My AKAI Digital Integrated Amplifier Model AM-M659 stopped working. there is no sign of power anywhere. the power cables are okay. Not sure about the power supply / transformer. I need help to solve the mess.
  • 5 Answers
SOURCE: akai lct3201 ad power supply
Hi doonz75
I got same problem with MLT169A power supply it wont power on. but i found service tech who fixed my power supply. but he stays in toronto, canada. only thing is you have to pull power supply out and mail it to him. his email is jah2mil@hotmail.com
Posted on Apr 08, 2008
  • 2318 Answers
SOURCE: Need help finding an Akai LCT2701TD Power Supply Board Assembly
It seems like there are not many of these service parts available anymore. The only way to get your LCD working again will be to repair it.
The repair involves changing the defective parts to restore the LCD functionality.
If you need more info, you can write to jah2mil@hotmail.com
Posted on Jun 16, 2008
Ajkill
  • 2035 Answers
SOURCE: akai PDP4247-L PLASMA main power supply module
Yes there two power supply unit one for the main power supply is used for the plasma screen which helps to display the image on the tv screen ,So you need to replace the main power board did they say they have it??
Posted on Sep 08, 2008
SOURCE: Remote Control Programming
GE Universal remote only $12.00 at Target works on my Akai LCD HDTV, this remote also has learning capability but the third code under Akai worked!!!
Posted on Mar 17, 2009
SOURCE: My MLT386Y power supply in AKAI LCT37Z6TA burned out and I bought
where can I find amlt386y power supply? and how much?
Posted on Apr 12, 2009
Power light is lit, but there is no sound coming from the speakers , it was working fine and just stopped working ?
Its an PA amplifier and i think this is build with an integrated powerpack IC output stage,
There are different TOA amps but if this model look first the fuses if that are (important)measured defect give a new fuse a try if it blows again there is something wrong in the cables or a speaker conection or filter , ut if the fuses are good there could be an single great brown or black colored IC with STK (....)A or B or something similar is to read on it on the great heatsink inside the amplifier that could be having 15 or more legs must be replaced , BUT also some capacitors thats belong to the output stage because every defect is having a cause.
It think this amplifier IC should similar be looking like this
Aug 05, 2016 | TOA Electronics - P-924MK2 - 240 Watt...
How do I connect this system together to get it to work?
The manual for the amplifier and all the other units are here. Use the search feature in the top right with just the model number 'AT-5210'. Getting the items in the right order helps. The turntable obviously goes on top. The Amplifier goes in the middle and all the other units connect to the amp.
Akai AM U61 Manual Stereo Integrated Amplifier HiFi Engine
Jan 14, 2016 | Audio Players & Recorders
How do i get a free service manual download of a kenwood ka-127 model stereo integrated amplifier in any digital format?
I doubt you will be able to find a digital copy, and Kenwood dropped their home audio line 2+ decades ago. I probably have a hard copy of the manual, as I was a Kenwood Factory Service Center for over 25 years, however, it is not free. If you would like more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 11, 2014 | Audio Players & Recorders
Akai dp4006
make sure the audio output format to optical or coax is set to either pcm(pulse code modulated) or dolby surround 5.1,6.1 7.1 etc. for both dvd and amp........may be in user menu for both......meder's tv service
Nov 10, 2013 | Televison & Video
Kenwood Stereo integrated amplifier A-58
hi i have bought kenwood hi fi with following parts -
integrated amplifier - A-58
cd player - DP-M58
stereo receiver - T-58L
twincassette player - X-58
turntable - P-38
but I can't get owner manuals from anywhere. Can you help me with it please ? marek922@vp.pl
Jun 29, 2012 | Kenwood Audio Players & Recorders
No signal using signal cable for some channels.
Some televisions, like some radios are more sensitive to signals than others.
If you are not using an antenna amplifier, adding one may help. I happen to be using an old antenna amplifier that was around during the days of analog and it works fine on digital. Plus I am about 75 miles from the nearest TV transmitter so I need to use one. They just simply have one input (from the antenna) and one output, (to the TV) and a power plug. There is not much to them.
Also checking the coax cables to make sure they are snug, they do not need to be torqued in footpounds of torqw, just snug. If you have the slip on kind, gently bend in one edge of that outer lip to make sure good contact is made as they will lose tension over time.
You should have no problem with satellite or cable if you add either in the future as those use a different input in most cases.
Dec 14, 2011 | Televison & Video
JVC AX-66 Integrated Amplifier seems to be muted?
You need to have a jumper between the 4 standalone jacks on the right side of the column of stereo connectors. A stereo RCA cable would work for this.
Oct 14, 2009 | JVC Audio Players & Recorders
HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
this is a good one i had the same problem about a year a go on my brothers we tried every thing nout worked i said put the video leads in and do it it worked a treat but i have herd it don't work for all so it sounds like an amplifier my be needed hope any of this can help you. sorry if it don't only trying to help
Oct 11, 2007 | Akai LCT2785TA 27 in. LCD Television
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
Electro Med Services...
