Question about HP Office Equipment & Supplies
Invalid Nand Size Press any Key" then when key pressed "Eeprom Not Found Press Any Key
  • 13 Answers
SOURCE: message on screen
do you have a floppy disk in it? or is it set to boot from the cd drive, with a non-bootable os disk in it?
those errors usually happen when you computer does not find a os system in the device it is set to boot from. Try setting it to boot from the hard drive.
Posted on Dec 07, 2007
  • 4 Answers
SOURCE: need help with my laptop
Did you laptop come with a RESTORE CD or DVD?
Look for the application on the media that came with the laptop.
You can also get it online
ONLY for AMI BIOS and Windows NT 4.0.
ftp://ftp.necam.com/pub/Catalog/3620/HDPrepNT.exe
HDPrepEZ version 1.9 for AMI BIOS. Supports FAT32 partitions.
Windows 95, Windows 98
ftp://ftp.necam.com/pub/Catalog/3646/Hdprepez19.exe
This is the page with all support downloads for your LapTop:
http://support.necam.com/downloads/
Select you type / make / model and you will have access to all service releases.
Hope it helped.
Posted on Mar 03, 2008
  • 6 Answers
SOURCE: canon mp-730 print head does not move
it seems you open or unscrew the printer.
this may happen if the mother board has no nigative pole.
you have to reset the mother borad.
cannot do that from the available options
the reseting procedure is to take the motherboard out and you have to shortcut the battary for 10 seconds.
re install it , and try it
Posted on Mar 26, 2008
hashir4u
  • 79 Answers
SOURCE: Printing envelopes
Print on the Envelopes
  1. Click File , then click Print .
  2. Click Properties , then click the Features tab.
  3. Change the orientation to Landscape and the paper size to envelope #10 .
  4. Click OK .
  5. Click OK again to print.
Posted on May 27, 2008
Ajkill
  • 2035 Answers
SOURCE: No printing
  1. Snap the cartridges in and out of the printer a couple of times.
  2. Clean the copper contacts with a dry cloth.
If this did not work then you need to give for service shop ,if they charge more than $50, you can buy new printer for the same charge..
Posted on Aug 17, 2008
Tip
A Simple Way to Increase, or Decrease, Text Size
An easy way to increase or decrease text size on most any type of Windows software is to rest your cursor over the software you are using, press and hold the Ctrl key, and then scroll the wheel on your mouse forward and backward. Pushing it forward increases text size, and going backward decreases the text size. You can also press and hold the Ctrl key and then hit either the "+" or "-" key for the same results!
on May 24, 2014 | Computers & Internet
Tip
How to format and instal a window xp
1.Insert your Windows XP installation disc into your CD drive<br /><br />2.Now as you computer boots a little more it will say "Press any key to boot from CD.." press a key to do so.<br /><br />3.The CD will load up a blue screen and then spend a while loading files it needs. When it is finished it will list a few options, mainly "Press ENTER to set up Windows XP." Press Enter or Return.<br /><br />4. Now you will be at a screen to select where to install Windows to. This is where you can delete old partitions and format drives. The box in the bottom half of the screen shows all your drives and the partitions that exist on them. Use the Up and Down arrow keys to highlight your "C:" partition and press the 'D' key (if all that shows up is "Unpartitioned space" and you have no C: or D: partitions, skip this step). On the next screen press the 'L' key to finalize deleting the partition.<br /><br />5.Now you are back on the screen to choose where to install Windows. The box on the lower half of the screen should no longer show a partition but simply have an entry "Unpartitioned space xxxxxMB." Select this with the arrow keys and press the 'C' key to create a partition on the drive. The next screen tells you the minimum and maximum sizes the partition can be and lets you pick the size. The default size is the maximum, but double check that the number entered is the maximum and hit enter.<br /><br />6.Now you will again be back at the choose where to install Windows screen. But this time you will have a partition that looks something like this "C: Partition1 [New (Raw)]xxxxxxMB." Highlight this entry and press enter.<br /><br />7.The next screen lets you choose which file system to format the drive with. Choose NTFS as it is faster and more secure. If the drive is brand new and has never been used before then use one of the options that ends in "(Quick)." Or, choose one of the lower down options. Use the arrow keys to select the proper one and press Enter or Return.<br /><br />8. From here you are all set and the installation of Windows will proceed starting with a format of your drive. This will take a while (over half an hour)
on Jun 23, 2011 | Computers & Internet
"wrong cartridge" message appears, new
It could be due to "waste tank full" alarm; you may need to reset the waste tank counter.
I found a reset sequence for a MP730 printer in this website that works for F30 and F50 as well. Try:
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 or F50 printers.
Feb 24, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
Hello k_akima Im tarek boot how are you are you fine I wish you are fine I have casio fx-82es version B I was try to upgrade it I tried this way ......[...the same until...
I'm sorry, but I have no idea what you're trying to do. If you're following instructions given on some web page, then I suggest you refer any questions to the author of that page.
Feb 19, 2011 | Office Equipment & Supplies
Canon mp130 shows error "
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
OR
Reset for mp130
turn on the printer press menu
press scan, copy, scan to enter service mode
use> to get to nvram
set ABS-M level to 0
Set ABS-P level to 0
Press stop to exit..........Done
i hope this help
Jan 26, 2011 | Canon PIXMA MP130 All-In-One InkJet...
How to clean waste tank on MP730 "waste ink tank
  1. press menu - copy - #
  2. Select TEST MODE.
  3. Select [8] PRINTER TEST in TEST MODE.
  4. Select 3. [EEPROM CLEAR].
  5. select 0. [INK COUNT].
  6. press the [OK] key
  7. press stop to cancell
  8. restart the printer
Oct 27, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
I have accidentally turned the child lock on and then turned of the tv and when i switch it back on it comes up locked on the screen and none of the buttons respond and i do not have the remote controll...
Get a Magnavox (or Philips, same company) brand universal remote and try this. I found this info at a tech website, but I haven't tried it myself (never have used parental lock on any set), so I don't know if really a solution.
Philips sets use 0711 as the override code to defeat parent lock. You may need to enter the code twice if it says "invalid code" the first time.
Using the remote control:
Press the MENU key. Scroll up or down until you reach AUTOLOCK or SMARTLOCK. Press the "right arrow" key. Enter code 0711. Enter it again if it says invalid code.
Once in the AUTOLOCK or SMARTLOCK menu:
Scroll to BLOCK. Press the "right arrow" key. Scroll to BLOCKING OPTIONS. Press the "right arrow" key. Scroll to MASTER DISABLE. Press the "right arrow" key. This should unlock the parental control.
Hope this works for you. Thanks for using Fixya!
Mar 12, 2010 | Philips 28PW6305 28" TV
I have a philips magnavox ms2730 c tv 27 inch , my parental lock is enable but i didnt enable it and i cant get it turned off, i was hopping i couldnt find a default password .
I found this info at a tech website, but I haven't tried it myself (never have used parental lock on any set).
Mar 05, 2010 | Philips MS2730C 27" TV
Cannon pixma mp750 - it is telling me "waste ink near full" but i can't find any mention of it in the guide etc. It is not printing at all. Can you help?
Just another little way that Canon have found to get more money from you, would probably cost you at least $150 for Canon to fix, but you can, I think this should work.
Reset Waste Ink
By pressing Menu, Copy, Scan, Copy, Copy
6) Press the [Set] key.
Jul 05, 2008 | Canon Office Equipment & Supplies
669 people viewed this question
Seeker5211
Seeker5211
