Question about Vacuums
Dc04 zorbster where can i buy parts in new zealand for this product. it was shipped over from the uk and there were a couple of hoses missing including the inspection cover hose.
  • 1 more comment
  • David W Jan 03, 2013
    I also need a legible diagram of the machine. The diagram that I have seen so far on the net seem hard to read on my ipad.
  • Les Dickinson
    Les Dickinson Jan 03, 2013
    go here https://www.google.co.uk/search?q=dyson+...
  • Les Dickinson
  • Vacuums Master
  • 18,394 Answers
Go to this link and send dyson a email they will should know
http://content.dyson.co.uk/contact/default.asp?basketTotal=0.00&basketQty=0&logged=false
Posted on Jan 03, 2013
  • 55 Answers
SOURCE: I want to replace the
Man that stinks burden.
Here's the deal. Sharp quit making vacuums and parts because, the same factory they were making the vacuums in, they were making regular T.V.'s in, and they decided to focus on the flat screens, thus it wasn't in the cards to keep the factory open. At least that's the way I understand it, and that's why you're having trouble getting the part.
The only thing you can do is call around to independent dealers and try to find it. A lot of times the ones that have the space will save spare parts, but the part numbers are not going to be on the parts, so that won't do you much good. You'll probably have to take them the those hose or the machine so they can see it, to make sure they have the right one, or if the tech is really good he may know that model and right hose off the top of his head.
Sorry I don't have a great answer for you, but I help people find stuff like that all the time, hopefully someone close to you will do the same. Good Luck
Posted on Dec 01, 2008
SOURCE: How do I replace the microswitch in my dyson DC04 Zorbster
Move the flexible hose at the rear out off the way and you will see a small hole that goes through to the on/off switch assembly. Use a small screwdriver through the hole to push the plastic clip away and you can then lift off the on/off button. You will then see a phillips screw that holds the switch assembly/housing to the main unit. Just unscrew and the whole switch unit can be removed.
Posted on May 28, 2009
SOURCE: No Problems with suction on hoses, however brush area it seems to lose powe, and has little suction r
We had a similar problem with ours and had to finally take it to the repair shop. They informed us that we needed to replace our clutch and that you needed to do that every 2-3 years. It cost less than $100 and has been well worth it.
Posted on Jun 24, 2009
  • 83 Answers
SOURCE: Dyson Animal Hose collapses
The blockage is in the wand itself - take it off the back of the machine and separate it from the gray hose. Hold the wand into the air and look through it. If you don't see the light coming through the other end, there is a blockage in the wand. Remove it with a long object like a metal hanger. The DC07 wand is slightly bent at the top - you should still see some light coming through the top though. Be sure to look through the metal rod end of the wand, otherwise you probably won't see anything anyway.
Posted on Jul 30, 2009
pippall
  • 1486 Answers
SOURCE: my hose tools wont pick up. when hose tools
I have a DC04 and the hose tools are a open hole.The only reason they want pick up is they are blocked.If you say they are sucking your hand when not attached.Make sure the hose is not blocked by taking off the cover at the front.Allso check the cylinder rubber seal is sealing the dust container.Thats the only problem i had with mine.Good luck.
Posted on Aug 01, 2009
I have a Dyson DC04 Zorbster. Sometimes there is very little suction & the motor runs slower than normal. If I give it a little shake or push down on the bin (my wife tends to give it a kick) the motor...
Hi David, it's Jack at Dyson.
The issue you're describing sounds very unusual. If the motor seems to be changing speed in use, this could suggest a fault with the motor. DC04 is one of our very oldest machines, and unfortunately due to its age we're no longer able to support it with servicing or spares. However, it would be worth giving our experts a call so we can help confirm if the motor is the cause of the issue - and we can also discuss other the options available to you.
When you have your machine to hand, please give us a call on 0800 298 0298. We're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends. Calls are free from UK landlines.
We'll look forward to speaking to you.
Feb 25, 2015 | Dyson Vacuums
How do i alter the dyson dc04 to use on hard floors
Hi there, it's Jack at Dyson.
If your DC04 has a brush control on the cleaner head, you'll need to set this to 'On' for carpets, and 'Off' for hard floors. You can find out how to do this on our Support site:
http://www.dyson.co.uk/support/dc04/dc04-brush-control/my-machine-is-not-working/i-can-see-something-wrong-visual/i-can-see-something-wrong-visual/my-brushbar-is-not-rotating2/does-the-brushbar-rotate-with-the-power-on
If your machine does not include the brush control, it will only be suitable for vacuuming carpeted surfaces and we'd advise against using it on hard floors in upright mode. However, you can use the hose and wand to vacuum hard floors and we have several suitable hard floor tools available which may help.
I hope this helps - if you'd like further advice you can reach our freephone Helpline on 0800 298 0298. Just to let you know, our Helpline is available from 7am-10pm, 7 days a week.
Best wishes,
JackDyson Online Customer Supporthttp://www.dyson.co.uk
Mar 06, 2013 | Dyson DC04 HEPA Bagless Upright Cyclonic...
How do i use the hose attachment on my dyson dc04
Hi Sarah,
For advice on using the hose, wand and accessories, please refer to the DC04 user guide. In case you don't have this to hand, you can download a copy here:
http://media.dyson.com/downloads/UK/floorcare/Manuals/dc04_gen_manual_uk.pdf
You may also find our Support page useful - just select your model from the list to view troubleshooting guides for advice on using and maintaining your machine:
http://support.dyson.co.uk/Support/Uprights.aspx
I hope this helps - if you'd like any further assistance or advice, please call us free on 0800 298 0298. Our Helpline is available from 7am until 10pm, 7 days a week.
Best wishes,
Jack
http://www.dyson.com
Feb 12, 2012 | Dyson DC04 HEPA Bagless Upright Cyclonic...
DC04 Handle broke on grey cyclone top. I have a new top and need to remove the yellow central cyclone cone from the old one in order to refit in the new one. How do I do that?
Unfortunately we can't supply instructions on how to dismantle the cyclone assembly. However if you wish to purchase a replacement cyclone assembly, you can do so via our online store:
http://www.dyson.co.uk/store/partsDetails.asp?part=ACC-DC04CYCLONE-STD&product=DC04-SY-STD-BC
Alternatively, if you'd prefer to discuss this directly with one of our experts, or to place an order over the phone, you can call us free on 08002980298. Our Helpline is available from 7am until 10pm, 7 days a week.
Kind regards,
Jack
Aug 20, 2011 | Dyson DC04 HEPA Bagless Upright Cyclonic...
Roller does not turn
It sounds as though you need to replace the drive belt. The necessary part is available from http://www.espares.co.uk/dyson/dc04/p/1086/716/4. Fitting it is tricky, but guidance is available from http://www.dysonmedic.com/DC04%20Folder/DC04%20belt%20change.html
Aug 02, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
The DC04 Zorbster runs slow, it still picks up but I am worried it will overheat. If I hit it at the front, the motor picks up speed until the next time I start it up. Can you help???
The problem is likely caused by either (a) a broken or worn microswitch operating lever or (b) a faultyt microswitch. With the bin removed, the lever becomes visible just above the filter upon which the base of the bin normally rests.
Replacement of either part necessitates dismantling the appliance. The necessary parts are available from http://www.espares.co.uk/parts/dyson/dc04-zorbster/p/1086/716/4/420621
Jun 23, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Apr 24, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
