Question about Bose & Wave& Music System
Bose wave radio/cd player. Power reduction.
Turned on my bose wave player and heard a loud crack noise. After this the unit seems to have lost a lot of power. The volume has to be turned up considerably more to hear the music. There also seems to be a loss of quality in the sound.
I would be very grateful if anybody can offer a solution. Is it something that a radio repair place can solve relatively cheaply or will it cost me a fortune to repair.
Thanks in advance.
Neal Webb.
    President:
  • 2,761 Answers
Unfortunately, Bose does not release their parts lists or schematics, effectively creating a monopoly for parts and repairs. In fact, their web site says that the Bose factory is the only option for service or repair. They used to list a flat rate repair charge on the web site, but removed it - probably because it scared too many people. Their troubleshooting guide (below) might help, but it's very simplistic.
Before you invest in expensive factory repair on one of these trouble prone sets, you might want to investigate the new HD radios -- better sound at a MUCH lower price.
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/troubleshoot/index.jsp
Posted on Aug 09, 2009
2 Suggested Answers
SOURCE: BOSE WAVE RADIO/CD
I've repaired about 10 type Bose AWRC3x (the radio/cd model with lift up lid and top controls). If the cd won't play or skips, try cleaning the lens VERY carefully with a cotton bud with some isopropyl alcohol. Let it dry then try again. This will help in about 1/3 of cases.
After that, a new laser unit is needed. They cost around 15 pounds,30 dollars, (Type SFP100s with 13 pin connector made by Sanyo). You need to have some electronics experience to take the case to bits to get the laser deck out, change the cd laser and reassemble. Basically, DISCONNECT THE POWER! Remove the 3 screws on top, turn over and carefully prise the front of the base away from the top cover with a table knife or similar. Lift off the top cover - be careful with the lid ribbon! The deck can be disconnected from its ribbon cable and wired connector very carefully. Take the deck to bits and fit the new laser head (take photos if you think it will help). Remember to unsolder the shorting 'blob' of solder which protects the new laser from static till its fitted.
On the bright side, there is no tracking etc to set up, that's all automatic so usually they work like new with a new laser fitted. I have to say this is the weakest feature on the Bose CD radio, the actual electronics rarely gives trouble.
Hope this helps Steve O'Donnell
Posted on Mar 20, 2008
Loud static burst at random times
Bose is proprietary. It could be electronic parts that are called capacitors.
Dec 09, 2013 | Bose & Wave& Music System
Loud popping noises affecting C D and Radio
You need to stop using the system to avoid further damage, go to www.bose.com contact customer support and the technical department, they have the authorized technicians and the much needed parts available, service is done on site by their factory trained personal.
Jun 16, 2012 | Bose & Wave& Music System
My Bose radio/cd player is making a loud siren noise when you attempt to turn on the radio or play a CD. Does anyone know what this is?
  • The amp has gone bad. You risk blowing the voice coil in the speaker until this is fixed or repaired. There is an electrolyte capacitor that has gone bad.
Regards, Tony
May 23, 2011 | Bose Wave Radio
Bose Wave Radio pops, loud hum that fades
Power supply capacitors have dried out and need to be replaced.
Sep 03, 2017 | Bose Wave Radio
I can't seem to adjust the time using the remote
You can obtain the Bose Wave radio instruction manual in electronic form, here: http://products.bose.com/pdf/customer_service/owners/og_wrcd.pdf
See page 15 for setting the time. You should be able to do it with the unit controls.
Apr 13, 2010 | Bose Wave Radio
I have a bose wave radio and cd player the cd
you sure have a problem with your cd pick up unit or servo drive,for that must bring it to your local repair shop
as for the poor recepcion olease try a better antena
Dec 18, 2009 | Bose Wave Radio
Loud popping and static-vol ctrl has no effect on noise
Bose will not release their schematics or parts lists, effectively giving them a monopoly on repair of their units. If you check their web site, www.bose.com, you'll find that they will repair your unit for $100 or possibly give you $200 credit towards a new model. Before you take them up on either offer, you might want to check out the new lines of HD radios. Better souind quality, MUCH lower prices than a Bose.
Bill B.
Apr 20, 2009 | Bose & Wave& Music System
I gave the Bose Wave Radio and 3-cd player to a friend for
Unplug and plug back in. It should go through a automatic process, ejecting any discs that are inside. If all you hear is a mechanical noise, try this again only with the disc trays facing the ceiling.
Dec 29, 2008 | Bose Wave Radio
Horrific bone crunching sound from clock radio
Unfortunately Bose will not release their schematics or parts lists, effectively giving them a monopoly on repair of these sets. Before you spend the big bucks on repair or a Bose "upgrade", you might want to check out the new HD radios. Better sound and MUCH lower prices than the Bose.
Aug 11, 2008 | Bose Wave Radio
CD player not working
CD Player on my Bose Wave radio/cd just blinks CD and it appears to me that the disc is not spinning. This is the same problem that many others have already identified. I unplugged the unit and removed the battery but this did not solve the problem. I notice that there is a "platter" (part of the lid) that sandwiches the cd onto the spindle. the platter seems tight but does turn. Also, does anyone know if there is a drive belt that may have broken?
Nov 03, 2007 | Bose Wave Radio
Bose & Wave& Music System Logo
201 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
