Question about Hitachi CPSX635 4000 Lumens LCD Projector Projector
Projector cp-sx635 lamp indicator glows red (RED). intimate trouble shoot pl
(1) Trouble shooting of projector cp-sx635- when ON/OFF sw of the projector put to ON, LED of power (ON/OFF) sw glows green. After few seconds, both Power LED and Lamp LED starts glow RED. (2) The exhaust fan attached to Lamp continue to blowing. (3) kindly intimate the exact problem and remedial measures please.
    Problem Solver:
  • 9 Answers
Sounds like the bulb will not fire up. most likely cause is the bulb needs replacing
Posted on Jan 18, 2013
smeago1
  • 136 Answers
SOURCE: No light come on from the projector
Thats the projector telling you that you need to replace the lamp. Lamps usually lasts for about 2000 hours so if you had it for a while you may need to replace it.
www.froogle.com and enter your make and model or go to www.projectorcentral.com and find a few retailers in the US that sells lamps.
good luck
smeags
Posted on Jan 02, 2008
SOURCE: Hitachi CP-X960 Shutting Down
Where can you find one?
Posted on Sep 12, 2008
  • 41 Answers
SOURCE: hitachi cp-s235 projector- red lights and projector turns off
There is a small tab on the lamp cover that should press into an "L" shaped slot on the lamp housing. This tab may break off, and not press into slot far enough to make the lamp dectection switch click. When the lamp heats up, the plastics expand and the detection switch opens. The projector quits as if no lamp is installed. The fix is to make an extension for the tab. I cut a small piece of sheet metal and crazy-glued it to what was left of the plasic tab.
Posted on Feb 04, 2009
SOURCE: LCD projector still not working after lamp change
Sounds like you have a faulty ballast. I recomend changing it. This is your lamps own power supply.
Posted on Apr 10, 2009
bobbuc
  • 136 Answers
SOURCE: My Hitachi cp x250 projector powers on and
Most likely you have a defective lamp or it is near the end of its life. It's also possible that the high voltage power supply is going out. You might check the lamp hours - you can find this in the advanced menu. Also check the air filter, if you haven't cleaned it, the airflow might be restricted, shutting down the projector.
Posted on Sep 24, 2009
Sony kp44px3u rear projector blinks 11 times red led then Off 3 second then 11 times off 3 second what dose this mean
your problem is most likely on the deflection power supply b Board a diode possibly d303 or mcz3001b Smps control IC . it will require some trouble shooting . and you will need a digital multi meter and schematics to trouble shoot the power supply further
Feb 02, 2015 | Sony Televison & Video
Where to buy projector lamp
CP-SX635/CP-WUX645N/CP-WX625/CP-WX645/CP-X809
DT00873
NSHA275w Original lamp
USD150
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Feb 20, 2014 | Christie Projector Replacement Lamp -...
I replaced the lamp for my LG 52sx4d DLP television. The TV still wont turn on and has a red blinking light where the green lamp indicator should be. How do i get my tv to turn back on!
did you get a Philips lamp check that also make sure all the doors are close also you could trouble shoot more with discount merchant
Sep 13, 2011 | LG 52SX4D 52" HDTV
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
Overheating?
The glow is normal, but the sparking may indicate lint back in the heater element compartment, you can check your owners manual for trouble shooting tips.
Apr 22, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Apr 10, 2009 | Hitachi CP-X250W Multimedia Projector
Infocus 4805 blinking red light problem
My first questions is:
Is this the first lamp you have placed into your Infocus pj? If not, did you reset the hours when you did it last time? Otherwise that can also confuse the projectors internal system thinking there is NOT a new lamp in there and there for make it stop working once the clock hours are expired and over the 3000-6000 suggested hour life.
Let me know so I can help trouble shoot other possible problems.
Oct 27, 2008 | InFocus ScreenPlay 4805 Multimedia...
Lamp and power light flashing
Red lamps flash but picture doesn't disappear. 100hrs remaining on filter timer.
Aug 03, 2008 | Hitachi CP-X345 Multimedia Projector
Dv 10 Lamp trouble
examine the lamp
any fault should be visible on the tube.
i assume you mean the pj lamp glowing bright red
Feb 26, 2008 | Optoma MovieTime DV10 Multimedia Projector
Hitachi CPSX635 4000 Lumens LCD Projector Projector Logo
135 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
