Question about HP Pavilion 761n PC Desktop
Install power supply - HP Pavilion 761n PC Desktop
  • ronhirata
    ronhirata Jan 03, 2013
    There is a square 4 prong connector on the PSU and I don't recall if I need it or not.
  • ronhirata
    Thank you!
  • HP Master
  • 27,725 Answers
No Power on an HP Pavilion PC Desktop b> Desktop computers are simultaneously more complex and easier than laptops when it comes to troubleshooting. There are more physical components on a desktop, so locating a specific troublesome part can be tricky, but working inside of a desktop computer is straightforward compared to opening and fiddling with a laptop. Power problems are always hardware problems. There are a few simple, preliminary steps to troubleshooting, but power problems often require opening your computer and having a look inside.
The Basics
Unplug everything from your PC except for the power cord. Try turning on the system and look for lights on the front, then on the back. When the power supply is on (receiving power), the small light beneath the plug turns green. If this light doesn't come on, the problem is either connected to the cord or the power supply. Try swapping power cords with the monitor cord to isolate the cord as the source of the problem. Look closely at the voltage selector and make sure it's set appropriately for your country -- 110 in North America and 220 for most other regions. b> The Socket b> Unplug the power cord and switch the voltage selector to the opposite setting. Wait five seconds, then flip it back. This ensures that the switch is engaged. Plug in the power cord again and try turning on the PC. Check the outlet to make sure it's working, and plug your computer direction into the wall socket (remove it from any surge protectors or power bars). Check the power button. If it sticks when you push it, it may not be making contact to engage the system power and will need to be replaced. If the button is going in and out freely, you've done about everything you can do from the outside of the computer. It's time to go inside. b> Open it Up b> Unplug the power cord and hold down the power button for five seconds. This clears all electrical charges from the circuitry and makes it safe to open the computer. Remove the side panel from your system. This process varies a bit from model to model -- some have one or two captive screws on the back of the system, some have an easy release button. Check your manual. b> Power Button b> Locate the power button from the inside and trace the cables to where they plug into the motherboard. Lift up on the connector and then push it firmly back down. Plug the PC back in to its power source and try to power it on. Unplug the computer immediately if the system doesn't power up, and continue troubleshooting. b> Hardware Components b> Disconnect each of the devices in your computer one at a time to locate a faulty piece of hardware. Power cables run from the power supply connect to your optical drive, hard drive, floppy drive (if one exists) and into several places on the system board. This step takes some trial and error detective work and a few minutes: unplug one device, reconnect the power, and try turning on the system. Then disconnect the AC power, plug the device back in and try the next one. If the system powers up at any stage, the device you are unhooking is shorting out the power and needs to be replaced.
http://www.youtube.com/watch?v=HJvYGtbwmh8
To Replace HP Pavilion Desktop Power Supply http://www.youtube.com/watch?v=VcEFUpZSmI4 Hp Pavilion 750n desktop computer basics on this computer b> http://www.youtube.com/watch?v=D8Y2PPMiiB0 HP Pavilion Slimline PSU Upgrade Guide This guide compares the Sparkle SPI270LE - 270 watt PSU against the Shuttle PC50 -300 watt as possible power supply upgrade for a HP Slimline. The s3600t Slimline I used for this video has a Intel Hope this helps.
Posted on Jan 03, 2013
Testimonial: "Thank you! That was a great help."
  • Brian Sullivan
    Brian Sullivan Jan 03, 2013
    thanks for replying and the testimonial hope it all works out
New power supply don't work
New Power Supply installed, computer won't boot up ...
www.tomshardware.com > Forum > Components
Tom's Hardware Guide
May 22, 2013 - 6 posts - ‎2 authors
I have recently received my new power supply, i was very excited for it and just finished installing it. ... those were already 100$ on both the powre supplies, i don't want to .... Do you have another computer around that works?
New power supply now computer won't turn on [Solved ...
Jan 22, 2014 - 3 posts - ‎2 authors
Bought a new 500W power supply to replace the one of the same wattage. I wanted to ... This should turn the PSU on and the fans should work.
pc not booting after installing new power supply (pictures ...
Jan 01, 2016 | Computers & Internet
Connecting power supply to motherboard
Hi There
This guide was developed to instruct readers on the proper procedures for installing a power supply unit (PSU) into a desktop computer case. It includes step-by-step instructions with photographs for the physical installation of the PSU into a computer case.
IMPORTANT: Many name brand manufacturer PCs use specially designed power supplies that have been built specifically for their systems. As a result, it is generally not possible to buy a replacement power supply and install it into these systems. If your power supply is having problems, you will likely need to contact the manufacturer for repairs.
CAUTION: All power supplies contain various capacitors inside of them that retain power even after the power supply had all power turned off. Never open up or insert any metal objects into the vents of the power supply as you can risk electrical shock.
To start with installing a power supply, it is necessary to open up the case. The method for opening the case will vary depending upon its design. Most new cases use either a panel or door while older systems require the whole cover be removed. Be sure to remove any screws fastening the cover to the case and set them aside.
Align the new PSU into place in the case so that the 4 mounting holes align properly. Make sure that any air intake fan on the power supply that resides in the case is facing towards the center of the case and not towards the case cover.
Now comes one of the most difficult portions of the power supply installation. The power supply needs to be held in place while it is fastened to the case with screws. If the case has a shelf ledge that the power supply sits on, it will be easier to balance.
Make sure that the voltage switch on the back of the power supply is set to the proper voltage level for your country. North America and Japan use 110/115v, while Europe and many other countriesuse 220/230v. In most cases the switch will come preset to the voltage settings for your region.
If the computer already has the motherboard installed into it, the power leads from the power supply need to be plugged in. Most modern motherboard use the large ATX power connector that gets plugged into the socket on the motherboard. Some motherboards require an additional amount of power through a 4-pin ATX12V connector. Plug this in if required.
A number of items reside within a computer case that require power from the power supply. The most common device is the various hard drives and CD/DVD drives. Typically these use the 4-pin molex style connector. Locate the appropriate sized power leads and plug them into any devices that require power.
At this point all of the installation and wiring should be completed with the power supply. Replace the computer cover or panel to the case. Fasten the cover or panel with the screws that were previously removed to open the case.
Link with Photo
Dec 12, 2011 | Computers & Internet
When I turn on my computer it runs for a couple of seconds and then stops.
Unplug everything inside the computer, except the motherboard and the front panel power on switch. Power up the computer. If the PS fan continues to run, (power supply doesn't shut down)and the CPU fan runs, then power off the unit and reinstall each device, one at a time, turn the power supply on after each device is installed (and off, before installing the next device).
You can not easily start the power supply if it is not connected to the cpu motherboard.
If the power supply shuts down with only the motherboard attached, then you will need either another power supply, to test the MB, or another MB to test the power supply.
R
Feb 02, 2011 | Acer DPS-420GB (dps420gb) Power Supply
Set up New PC Studio that is NPS then install USB drive
i have to install PC studio in my PC but when i tried it shown that my PC does not have NPS therefore it can not be installed. tell me how to install NPS.
May 30, 2010 | Dell 210W Optiplex GX270 NPS-210 AB Power...
Powr supply checks out with tester, but when plugged into a BRANDNEW motherboard. Flashes green, Power switch is in and fans are in. Is it possible for P/S to be bad only when drawing from board?
There are many possibilities here. The motherboard could be installed incorrectly causing a short. The motherboard may not support the processor. A hardware device plugged into the motherboard may be shorted. The power supply may be defective under load ( when plugged into everything). No memory is installed on the motherboard. The power supply is too small for the motherboard that was installed. The first thing to check, is to plug in the motherboard connectors only with memory installed then try to power up. If at this point it will not power up, then you have a problem with the power supply or motherboard. If it powers up at this point, then plug in one device at a time starting with the hard drive and try to power up. If it continues to power up, plug in another device. If this process continues work, then you will find that either you have a shorted device or your power supply will not support the motherboard and all of the installed devices. It is also possible at this point that the motherboard is defective, by using more power than it should causing an overload on the power supply with all devices plugged in.
Dec 27, 2009 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Blinking power supply LED
Your power supply is fried. I had the same problem with my Bestec ATX 250 power supply. I fixed the problem by installing the StatTech model: ATXPOWER250. It was easy to install and works well. It is almost identical to the original but more quiet. I got it for $29 at MicroCenter.com. Also at online Newegg.com, Radioshack.com, Provantage.com, June 20,2009
Jun 07, 2009 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Power supply installation in gateway 610xl
to replace a standard ATX powersupply;
remove left hand side cover (ensure power is disconnected first);
disconnect the 20.24 pin primary power plug (big wide white one plugs directly onto the mainboard, also disconnect the 4 pin AUX power plug, looks just like the other one but is a smaller square shaped plug (older P3 boards will not have this)
disconnect all 4 pin power plugs from hard drives/cd drives and aftermarket fans (if any are installed), disconnect SATA power plugs from any SATA devices installed (flat black plug, 4 wires)
disconnect floppy drive power plug (if app) small while 4 pin power plug, once all of these are disconnected, looking at the rear of the computer there will be 4 screws holding the power supply in place, one screw will be more to the centre slightly to ensure you do not put it in upside down, once you remove those screws the power supply will slide right out.. simply re-do these steps in revers for instaling the new power supply
David
Feb 28, 2008 | Gateway Media Center 610XL PC Desktop
Power supply
Not sure what you requesting as information but to install a power supply is easy (make sure it's not plugged in obviously). Take off the case...it's right there. Unscrew from the outside to remove and install new. One word of caution...I am not a big fan of E-Machines "past"....motherboards and power supplies were (are?) major failure items with these machines. If you wish to know what supply to use check what you have and then go to pricewatch.com to find one....note, it need not be the same brand (preferable probably) but it does need to have the same dimensions and wattage. Trust this helps...Tango
Jan 18, 2008 | E-Machines E-Machine Power Supply 230W ATX...
HP Pavilion 761n PC Desktop Logo
67 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
