Question about Supersonic 7" Touch Screen MID Tablet
Mi tablet supersonic 7" touch Screen MID no tiene sonido,,que tengo que hacer para que tenga sonido?
Hola gracias por resolver mi inquietud,,estoy tratando de oir videos en mi tablet pero no se olle nada,nisiquiera en juegos,,gravo mi voz y trato de reprodicirla pero no oigo nada,no tiene sonido.
2 Suggested Answers
spshort
  • 36 Answers
SOURCE: supersonic 7" touch screen MID Tablet
You need to flash new firmware you can download LiveSuit and
then look for the correct firmware that is compatible with your tablet.
If you search for How to Flash Tablet there will be a video or instruction on how to do it.
Posted on Jan 15, 2014
Al encender aparece coby y no entra
Probablemente tienes que resetear to Tablet al los ajustes de fabrica.
Si tiene teclas de subir bajar volumen hay que oprimirlas juntas y despues encender tu tablet.
Aparecera un menu de texto para elegir lo que quieres hacer, elige Factory Setting.
Espero te sirva..
Si no tiene teclas de volumen intenta con otras teclas o botones de la tablet.
Apr 07, 2014 | Coby Kyros Tablet
Supersonic 7" Touch screen MID tablet was dropped now touch sensor not working
This may or may not be fixable without replacment parts. The hopeful solution would be to open the tablet and take a look at the ribbon cable for the digitizer to see if it was moved. Check all the cables to make sure they aren't damaged, and are seated properly. You can get parts online such as ebay if you suspect a damaged touch screen. I think these are around $25-$30.
Need tablet repair help?
http://forum.wasatchtechies.com/
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Feb 11, 2014 | Supersonic 7" Touch Screen MID Tablet
Supersonic 7" touch screen MID Tablet
Jan 15, 2014 | Supersonic 7" Touch Screen MID Tablet
Default Password
Its a android based device, so its most probably asking you for the password of the gmail ID you entered in the previous screen.
Dec 03, 2013 | Supersonic 7" Touch Screen MID Tablet
7" supersonic tablet is stuck on the opening android screen and will not boot. The tablet's battery power went empty during the last use and was fully charged afterward.
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
Oct 30, 2013 | Supersonic 7" Touch Screen MID Tablet
Mi problema es que se me ha olvidado el patron de desbloqueo
hola tengo una tablet cruz reader r101 y me olvide el patron de seguridad no puedo ingresar mediante el patron de la cuenta d gmail porque no aparece en mi tablet ,que solucion tendria para utilizar mi tablet,ayudenmeee ,cualquier cosa me escriben a libra23-9@hotmail.com se lo agradeceria .graciasss
Jul 01, 2012 | Velocity Micro Cruz Reader R103
Buenas noches, tengo problema con mi tablet. me sale un mensaje android.process.acore
A mi tambien me salio, no me dejaba entrar a ninguna aplicacion, no lo podia quitar. Tuve que recuperar el sistema operativo para regresar al inicio de fabrica aqui te dice como hacerlo es muy sencillo http://latin.aoc.com/support/troubleshooting.
Te borra las aplicaciones que tengas instaladas pero lo que tienes guardado en tu memoria se mantiene.
No se como evitarlo para, si alguien puede decirme, tks.
Jul 13, 2011 | AOC MW0811 Breeze 8Inch Tablet PC Black
Tengo una toshiba r15 s822 que tiene password en el bios y no se como quitarlo ayuda por favor
If you forgot Windows password, you can create a Windows password reset bootable CD/DVD or USB flash drive to reset your lost or forgotten Windows password, i have created a bootable CD with the tool Windows Password Breaker and reset my administrator password successfully.
Dec 28, 2010 | Toshiba Satellite R15-S822 Tablet PC
La computadora se traba cuando conecto el cargador de la pila
Tal vez hay un problema con el cargador. Normalmente, usted puede cargar la batería con la computadora. Trate de comprar otro cargador. Pero antes de comprar, probar el cargador de nuevo en primer lugar.
Sep 14, 2009 | Toshiba Satellite R15-S822 Tablet PC
Supersonic 7" Touch Screen MID Tablet Logo
142 people viewed this question
Top Supersonic Tablets & eReaders Experts
Paul Bade
alibaba69
Are you a Supersonic Tablet and eReader Expert? Answer questions, earn points and help others
