Trouble hooking up wireless printer
WPS light on router not lit up
    New Friend:
You may need to reset your router and let it run through its "connecting cycle" (about a minute or so) then using your printer go throu the settings and do another device search. You will also need to do the same on your computer so the printer and computer pair-up. Also try going to the printers brand web page and look up the software or drivers for that specific model.
Posted on Jan 03, 2013
3 Suggested Answers
  • 23 Answers
SOURCE: I recently purchased an acer computer that has
All you should need to do is connect the HP printer to your wireless router via Ethernet cable (which should be included with the printer). Follow the instructions that came with your printer to set it up on your computer.
Posted on May 13, 2010
Rider On Way
  • 1679 Answers
SOURCE: HP Photosmart printer gives me
If your router does not has WPS button, there is another way to Enable it from Router configuration under wireless settings
If you enable the WPS option from Router, you will have to press the WPS option from printer for automatic setup of printer on wireless network.
If you are not able to locate it then the WPS on your printer is of no use ( to connect to router )
Instead, I believe you have wireless router and you want to setup the printer wireless on network.
This is touchsmart printer and it has a setup button
Press SETUP option
Press WIRELESS option
Check for Wireless Setup Wizard
If it has Wireless setup wizard, select it and continue to search for wireless router and enter your network key if your router is secured with a key.
Run the software disk on pc and choose wireless connection and continue with the rest of the installation screen to complete.
If this option is not available, you will have to setup the printer thru usb cable and make it wireless
Run the disk on your pc
Choose Network Wireless connection
It will prompt you to connect thru USB
follow the instructions and it will ask you to disconnect
Continue with the remaining instructions.
Posted on Oct 23, 2010
What does WPS button stands for.
WPS=WiFi Protected Setup. This is typically used to connect a Wireless Router to a Wireless Repeater. Both must be WPS capable and using WPS is similar to pairing two Bluetooth devices. One device transmits WPS and another listens (after you initiate a WPS sync). You have to enter a WPS PIN and the devices should connect.
Jul 03, 2017 | The Computers & Internet
I cannot find my WPS button on my Wifi printer. I have pressed WPS on router but no different
where is the WPS button? - Canon Community
community.usa.canon.com/t5/Printer...Support/...WPS-button/td.../8893
Dec 27, 2012 - It asks for me to push the WPS button, but can't find? ... Now I am afraid to unplug the printer and move it back to my desk because it will ... starting only 2 days back, it was daily "dropping" my wifi connection with my MacBook.
WPS access point - Canon Community
community.usa.canon.com/t5/Wireless.../What...WPS.../11819
Jan 19, 2013 - What and where is the "WPS access point" button required to set up wififor the ... What and where is the "WPS access point" reqired to use wifi for the MX432printer .... My WPS button is on my the back of my router (blue button) ... I have a tp-link model tl-wr841n and I can't find the access point in the router ...
Connecting your HP wireless printer ' Wireless Printing ...
Nov 19, 2015 | Computers & Internet
WHERE IS THE WPS BUTTON ON A MG5650 PRINTER, TRYING TO SET UP THE PRINTER AS WIRELESS
The WPS button is on most wireless routers.On the printer go to tools and wilan setup and hit ok after you push the WPS button on the router
Feb 07, 2015 | Computers & Internet
I got a Netgear WNCE2001 today. My router is a Verizon router. (The one with the WPS button on the front.) The security password is in WEP. When I try to connect it with WPS, the light on the WNCE2001 just...
which light is blinking ?
may be this help you ?
2. Select a radio button.
• Push and Connect (recommended). Either click the button or press the WPS
button on the rear panel of the Internet adapter.
• PIN Number. Select the radio button and a PIN displays.
The Internet adapter tries to join the wireless network for 2 minutes if you are using Push
'N' Connect, or 4 minutes if you are using a PIN.
3. Go to the router.
• If you are using Push 'N' Connect, press the router's WPS button.
• If you are using a PIN, log in to the router and type the PIN from your Internet adapter
in its WPS screen.
4. Go back to the computer that is connected to the Internet adapter, and make sure that you
are connected to the wireless network.
• When WPS is running, the WLAN LED blinks, alternating between green and amber.
• If the computer does not to connect with WPS, the WLAN LED is solid red for 5
seconds.
• If the computer does connect using WPS, the WLAN LED is solid green for 5 seconds
Then the WLAN LED returns to indicating a wireless signal.
Feb 12, 2014 | NetGear Computers & Internet
Can i use wps button to connect my printer to my network?
According to the Canon website, yes, the 495 is wireless capable. I have a Pixma MG5300 and had no trouble at all connecting to my network with WPS. The installation instructions were a bit unclear but I just pushed the WPS button on my router right after going through the steps to make the wireless indicator on the control panel blink. Works great.
Dec 11, 2013 | Canon PIXMA MP495 InkJet Printer
Where is the was button
I'm guessing you mean the WPS button - "Wireless Protected Setup" - As far as I can see from the User Guide this router doesn't have an actual WPS Button - You need to log onto its admin web interface and browse to the WPS setup page - Press the WPS button on your client device (laptop, printer, etc) then Click the WPS button in the router's web interface and let them talk to each other to establish a secure connection - The WPS light on the Front Panel should then light up when connected - You can find a user guide at the following url:
http://downloads.linksys.com/downloads/userguide/1224642967100/WRT54G2-EU_V10_UG_combination_NC-WEB.pdf
Jun 14, 2013 | Linksys WRT54G2 V1 Wireless-G BROADBAND...
I am having trouble downloading My wireless Printer-CanonPixmaMX892 to my laptop!
Yes. It is a feature on the router and wireless enabled device. You can't use wireless without a router. I got a Belkin n750, and it has WPS. Basically, you activate WPS on device and push the WPS button on router, and wait a minute for it to configure.
Not to sell the Belkin, it one the easiest and user friendly routers i've seen. That is solely based on answering these questions. GL
Oct 17, 2012 | Computers & Internet
I am having problems with setting up my printer (Epson TX710W) to run remotely from my router. When I attempt to setup the router it wants me to use it for internet connection but I am running my internet...
Hi Robert_fl657,
For any printer to run on the network (wired or wiireless), aside from just a router, you will need a print server. Now, since this printer has wireless capabilities, i am going to assume that you might have a wireless prinet server built in (WPS). If your wireless router does not have that function, i suggest you buy a wireless print server to accomodate the printer that you would want to hook up.
Possible Solution 1: Sync wireless printer with WPS button on wireless router
1. Try and locate the WPS button (if any) on the wireless router.
2. Once located, go to the network options on the wireless printer and select set up by WPS.
3. Once you have selected that option, the printer should be in a seeking mode. Select and hold the WPS Button down on the wireless router.
4. If all goes well, you should have established connectivity with the wireless router.
I hope the above information helped. Please do let me know if there are other queires regarding this. Also, pls remeber to vote for me if you find this solution useful. Thank you.
Regards,
Technomancer
Apr 04, 2010 | NetGear DG834G Router
Security(wps) light not lit on router
You need to setup the wireless security ON on the router by loggin in to router setup page for that you need to connect the router with a ethernet cable with the computer or laptop and open the router setup page with router IP in internet browser, if you can tell me the model number of the router and brand i can give you step by step process to setup the security on the router.
on selecting the security as any apart from none the light comes on
Let me know if this will help
Regards
Nov 30, 2009 | Computers & Internet
23 people viewed this question
k24674
jasbo
jasbo
