Question about ASUS U46E-BAL6 U46E-BAL7 U46E USB External CD-ROM Drive Black
I need to boot from dvd player, but windows does not recognize it.
I have a newer Asus, After doing a HD defrag, I can't get the DVD player to work. I have uninstalled driver and reinstalled with no results. Also I have changed the Bios to boot from DVD and run the recovery, but still will not work. Help
  • 256 Answers
SOURCE: New ASUS A8V-MX motherboard will not boot to CD or HD with XP
The first thing is to make sure that your CD/DVD drive has the windows disk in it. Also check drive C which is where the windows will be installed. It may require that it is hard formated. Hard formatted means "format x /u" [format-space-drive to be formatted-space-right slash-u]. This will place the drive for "windows xp sp2", all of it, to one pass of zeroes. So, once we have a clean drive C and the installation disc is inserted into the CD/DVD drive, you may proceed to install. You will need to find "install" or "setup" and start it on he "RUN" mode. Any questions or help get back to me. CONSTANTIN (arzconst)
Posted on Jun 25, 2009
  • 355 Answers
SOURCE: asus quietrack dvd drivers can't run movie dvd
check the dvd are scrach or not
Posted on Oct 02, 2009
  • 67 Answers
SOURCE: Asus P5KPL SE & Sata, Bios "Not Detected Problem"..
The Asus bios won't show SATA devices.
However if you are using Windows XP with Service Pack 2 (or newer operating system then the devices should be detected. If this is not happening then enter the bios -- Storage Configuration -- Configuration Enhanced and set the IDE devices to compatible. This allows all drives to be "seen" and you should then be able to load an OS.
Posted on Jan 23, 2010
  • 111 Answers
SOURCE: my cd rom driver doesn't install
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Posted on Apr 01, 2010
rcw1962
  • 2571 Answers
SOURCE: HOW TO USE THE ASUS F3E RECOVERY DISK TO
Pop back into the bios and make sure the boot order is correct (cd first), and make sure that you exit and SAVE.
Look out for the press any key to boot fron cd.
If no luck, can you try the disc in another computer to see if it is bootable
Posted on Jul 19, 2010
Testimonial: "I'v not got there yet , but every bit helps "
19 boot loader
Hello here is the homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=M2A-VM&p=1&s=24
Try to download the manual, by selecting your windows system.
Open the manual folder, and click on global for download.
Adobe reader, is needed to read content.
Check the bios boot settings for booting, from the dvd drive.
Dvd must be the first boot device, and hard drive the second
I have newer heard of a boot loader.
Good luck
Jan 25, 2013 | ASUS M2A-VM (0610839149438) Motherboard
Asus a8n-e m/b gets power, will not post
Hello from here you can download a manual and drivers:
http://www.asus.com/Motherboards/AMD_Socket_939/A8NE/#download
My guees is that the windows disk is damaged or burned to fast.
Since you not get any picture on screen now the graphic card. maybe malfunctioning try to change that and see what happens.
A ps2 keyboard and mouse must be used.
Because the usb function will not work until the system is fully installed.
A restore disk does not contains a full windows its only for repair
purpose.
Good luck
Nov 02, 2012 | ASUS A8N-E Motherboard
Won't recognize windows 7 upgrade dvd
sooooo you tried to boot from it, and it is not ?
or
you have booted to windows and have put the disk-in and cannot access it ?
Sep 03, 2012 | Computers & Internet
Asus x53u e drive recognized but no working
So you click on the e drive icon and the drawer opens so you can put the dvd in, then you get a message that it is not recognized? The million dollar answer is: It sounds like the DvD is not recognized. Where did you get the dvd that you are trying to play? Did someone make it for you or is it a store purchased dvd?
Computers have problems sometimes with dvd's that someone else made. Maybe the computer is telling you that the DvD Format is not recognized.
Try downloading the VLC Player and see if you can use it to play the dvd.
Try using VLC as your player. Go to www.google.com and in the search box type "download vlc" (without the quotes). Look for the Video Lan download from site www.videolan.org/vlc Download and install it. It downloads and installs in 3 minutes or so. It's a very fast player, smooth and it can play just about any type of dvd formats and media. It's totally FREE.
Jun 02, 2012 | Computers & Internet
Can't read DVD+R that were recorded on LG-DR389 on my PC / Laptop DVD
The DVD+R is the older version that was used, all newer ones use the DVD-R now, your problem is the disc is not recognized in the other players because of the different format.
Mar 18, 2012 | LG Televison & Video
Hp presario f700/f750us, cd/dvd player, won't boot from start up but is listed first in boot order, not recognized by windows either, won't read, write or play. tray opens and light blinks. tom...
Check the jumper settings in the back of the drive, by the power cable. Make sure your cd/dvd drive is set to SLAVE, with your primary harddrive as MASTER. Check BIOS settings, specifically your boot order, choose which drive you want to load first (usually HD 0), save and exit.
That's just the basics, though.
Another possibility is that you might just have a paperweight ;)
If so, try another drive.
Hope that helps
Cheers from NZ
May 17, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
Asus Eee pc 904 hd how can i reformat my computor to original factory settings
Do you mean to ERASE everything on the hard drive and then re-install the OS and all the drivers from scratch?
Before you do any of the follwing, be ABSOLUTELY SURE that you have access to the drivers you'll need for your computer. If you don't have access to the original CD/DVD, you can download them from here:
http://www.eeeguides.com/2008/03/asus-eee-pc-drivers-download-windows-xp.html
You will also need the SERIAL NUMBER or "PRODUCT ACTIVATION KEY" for your copy of Windows. If you have misplaced this, you can try the following program, which will read the product activation key from your HD:
http://www.snapfiles.com/get/rockxp.html
There are several programs out there to erase the contents of your HD and re-format it.
A) One option is to use your OS CD/DVD:
1) Place your OS CD/DVD in the CD-ROM and boot from it (you may need to change something in your BIOS so that the computer does not boot from the HD.
2) After the CD boots, choose "install OS" (do not choose "repair installation").
3) You will be asked if you want to DELETE the partition in your HD that has your OS. Choose "YES". This will delete ALL information previously stored in your HD.
4) Proceed with the OS installation, following the directions on the screen.
5) After the OS is installed and your copy of Windows is validated, install all the drivers
YOU ARE DONE
Please, report back if you need further assistance
Mar 28, 2010 | ASUS Eee PC 900 Notebook
Jun 03, 2009 | ASUS K8V-MX Motherboard
Dell CD/DVD shows up in 'My Computer' but doesn't recognize CD's
the cd player could be bad it doesn't seem to be reading anything. or your windows needs reloading because you have other programs overwriting each other and windows.too much on the drive defrag it
Dec 27, 2008 | Dell Inspiron 2200 Notebook
ASUS U46E-BAL6 U46E-BAL7 U46E USB External CD-ROM Drive Black Logo
27 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
