Question about Toshiba Libretto 50CT Notebook
Toshiba libretto 50 ct wont boot
Toshiba libretto 50 ct wont boot. Then takes some time before I can turn it off then it beeps numerous times before turning off.
    Habit-Forming:
    Scholar:
  • 69 Answers
I haven't encountered multiple beeps on shutdown - but multiple beeps on startup is usually an indication of a memory issue. Frequently can be resolved by simply taking memory modules out and re-inserting them.
If problem continues, may need to replace memory chip. If more than one chip, put one in at a time and startup to see which chip is causing the problem.
Not sure, based on your description of the problem, if this is the issue - but certainly worth a try.
Best of Luck!
Posted on Jan 03, 2013
SOURCE: Upgrade the Toshiba Libretto 50 CT
if you want to improve the speed of your laptop you could buy a faster harddrive with an higher rpm per minute than the one installed in the unit, that WILL speed up the system:), and yes its possible to boot from the 2gb flash card but i recommend if you are going to use a flash card you get a bigger one:)
Cheers
Posted on Jan 04, 2009
fossildude
  • 832 Answers
SOURCE: toshiba satellite L300 wont boot
hi thanks for using fixya!
I suggest that if you could do a full scan (anti-virus) to your system. Then, do the disk defragmenter on all your drives, especially the system drive.
the last option is to reformat your system/laptop.
If you need further assistance, let me know.
pls rate me positively! thanks!
Posted on Apr 01, 2009
marketex
  • 371 Answers
SOURCE: toshiba laptop satellite a75 s209 when i turn on, won't start
Hope these helped you.
Posted on Apr 18, 2009
Basilio00920
  • 155 Answers
SOURCE: Toshiba wont turn on, has beeping after i press power
Check the memory modules. Test one at a time to see if any of them is damaged. If you have only one, try a borrowed chip, or test yur modules in a borrowed laptop (it doesn't have to be the same brand/model, only the chips must be the same speed).
Posted on Apr 28, 2009
  • 14 Answers
SOURCE: my toshiba M45 takes several times to turn on,
what is your operating system? if you're familiar of what you're using, then it might be a hardware issue, please be specific,
if you're using windows, try running your OS to safe mode by turning it on and pressing F8 after bios load, it might be your Operating System is corrupted...
Posted on Mar 18, 2010
Reset to factory default
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
May 19, 2012 | Toshiba Libretto 50CT Notebook
My toshiba libretto laptop won't turn on how do i fix it
first, I will advice that you check the adapter, see if its still working. The adapter might be the reason your laptop is not working.
If you have confirmed that the adapter is still good, let me know so that I can direct you further.
Take care.
May 28, 2010 | Toshiba Libretto 50CT Notebook
Need to boot into BIOS to change IDE setting. No Floppy drive.
hi
To enter the BIOS during start-up press the ESC-key while switching power on
hope this helps :0)
May 19, 2009 | Toshiba Libretto 50CT Notebook
I cant reformat my Toshiba libretto L3. I tried everything
You cant boot from cd. Try changing the boot order in the BIOS and allow the CD to have ownership over the Harddisk Drive. This way the computer is forced to boot from the CD.
Jan 16, 2009 | Toshiba PA2502U - Libretto 100, 110,...
Screen has no power
1. take a flashlight and light on the display after you started the computer and waited for about 5 minutes, if you can see the windows environment the inverter needs to be replaced (normally it's in the display frame under the display)
2. attach an external monitor to the laptop and boot. if the monitor shows something you don't have a defective graphic-card (maybe you must push fn + one of the fn-buttons showing a monitor)
if you don't get anything displayd by an external monitor the graphic-card might be defective - you would need a "new" motherboard then
Jan 12, 2009 | Toshiba Libretto 70CT Notebook
Cheers
Jan 04, 2009 | Toshiba Libretto 50CT Notebook
Toshiba A105-S101 freezes at start up!
I would first attempt to reinstall the software from the install cd. Your Toshiba support page is recomending a new BIOS upgrade. See below:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1209144&rpn=PSAA2U&modelFilter=A105-S101&selCategory=3&selFamily=1073768663&selModel=1209144|PSAA2U
Dec 25, 2008 | Toshiba Satellite A105 Notebook
Laptop wIll not boot, Beeps 8 Times
check the memory chips, they might not be seated properly. tips..try one stick in the slot, then try the same in the other slot if it doesn't work. then the same with the other memory stick
Jan 30, 2008 | Toshiba Satellite M35X-S3112 PC Notebook
How to overcome 8.4gb bios limit on a toshiba libretto 100ct?
Ok get a program called Partition Magic, I have found you a Tutorial here: http://www.le.ac.uk/cc/dsss/docs/pm4-main.shtml Basically, you divide the 8.5GB into smaller sizes, NO MORE than 4GB, so say 2x3GB, & 1x2.5GB, or whatever suits.. then ya Format each Partition, Make ONE an Active Boot Partition, the rest logical ones. Your actual Size of the drives will be less than the Total due to Formatting information etc. Read the tutorial carefully B4 ya do anything. Ya be using the bigger storage in no time...
Aug 14, 2007 | Toshiba Libretto 100CT (P000249540)...
Toshiba Libretto 50CT Notebook Logo
112 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
