Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Frigidaire Dishwasher FDB1050REC1 - Washing Indicator Light Blinking
I am currently having a problem with my dishwasher. It is less than a year old. Whenever I try to start a cycle by pressing the start/cancel button, the washing indicator light just blinks and it will not start. Does anyone have any suggestions?
  • 3 more comments
  • changstein Jul 23, 2008
    Washing Indicator Light Blinks - but the darn thing doesn't start. It's closed properly (I hear the click), I've tried turning the circuit breaker on & off. Still just blinks.
  • cr06 Aug 23, 2008
    Blinking "washing" light, cycle does not start... checked water feed, no problem there... door clicks shut fine...
  • Cyndtwo Dec 22, 2008
    Worked fine yesterday. Today, I have the flashing Indicator light. It is one month past the warrenty. Of course. Since it is built-in, I don't know how to check the water hookups.
  • Anonymous Mar 15, 2009
    I have the Frigidaire 1000 series dishwasher. Unit worked fine yesterday. Today when I tried to start another load the washing light just blinks.
  • etombari Mar 17, 2009
    I have the same problem, but there is flooding on the bottom of the dishwahser. Maybe it is a clogged drain? I am going to try and clean out the strainer and drain the pool of water when I get home. The not starting may be a smart feature the dishwasher uses to prevent flooding of the floor.
    New Friend:
Here is what happened, you pulled the door open without pressing cancel and allowing it to pump the water out, hence the "flooding in the bottom". This is just one reason why it maybe blinking, there is a water sensor in the bottom. If your dishwasher is hooked up properly to any decent garbage disposal, run the disposal for about 30 seconds to a minute. This should pump the water out, more like activate a light siphoning affect. It should work as normal. If you are not having luck with that, detach the DW drain get it low and let it siphon.
Posted on Apr 06, 2010
  • 27 Answers
Make sure the water feed is open....although I don't know this make and model, a flashing light at the start of a program is usually always to do with a water feed problem....make sure there is sufficient water pressure at the hose (by closing the tap, removing the feed from the dishwasher and opening tap with hose in bucket) You will be surprised how many times a worn tap washer is to blame for low pressure. A stiff turning tap is always a sure sign of problems.... If the unit is a integrated model, make sure that when you close the door it "clicks"...if it does not activate the door switch properly, there could be a flashing light. Sometimes the integrated units "move" deeper into the enclosure, and the door will not close properly to activate the door switch. Oshie
Posted on Jun 26, 2007
  • 869 Answers
Less than 1 year you call and fix through the warranty.You already paid for Warranty and have a minimum of 1 year parts/labor.Use it !
Please rate this !!!!
Posted on Aug 25, 2008
SOURCE:
FIRGIDAIRE DISHWASHER FDB1050RES0 WASHING LIGHT BLINKING CONSTANTLY BUT MACHINE WON'T RUN
Thank you for your inquiry, William Garrett!
I understand that the washing light on your Frigidaire dishwasher, FDB1050RES0, continues to blink and will not run. You may need to perform a reset on your dishwasher. In order to do so you would need to disconnect power from your dishwasher for roughly ten minutes. This will help clear out any false error codes or miscommunications within your dishwasher. If resetting your dishwasher does not resolve the issue you may need to have an electrical component replaced and I would recommend seeking professional assistance for that. Hope this is helpful. -Matt
Feb 16, 2015 | Frigidaire Dishwashers
Frigidaire dishwasher won't dry dishes. Less than two years old. Seldom used. FDB1100RHM. Could this be the heating element? Could this be something we could fix?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 05, 2011 | Frigidaire Dishwashers
Washing light is flashing and dishwasher won't start
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jun 19, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
Fdb1050rec1 frigidaire dishwasher door leak
I think you most likely have a basin Float water level sensor that is no working correctly, the door seal is not water proof, if the water level gets over the lip of the basin it will leak on the floor.
May 01, 2017 | Frigidaire Dishwashers
Can't find the model number on Frigidaire dishwasher
The nomenclature should be located on the left side on the inside of the tub right by the front when you open the door. It is most likely an fdb series example fdb1050. however the drain hose pn 154606701 is the factory replacement for most frigidaire dishwashers ten years or less.
Mar 31, 2009 | Frigidaire Professional Series 24 in....
Runs forever! even on Normal wash...help !!
Check to make sure you heating element has not failed. Dishwashers of today heat the water periodically through out the cycle and if the element has failed. The heating delay light is the indicator that tells you that it is trying to heat the water.
Feb 26, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Washing and Drying lights blinking.
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Drain is clogged at the bottom or bad pump!
I would call service and get along with my life!!
For this problem you will need to use factory service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 15, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Bad impelller on wash pump replace pump motor
Dec 30, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
2,625 people viewed this question
Top Frigidaire Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
