and then jumpering test points T to H. The white dial will begin to move if there is power to the module. Remove the jumper when the sweep arm reaches 5" o'clock and let the ice maker automatically cycle. It should harvest, and fill in on complete turn of the white dial. If it does not fill you probably have a water supply or water valve problem. There is an inline input power fuse for the ice maker. Power should come in via the red wire.
Mind you the ice maker has an internal thermostat behind the module assy that has to reach 15 deg F to start the harvest cycle. When you jumper T to H you are bypassing the thermostat. If the thermostat fails or the unit does not reach 15 deg F then the harvest cycle will never begin.
Thanks for choosing FixYa,
Kelly
Nov 25, 2010 | Raritan Icer-ette Ice Cube Maker
UMT242/USTIP2 not accepting remote clients, local only
I do not know this particular IP KVM but most IP KVM's use SIPPs that must be updated on the KVM when they are attached to the servers. Look for an option in the admin tools that say update SIPPs or update connection. You may also just have to double click on the list of connections to get it to update. This may have to be done at the console and not via remote.
Dec 18, 2008 | Raritan Paragon UMT242 (p2-umt242) 42-port...
ViewSonic VG900 and Raritan Paragon KVM won't play.
hi there, yes, go to safe mode first, then adjust the resolution to the lowest and restrat the unit. then you will boot up for a lower resolution and adjust it to your desire resolution. note that don't set it to higher resolution it will go blank again. ty
Feb 18, 2008 | ViewSonic VG900 19" Flat Panel LCD Monitor
Raritan 17in lcd cat 5 kvm swch 8pt opt 2nd user tmcat1728 Logo
Top Raritan Computers & Internet Experts
Mike
Are you a Raritan Computer and Internet Expert? Answer questions, earn points and help others
