Question about Car Audio & Video
I have a bazooka tube subwoofer, and was told the voice coil bad in it. What could cause this during installation?
    Genius:
  • 1,144 Answers
About the only thing that could cause it would be if they were hooked up while installing and shorted them out some how.. or it was dropped.. test your coild with a DMM and see what the impedence is on them if there good it should read 4 ohm if thats what they are if DVC check both sides. if the read real low then coils are shot.. replace with recone.
Posted on Jan 03, 2013
  • 9 Answers
SOURCE: what up with my subwoofer?
Sometimes the Bazooka tubes have an internal amp. I am not sure of this model but maybe you can Splice in directly to the Speaker Wire and bypass the AMP in the Tube if it has one
Posted on Feb 17, 2007
pjstanley
  • 185 Answers
SOURCE: subwoofers
u have to pay the 100 dollars
Posted on Apr 10, 2008
  • 13 Answers
SOURCE: What size is the voice coil in my 1100w 10" sony xplod sub?
go to the sony website or any dealer website and look at the model number of your sub, punch that in and get the measurement.. mostly gonna be inches.. but then go to google and convert it to mm
Posted on Apr 08, 2009
  • 10 Answers
SOURCE: I hooked up a 2-Ohm dual voice coil 800 watt max
off the same amp? you have two way different sounding speakers man. you can buy 2 identical speakers from the same company and brand and series and they will play differently every time. you have 2 speakers with nothing in common so you will hear a difference and maybe interference because of the different ohm levels.
Posted on Apr 14, 2010
SOURCE: Volfenhag ZX4725 i am buying this subwoofer and
No the LOWER the resistance the MORE Output or Draw, If say it is 100 Watts into 4 Ohms, if you used a 2 ohm speaker it would draw 200 watts.(only if capable of delivering that amount of power) The LOWER the Resistance, the HIGHER the Current Draw. WATTS = AMPS x VOLTS. (This is not strictly true with amplifiers output though, as it is an AC Current, and a "Reactive" load, it has, Inductance, Capacitance and Resistance, all in one.and is worked out via a Formula) see below. http://en.wikipedia.org/wiki/Audio_power
http://www.hometheaterhifi.com/volume_1_1/v1n1spk.html
Now with Dual Voice Coils, Essentially, you can think of these speakers as TWO speakers in ONE enclosure. As such, They are basically TWO Speakers. Please see the website below it explains everything for you. http://www.diyaudioandvideo.com/FAQ/Wiring/
Everything is a function of Resistance and Ohms law.
Current (I) = Voltage (E) divided by Resistance(R).
Voltage = Current Multiplied by Resistance.
Resistance = Voltage divides by Current.
Posted on Apr 17, 2010
I have a s12l7 only one voice coil will work
sorry to say you have burnt on of the coils out open circuit. it probably will not be long now before the other coil blows as they are wound together and one can damage the other during burn out.
Apr 10, 2011 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
I have a subwoofer in my truck. 2 speakers in a box with an amp. One of the subs blew to a song that just came on. the volume was high. Sounds distorted. Any way to fix?
Sounds like the voice coil of that woofer overheated and melted while it was turned up too far. Now that area rubs on the magnet or pole piece internally and makes noise.
No you generally can't fix that except for a few high end woofer brands that have field replaceable voice coils that you can buy. Most subwoofers physically bottom out and sounds really bad before experiencing thermal damage like that. Sounding bad is a warning sign that it's being overloaded.
Note that woofers have 2 different types of overload conditions that can cause damage.
1. Over excursion from deep bass that moves the woofer cone too far and damages the suspension. This is clearly audible. Proper box design and user knowledge will prevent this.
2. Thermal limit. This is the published power rating that the voice coil can absorb without damage. Things can melt or fail entirely if this is exceeded.
Either of those issues can cause the noise you are hearing. Without a more detailed description of what happened or how it sounds before, during and after this is much detail as I can provide. But.. move the woofer some by hand, do it evenly pushing straight down evenly on both sides, not too far, go about half way through it's normal movement. If it clearly rubs and makes noise internally then the voice coil is damaged or if has some debris stuck in there. Most woofer are not serviceable.
There are many other factors that affect the longevity of the woofer, such as
  • Ambient temperature too high
  • Limited air flow has inadequate woofer cooling
  • UV exposure can make the surround material brittle
  • Proper enclosure design is needed to acoustically and physically supports the woofer to prevent bottoming out, particularly at the system resonant frequency.
  • Amplifier distortion can kill speakers even when rated far below the woofers max wattage.
Nov 28, 2010 | Sony XS-AW200 Car Subwoofer
Hello the bazooka power wont come on
So it is a powered tube, yes? Can't remember, does the Bazooka have a fuse on it? If it is powered, you blew the board.
Apr 07, 2010 | Bazooka BTA8200 Car Subwoofer
Checking voice coil
Are the connection tight? Do you have a good ground? Does the coil, when pushed down gently, move freely? If it moves rough, the coil is bad. check those.
Mar 31, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
Popping during action scenes at moderate volume
the woofer is being overdriven and the voice coil is hitting the magnet structure.eventually it will damage the coil end and it will scrape in the gap.
May 14, 2009 | AAD C10 Subwoofer
Bazooka BTA series self-amplified tube subwoofer wont' power on
the blue wire is called the remote wire will go to back of head unit also to a bule wire that will send 2 amps to turn on the speaker only when the head unite is on
Apr 18, 2009 | Infinity BASSLINK Car Subwoofer
Amp is a mtx 801d not sure
no you will not blow it out by hooking up both voice coils. But First before you do, what oms are they. and is your amp one oms stable? There a lot of ways you can wire double voice coil. But if you can get me that info i can send you some digrams to help you out and tell you whats best.
Oct 05, 2008 | MTX Thunder TA7801 Car Audio Amplifier
Subwoofer problems
What started smoking the Sub or the amp?
Oct 08, 2007 | Car Audio & Video
What up with my subwoofer?
Feb 06, 2007 | Bazooka BT6014 Car Subwoofer
Car Audio & Video Logo
53 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
