Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
We heard a loud gushing sound and the dishwasher leaked all over the kitchen floor. Why?
  • LG Master
  • 32,281 Answers
The drain hose may have disconnected from the dishwasher or at the waste trap or the drain hose maybe broken.
If the drain hose is OK then the water supply hose may have disconnected from the tap or the water hose is broken and fresh water is leaking from this hose.
Posted on Jan 03, 2013
I have an older model Bosch dishwasher, model SHX46B, serial 830300124, that is leaking while not in operation. It's a very slow leak, and I think I heard and saw a drip from the upper spray arm. It fills...
Hi.
Sounds like a leaky inlet valve. Sometimes they don't seal off completely or the membrane inside it could be torn. Best to replace the whole valve.
Regards Sam
Sep 30, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
When running my dishwasher it overflows and leaks out onto my kitchen floor. Had a plumber in and identified that this issue is not with the plumbing as there are no other issues to the sink.
sounds like you should check the rubber gasket around the door. if it is torn or ripped it will leak. hope this helps.also make sure where the rubber meets when you close the door that it is al clean from dirt and grim. have a nice day
Jan 14, 2011 | Maytag Dishwasher
The 2 metal "clips" that secure the dishwasher to
door gasket possibly bad or another leak. Stop using dishwasher until repaired or you're likely to ruin your floor. I just had this problem before we found a leak and now we may have to replace the kitchen flooring.
Order new clips or the dishwasher could fall out onto the floor or even onto your foot.
Nov 16, 2017 | LG LDF6920ST Stainless Steel 24 in....
Water leaking under floor when dishwasher runs
check the water to the unit it is locate under the door open the panel 2 -4 screw take flash light turn the unit on and see where the water come from ... it might be also from under your sink.
Jan 01, 2010 | Dishwashers
Water leaking out bottom of dishwasher door onto kitchen floor.
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Mar 02, 2009 | Kenmore 15762 Dishwasher
Bosch Dishwasher 6805 leaking
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
uoioy
Feb 20, 2009 | Bosch 24 in. SHU6802UC / SHU6806UC...
Kenmore ultra wash 665.16761690
If it is not overfilling, and then leaking, the whirring noise can be a defective water inlet valve, that stays stuck on open, see here : It's overfilling
If it is not overfilling, the two problems may be unrelated, and the noise can be froma foreign object inside the object trap.
See here about leaks and noise
It's noisy
It leaks
Oct 08, 2008 | Kenmore 16919 Built-in Dishwasher
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
80 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
