Question about Imation 4GB DEFENDER F100 FLASH DRIVE USB (51122278013)
How to disable write protect in my imation nano 4GB
I cannot reformat it, it always say it is write protected. There are some hidden files that i deleted before, it was still there and its size has gone large.
  • 1 more comment
  • joelv3053
    joelv3053 Jan 14, 2013
    I've tried formating but still the message "The disk is write-protected" came up. Is there any other way
  • Justin
    Justin Jan 14, 2013
    Open "Computer" before plugging in the device. Plug it in. If you see two devices show up, one with a CD symbol and the other with a drive. Don't try opening the CD one, this is a read-only cd emulator on your flash drive. You cannot write to this nor make it writable. If this is not the case check the USB drive for a physical lock switch and unlock that.
  • joelv3053
    joelv3053 Jan 15, 2013
    The usb drive does''nt have a physical lock switch. I can copy the files but I cannot reformat it..
  • 2,072 Answers
Just format the drive. The hidden files are the trash folder.
Posted on Jan 14, 2013
My imatinon nano usb 4gb now only 1 mb what should i do?
I'd go into disk manager, delete any partitions and reformat the flash drive.
Dec 23, 2012 | Imation 27102 4GB Nano USB 2.0 Flash Drive...
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
1. i have problem with my pc that is file protection is not disable. 2. i can't format my usb flash drive 4gb.becoz it is write protected. i can't remove write protection in regedit. plz help me.
Is there a hardware swich to give write protection? Any files or programs on your stick open? A restart can often solve most write protection bugs.
Mar 13, 2011 | Computers & Internet
It always shows disk is write protected.
There is a switch on the back on the card. to disable write protection, simply move the switch in the opposite direction.
Feb 28, 2011 | Kingston 4GB Secure Digital High Capacity...
I have an imation 4GB nano usb, which just stopped working and i cannot format it because it's write protected.
If you plug it in and it shows up, right click on it from "my computer" (windows) go to properties and you should be able to uncheck the "read only" box. click apply and you should be able to format it... I think.
Jan 08, 2011 | Computers & Internet
I am trying to format my imation m 4gb usb but the error comes as write protected.where in i am not able to even delete files from the drive
what you can do is, make your write protected drive "shared", that means go to my computer---> then rigtclick on flash drive---> click sharing & security---> check both "share this folder on network" & "allow users to change my files" ,apply setting then you'll be able to format your drive.
Note: In the future never unplug it before clicking on safely remove device.
Nov 27, 2010 | Computers & Internet
Cancel ''write protect'' on USB memory stick
If no physical switch, then check the software that came with. Some sticks have a software component that recognizes when you plug the stick in and gives you options for viewing and launching applications from the stick. There may be controls you can use to change the write protect.
If not, or you can also try, opening a view to the stick from Windows Explorer and just delete files from there as you would from any drive. Windows will prompt you to confirm delete. I wouldn't delete any auto-load or setup apps that would be used to connect to another computer.
Oct 05, 2009 | Computers & Internet
I had run imation lock on kingston 4 gb and now its says "Please insert the device or run this"
its a little tricky, just try it
  1. unplug ur usb drive
  2. double click the imation lock
  3. when the message appear "Please insert the device or run this utility as privileged user" plug the flash/usb drive quickly
  4. USB will start working
  5. run the imation lock again and disable the password protection
  6. delete the ugly imation lock from ur system
i hope u find it use full, plz give ur feed back at: masood@inbox.com
Jul 28, 2008 | Computers & Internet
Problem regarding the write protection of pendrive
sir,
i am not able to delete files from my pendrive nor am i able to format. every time i try to delete or format, a window pops up saying that ur pendrive is write protected
Sep 03, 2007 | Computers & Internet
Imation 4GB DEFENDER F100 FLASH DRIVE USB  (51122278013) Logo
1,022 people viewed this question
Top Imation Computers & Internet Experts
Raj Patel
carey w mason
carey w mason
Jax Planet
Jax Planet
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
