Question about Kenmore 22422 Top Load Washer
Kenmore 90 Series
The agitator at the bottom is working fine... the one at the top is loose and will not "grab" to keep form spinning backwards. There is no hold on it to keep it only going in a clock wise motion. It can spin counter clockwise motion. I believe everything else is working perfect.
  • 5,911 Answers
The agitator has four small teflon (I believe) plastic grips inside the upper portion called "agitator dogs". They have small teeth on them to grip the inside ring of the agitator. You can replace them for less than $10 for a pack of 4. Your local appliance repair shop should carry them, or be able to order them for you. Let me know if this helps.
Posted on Jun 27, 2007
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Washer
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
Kenmore 90 series agitation problem
suppose to not spin unitl the lid is closed( safety reasons) the reason for the "weak agitation " is a bad set of agitator dogs. by removing the center fabric softener cup, you can get to and unscrew the center shaft bolt7/16. after removing the bolt, the agitaor will remove and the agitator dogs canbe replaced. part number 80040.youll need to split the agitator top and bottom to insall them . they simply slide into place.
Feb 14, 2009 | Whirlpool LSB6200PQ Top Load Washer
Tub won't agitate and when it does spin, makes a grinding noise.
its probably in the gear case. or spin tube bearings. did you see any oil leaks on the gear case or clutch and break area.
Feb 07, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator spins in one direction
The purpose of the upper portion of the agitator is to push the clothes in a downward motion. As the agitator moves the dogs grab and on the backward srtroke the top portion rotates a quarter turn. In the spin mose the agitator only goes in one direction or your clothes would be torn to shreads.As the washer rotates back and forth, the dogs grab the inner walls of the upper agitator and that forces the clothes into a downward movement to the bottom of the tub. These dogs will wear out. To test whether or not these are bad just grab the agitator while in wash mode. The dogs should advance the top portion easily. If not then they are worn out. To replace them you must remove the agitator and sit it on the floor. Hold the base down with your feet and yank the top upwards. After seperating the 2 pieces you simply install the new dogs and line up the bottom with the top being careful not to break the little tabs on the bottom agitator that hold the top in place.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 22, 2008 | Kenmore 22422 Top Load Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Kenmore 90 series slow spin
You need a repairperson. It is probably a belt or a switch problem.
Jul 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore 90 series noise after spin
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
Oct 02, 2007 | Washing Machines
Kenmore 22422 Top Load Washer Logo
102 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
