Question about Dishwashers
How to remove Asko D3122 dishwasher drain hose
Just trying to remove the drain hose clamp from the drain pump of my dishwasher, but it looks to need a specialised tool? Any ideas?
3 Suggested Answers
  • 220 Answers
SOURCE: Maytag MDB5100AWB Dishwasher not draining
More than likely the filter is clogged,remove the spray arm(there is a threaded cap in the center of the arm twist it to the left,then remove the # 15 or 20 torx(star shaped) screws out of the filter cover(around the edges)The filter is round and runs around the outer edge of the pump housing it lifts right out,clean it and reverse the process.It's the most common issue with not draining on this model.
Posted on Sep 26, 2009
Testimonial: "The solution from TomZS was precisely what I needed to fix my Maytag washer. Thanks a million!"
rylee_smith
  • 8619 Answers
SOURCE: asko dishwasher 1385 does not drain completely.
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 10, 2009
Dead circulation pump capacitor: I have an Asko
Capacitor should have a uF and voltage rating stamped on it. They are NOT a one-size-fits-all.
Always keep your Owners Manuals so you can use it to get parts. Without seeing it myself, the part will probably have to be replaced.
Sometimes you can find the manufacturer online and get parts through their website.
Possibly find this capacitor at an AC shop.
Oct 29, 2013 | Dishwashers
Hi I had f2 flash up on the control panel so we drained it and turned it back on it now shows 5 on the control panel and wont do anything else it is a ASKO D1976
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be there when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now. Hope it helps...
Daniel
Jun 08, 2011 | Asko D1976 Built-in Dishwasher
My Asko Dishwasher D1976 on the main panel all of the top lights are on and in the display window it flashes F2. The motor is on but nothing else is happening can you help. I have checked that drains are...
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be ther when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now.
Hope it helps...
Daniel
Apr 22, 2011 | Asko D1976CSTM Built-in Dishwasher
Dishwasher will not drain. F2 shows up on panel
Hi
Hope it helps...
Daniel
Aug 20, 2010 | Asko Dishwashers
How do I remove the cerculation pump on an asko asko Dishwasher D 1716
Hello, With the right technique it isn't too bad, but it does require removing it from the cabinet/cupboard. This is what I do. FIRST**Turn off the power at the main service panel or unplug the unit.** Shut off the water and undo the water supply and drain hose. Remove as much water from the sump well as possible because you'll need to lye the dishwasher on its front ( remove any dishes inside and also get some towels or a blanket to lay it on so you don't damage the front panel or control's ). Once you have the unit out and face down, you'll see the back of the circulation motor&pump assembly...this is where it gets a little tricky, but I've done plenty and will guide you through. The clamps holding the pump hoses in place are "one time" clamps so once removed they'll need to be replaced with narrow "worm gear" clamps when installing the new pump assy. Undo the wires at the side of the motor ( A good idea would be to take a picture or draw a diagram, the picture is likely better...in my case at least ). Hopefully from here you will get the new one in. Let me know how you make out, I'll watch your post. Good luck. Macmarkus :)
Apr 22, 2010 | Asko D1716 Built-in Dishwasher
ASKO D3122 PUMP STAYS ON AND MACHINE WILL NOT SWITCH ON
The machine has activated a safty seq. There is most likely water on the lower buttom. Leakage or drain pipe blocked. The power will get to the drain pump, when this happends. To prevent overflow on your kitchen floor. Dry out the water. Then it will start as usual.
Jul 25, 2009 | Asko D3122XLSS Stainless Steel Dishwasher
Asko D3122 dishwasher will not fill with water and will not turn off
you may have water under the dishwaher ... have any plumbing work done lately?
if the dishwaher overflows or leaks it will trip a float switch under the dishwasher... as long as it is triped it will run the drain pump.. and not let any water into the tub...
the water will have to be removed and the leak stopped before it will run a cycle....
Hope this helps if not let me know more about your problem..
Mar 20, 2009 | Asko D1876 Dishwasher
Asko d/w d3122 Hi gang the overfilling protection has been activated, what can I do to remedy the sitution. regards banger35
Have a look to make sure that the pump and drain hose are unblocked. If they are, you might have to call Asko and arrange a service call.
Oct 08, 2008 | Asko Dishwashers
Dishwashers Logo
173 people viewed this question
Top Dishwashers Experts
Owen Barnes
