Question about Pentax ZX-30 35mm SLR Camera
Lens problem... I have two lenses for my Pentax ZX-30; one Quantaray 55mm and a Quantaray 62mm telephoto. I can take pictres just fine when I affix the 62mm telephoto lens but when I switch back to the regular 55mm lens and turn it on, the LCD panel flashes "Av - -" in the lower left hand corner and won't take pictures. It seemed to start doing this out of nowhere one day in between routine lens-switches. I've tried every conceivable combination on the mode dial to no success. Any thoughts?
    Problem Solver:
  • 15 Answers
You are experiencing lack of communication between the shorter lens and the camera body. Since the longer lens works correctly the problem is in the other lens and not the camera body. BTW-the numbers 62mm & 55mm are probably the filter sizes for each lens and not the focal lengths. Unscrew the filters and you will probably find a name ring on the lens signifying the type of lens it is(e.g. 28-80 or 70-200 or something like that.) Look at the rear mount of the problem lens. There are some small metal(5-6) contacts there. Make sure the contacts are clean. If not, clean them with a soft rag or Q-tip. If they seem to be OK then there may be a problem inside the lens with the flexible printed circuit(FPC). The FPC may have been damaged somehow. If this is the problem take the lens to a competent repair shop and have them evaluate it. Depending on exactly which lens it is, it may be cheaper to replace the lens rather than repair it--but have it looked at anyway. Hope this helps.
Posted on Jun 27, 2007
SOURCE:
Does the quantaray 85-210mm fit the canon rebel cameras
Quantaray makes lenses with many different mounts. If the lens has a Canon EF mount then it will fit your camera. If it has another mount, Nikon for example, then it will not fit your camera.
Dec 05, 2013 | Quantaray Auto Zoom Telephoto Lens Macro,...
Quantaray 600-1000mm Telephoto Zoom Lens FOR NIKON work with D3100 in all modes?
The lens is a manual focus lens. It doesn't matter which mode you have the camera in, you'll still have to focus it yourself.
Nov 16, 2012 | Quantaray 600-1000mm Zoom Lens
IS THE 28-90mmF/3.5-5.6 FIT THE CANON REBEL XTI
Since you already have a Quantaray lens, you should know that Quantaray makes lenses with a variety of mounts. A lens with a Pentax mount won't fit a Canon camera, for example. As long as you get the lens with a Canon mount it will fit the XTi just fine.
Aug 18, 2012 | Quantaray 28-90mm f/3.5-5.6 for Pentax
Quantaray Tech-10 Camera Telephoto lens 75-300mm is it work in Nikon D3100?
Quantaray makes their lenses with a variety of mounts. As long as you get a lens with a Nikon mount then it will work on the D3100.
Jul 16, 2012 | Quantaray Cameras
Dear sirs; What type of uv filter fits a quantarary tech 10 28mm - 200mm zoom lens. I have several 62mm filters and the zoom lens does not accept the normal threaded screw on format common to lenses
First, make sure that the lens diameter is 62mm. It should say on the front or on the body of the lens. If this is correct, it could be a unique mount that would require a specific brand. If it's quantaray, it might require quantaray filters. If it's an old lens, it might require an attachment to the front of the lens that would act as a filter holder for the square filter tiles.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/erik_3934b541f17c4e99
Jun 04, 2012 | Cameras
Hello i have a Quantaray 70-300mm DI f/4-5.6 Digital AF Zoom Lens. what size lens cover do i need for it?
Look at the writing on the lens. There is a number next to a circle with a line through it. The 70-300 is probably made by Tamron and sold under the Quantaray name. Probably a 62mm diameter.
lightspiritphotography.com
Dec 14, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
I was wondering, are all quantaray lenses interchangeable? I got a quantaray dakota camera, and it says it has interchangable lense capabilities. Does that mean that any lens called quantaray can fit on...
No. Quantaray makes a wide range of lenses, with a wide selection of mounts. This is because the various camera manufacturers like Canon, Nikon, and Pentax have proprietary mounts. A Quantaray lens for Canon will not fit on a Nikon, for example. You need to specify the mount when you buy your lens.
Oct 11, 2009 | Quantaray 100-300mm F4.5-6.7 Zoom lens for...
Dropped my camera bag & my 17-55mm Lens Now will not telephoto
The best way to get it done right after you drop the lense is send it to NIKON NY . They put the lense on a resolution bench test and it make sure the resolution is great ,. This lense is very criticial and it is a must or your wasting your money . The reason is this ., The lense is a wide angle and sometimes photographers have probelms with 17-55mm lenses and sub mirror problems . So its best to be safe than sorry .
Mar 07, 2009 | Nikon 17-55mm f/2.8G ED-IF AF-S DX Zoom...
AV error whn pentax ist DL & Quantaray zoom lens attached
I've got the same problem. The problem is that the lense is loosely attached to the body. What you need to do is that when you see the Av flashing, press the lense of the camera to the body and twist the lense to the left a bit. This tightens the connection. You can then take the photo.
Feb 20, 2009 | Pentax *ist DL Digital Camera
Lens
You have a 55mm filter size on your camera, and the accessory lens requires a 62mm camera connection. I think you are looking through a 55mm tunnel into a 62mm lens (over-simplified I know). The black ring is the result, and I don't think you can fix that. Is the telephoto a Panasonic accessory, or a third party item. I think I already know the answer to that. I'd take it back and see what Panasonic recommends - you'd be happier. However, Panasonic has Leica glass (Leitz lenses) so it won't be cheap.
May 19, 2008 | Panasonic Cameras
Pentax ZX-30 35mm SLR Camera Logo
93 people viewed this question
Top Pentax Photography Experts
Bill Eager
Geoff Hone
Are you a Pentax Photography Expert? Answer questions, earn points and help others
