Question about Nokia N76 Cellular Phone
MY NOKIA CELLPHONE DIDNT WORK PROPERLY
MY PHONE IS CHARGING BUT THE INSIDE SCREEN IS BLINKING AND THE WIRING ARE LOST TREND WHERE WILL I GO TO FIX MY CELLPHONE
    Master:
  • Nokia Master
  • 520 Answers
Hi:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Jan 03, 2013
2 Suggested Answers
SOURCE: My Nokia 2310 suddenly switched off. It didnt switch on again.
I tried putting the battery(of problem phone) into another cellphone, the battery works fine.
I tried to charge the problem phone, but is not showing any activity upon inserting the charger jack. Other phones are getting charged using the same charger.
Any idea of what the problem could be?
Posted on Nov 17, 2008
My nokia x3 wont charge properly. i got the battery changed twice and also got a new charger, but still it wont charge completely. as in, till its connected to the charger it will work, but when it is...
Good day. if you have tools with you, check first the charging pin at the side of the phone unit, sometimes its the PIN inside not in proper position, or check the terminal IC of the charger. But if you cant handle this problem by yourself, i might suggest you must go to your nearest cellphone personnel at your area, coz its too complicated and it required a proper tools. thanks
Sep 11, 2011 | Nokia X3 Cell Phone
Nokia n76 charging uk. but switch on time only blinking lcd
the system of your phone is corrupted, you must bring it to a cellphone technician who have a knowledge on reprograming cellphone.
Jun 30, 2011 | Nokia N76 Cellular Phone
How do I switch my Nokia E63 cellphone on
To switch on your nokia e63 phone, press and hold the red button also know as the end call button for a while till it responds.
Ensure the battery is properly inserted inside the phone. And well charged.
If it does not come on, ensure the phone is charged for some time before trying. and if it still does not come on it means there is a technical problem and you need to seek professional assistance from an expert.
Take care
Oct 12, 2010 | Nokia Cell Phones
I dropped my nokia 6303 and screen not working now. Phone still works but cant see who's calling. Can it be fixed?
hi,
yes it can be fix ,but unfortunately not by you..beacause its a sensitive case...go to a cellphone shop to repair your lcd connector first ,that lcd connector connects the lcd or glass display to main board of the cellphone ,if it is damage or lost of contact you cellphone display is not working...second try to replace a new and good lcd before going to the last option ,which is the display driver of the phone...the display ic is a small components that makes the lcd functioning..
the above solution must be doing by an expert mobile technician and its step by step procedure must needed to prevent bigger damage in your phone..
i hope it will help you ,thanks for trusting fixya..
Jun 19, 2010 | Nokia 6303 Cell Phone
Problem charging my Nokia 7610 cellphone
1. try to check if your charger is working or not
2. if charger is good.then try to replace the charging socket of your phone.you have to open it,but if you dont know how to do it.you need to go to a technician to fix it for you rather than taking the risk.
Apr 11, 2010 | Nokia 7610
Blackberry pearl 8130. screen wont come on.
To help you with this problem, I want you to know that when a cellphone got fell, the main problem will be make is lost in display,you will not see anything but you can hear something like message tone and start-up tone, you can also receive calls. Don't be worry with that kind of problem. To tell you whats happening inside your phone is your LCD of display connection is only misaligned. Get it to the nearest cellphone repair center to get your cellphone to be open by a technician and probably they will do dismantling your phone and fix the problem. Hope this could help. Don't forget to say thanks..:-)
Oct 28, 2009 | RIM BlackBerry Pearl 8100
My phone fell and now the screen is blank at first you could not see anything but you could hear when it rings now you don,t
To help you with this problem, I want you to know that when a cellphone got fell, the main problem will be make is lost in display,you will not see anything but you can hear something like message tone and start-up tone, you can also receive calls. Don't be worry with that kind of problem. To tell you whats happening inside your phone is your LCD of display connection is only misaligned. Get it to the nearest cellphone repair center to get cellphone to be open by a technician and probably they will do dismantling your phone and fix the problem. Hope this could help. Don't forget to say thanks..:-)
Oct 25, 2009 | Nokia 2610 Cellular Phone
My Nokia 2310 suddenly switched off. It didnt switch on again. I tried putting the battery(of problem phone) into another cellphone, the battery works fine. I tried to charge the problem phone, but is not...
Jul 29, 2008 | Nokia 2310 Cellular Phone
My phone restart automaticly pls help
for the cellphone automatically switched off the problem is the switch,if there is one who look anf fixed that cellphone but he did not fixed try to consult to another cellphone technician maybe it will fixed.
Jun 07, 2008 | Nokia 3230
Nokia N76 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
