Question about Nintendo DS Lite Console
Screen freezes on Dogz 2 - ds lite
When I come back from shopping and go into the dining room the screen freezes. It also won't save the things I have bought. I have tried switching off and back on which used to work but now it freezes so I can't do anything. Can anyone help?
  • adele123 Jan 20, 2009
    All my other games are working just fine ......
    thanks for your help!
    Problem Solver:
  • 18 Answers
Turning it off and on will make it work less so maybe you let it fell on the ground that may be a reason of why but does this happen with other gamesyou put on? once you tell me i will know what to tell ya thanxs.
Posted on Jan 19, 2009
DS Lite malfunction Turns on sometimes freezes on keypress
try calling nintendo if you have warrenty you can get it fixed for free
Sep 05, 2009 | Nintendo DS Lite Console
Nintendo DS Lite Top Screen works at certain angle
my mates ds lite happened the same too. the only thing you can do is...
1. send it back to nintendo if its insuared
2. buy a new one
3. try and fix it yourself (mate used sellotape)
Jul 07, 2009 | Nintendo DS Lite Console
Nintendo DS Lite freezes while playing a game
the contacts where the game go got dirty or broken!, u will need to get it repaired
Mar 14, 2009 | Nintendo DS Lite Console
Turns on and lights up but no images on top screen
The DS top screen has two components, which are the LCD display, and the backlight. If the LCD display has gone bad but the backlight still works and the connecter is seated properly, the DS will still power on and the lower screen will be normal, and the top screen will light, but it won’t display anything.
You didn’t mention if your DS is the original DS or the DS Lite. Replacement top screens for the DS Lite are cheap on eBay, but installing the screen is a bit complex. The screen for the original DS is a different part and they are more expensive and hard to find.
I’ve never worked on an original DS, so I can only tell you about installing the top screen on a DS Lite.
First, the DS Lite has to be just about completely disassembled. You have to completely remove the top and bottom cases, pull out the microphone and wi-fi cables, and release the connecter for the top screen, which is located on the main board in the lower case. You’ll need the tri-wing screwdriver. You can leave the bottom screen/touch screen assembly attached to the main board, but be careful not to pull or tear the flex cables. Check YouTube for videos on disassembling the DS Lite.
Here’s the deal breaker for most people: The speakers are soldered to the flex cable of the top screen. I’ve never seen a replacement sold with speakers. You’ll have to unsolder your speaker wires from the old screen cable and reconnect them to the new one. If you can’t solder, you could take the screens to a local tv/electronics repair shop and pay to have it done. I got this information for you from http://wiinewz.com/forums/nds-general-discussion/72805-ds-top-screen-white-blank.html this appears to be a common problem I hope this helps
Dec 01, 2008 | Nintendo DS Lite Console
New ds lite will not save initial settings
Either the battery has stopped functioning properly and needs replacing, or one of the battery terminal connecters has become loose and needs to be replaced with a new battery terminal (as the battery acts as a lithium battery found in a pc to save the bios settings), but they are quite difficult to desolder and reapply, best bet is to probably get another mobo. Touch screen ribbon cable could have worked loose and needs tweaking or the connector is faulty and again needs to be replaced.
Sep 29, 2008 | Nintendo DS Lite Console
Lower screen flickering
ITS NOT HARD 2 TAKE IT 2 A REPAIR SHOP
Jul 27, 2008 | Nintendo DS Lite Console
Nintendo ds freezes up during game play
The freezing whils using an R4 card can be caused by allowing the reset function to be turned on (it's on the top right corner of the botttom screen (green is on and red is off (red shouldn't lock up, green is reset on and may lock up)))
HTH
JulianW
May 11, 2008 | Nintendo DS Lite Console
Nintendo ds lite - 2 months old
did you drop it a lot? If you did you may not be able to fix it...
Dec 26, 2007 | Nintendo DS Lite Console
Ds lite
When this "freeze" occurs, turn off the DS system and remove and re-insert the game cartridge several times. Turn the system back on and the game should appear. If not, repeat this procedure.
Dec 03, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
41 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
