Question about Ricoh Aficio 1035 Copier
Error 061 canon ir5075
Error e061
    New Friend:
Hi you should check the lower corona block cleaning motor or the cleaner got stuck
Posted on Mar 24, 2013
Can anyone help me I have problem with code E061 with Toshiba Copier e-studio 850
Please check if your paper orientation and size in the first cassette matches the copier's display settings. If your machine is set to letter size paper, but you have LD in your first cassette you will get e-061
Nov 27, 2011 | Office Equipment & Supplies
E061
I bought the machine book and I was able to look at it based on him what it reports the E-061 mistakes.
Myself was able to improve it and now good it's working.
I say thank you for your help nicely.
Jan 06, 2010 | Canon CLC 1000 Color Copier
Error code E061/0040
check and clean the Primary Charge unit or check all the door actuator check if there is damage .it couldbe the laser gate is not opening because the (door)actuator is broken
Jul 22, 2009 | Canon CLC-700 Copier
Error code E061 0093
its a problem of dirty primary assembly or the corona and grid wires are dirty or check your front door actuators if the laser window is not open,laser can't reach the drum and will result Error 061 hope this will help
Jun 08, 2009 | Canon CLC 1180 Copier
Can somebody help me what this mean? Error Code: E100 0001- E100 0002 it is a canon LBP5000
Symptom
  • E061-0001 (Potential ON)
  • E061-0002 (Potential OFF)
  • E100-0001
  • E227-0004
Cause
  • The pin is broken on the Primary Fan 2 Duct. The Laser Shutter is activated by the pin on the Primary Fan Duct Assembly. The linkage is pinched not allowing the laser shutter to be fully actuated (may also indicate E227-0004). Faulty Laser Scanner Assembly.
  • Defective DC Controller PCB Assembly.
Action
  1. Check the shutter operation and the pin on the Primary Fan Duct Assembly. If the pin is broken replace the Primary Fan 2 Duct (iR6570 : FC6-3540-000 / iR5075 : FL2-5834-000) or the Primary Fan Duct Assembly (iR6570 : FM2-3074-000 / iR5075 : FM2-9694-000). If the Laser Scanner Assembly (iR6570 : FM2-3670-000 / iR5075 : FM2-9832-000) has been replaced and error codes E100-0001/ E227-0004 are intermittently indicated, proceed to the next step.
  2. Remove the Primary Fan Duct Assembly (this assembly has a pin on it that activates the laser shutter).
  3. Remove and reinstall the Laser Scanner Assembly.
  4. Install the Primary Fan Duct Assembly. This should free the linkage allowing the laser shutter to be fully actuated.
  5. Finally a DC Con clear resolved both of the intermittent issues (E100-0001/ E227-0004).
May 28, 2009 | Office Equipment & Supplies
ERROR E061-0122
e061 is a code for a drum charge error on the first drum in line from right to left i think yellow ? any way its either a worn drum broken charge wire if you have not changed drums in a while the other ones may be coding out next
Jan 28, 2009 | Canon CLC 2400 Color Copier
E061-0122
this is a very old machine and canon do not make certain parts any more------01= yellow check corona wire, grid, drum, develpoer replace if necessary
Oct 16, 2008 | Canon CLC 1000 Color Copier
Look up error code E00061001 for Canon 5020i
Title : E-061 Error Code Problem :
E-061 code is occurring for the IR5000/6000
Solution :
Check, re-seat or replace the Primary Corona Assembly
Apr 25, 2008 | Canon imageRUNNER 5020i Copier
Error E061 & 0070
grid bias at upeer limit
Dec 19, 2007 | Canon CLC 1120 Color Copier
Ricoh Aficio 1035 Copier Logo
326 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
