Question about Nordic Track NordicTrack Treadmill, A2550
Nordic Track c1800s, Model NTTL99120, runs but the belt stops when I get on it. When this happens the speed indicator falls back to 0. All the other indicators stay the same. Ater it stops I have to pull the safety key out and re-insert it to get it going again just to have it stop again. I've adjusted the speed sensor and the belt tension. No change. I ran the calibration sequence and everything finished correctly except for the second part of Level 2 which has to do power. The test showed that the speed of the machine has been properly set at 10 mph, but when pressing the plus button to run up to 85 it never makes it past 27 before the belt stops rotating. I watched a video of how to adjust a screw on the controller board to increase the power to the motor, and I tried it, but it didn't seem to work right because on retest it seemed to have less power than before. I was thinking of replacing the board. Am I on the right track?
3 Suggested Answers
  • 218 Answers
SOURCE: The Nordic Track machine's controls seem to be
Remove the console from the treadmill and remove the back
remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console
reattach the console and calibrate by doing the following:
1. With the key off press the speed + and stop buttons at the same time and hold
2. place the key on and release the buttons
3. press the stop key once
4. press the speed up til it reaches 85
5. if your max speed is 10 mph then it should read about 9.8-10.2
If the keys will not work then the console is bad and would need replaced.
Posted on Aug 11, 2010
  • 218 Answers
SOURCE: Hello, I have a Nordic Track 2050, and got on this
console is bad no other alternative, check ebay for part
Nordic Track NordicTrack Reflex 4500 Pro Treadmill - My belt speed is running about 60% of the speed displayed. What is causing that? Is there a reset feature?
The treadmill is set for kilometers, not miles.
With the stop button pressed, insert the safety key/magnet. This will display miles (or Kms) and hours of use.
There will also be a "M" for metric or "E" for english, or miles. Use the speed up/down buttons to adjust to "E".
Oct 01, 2017 | Nordic Track Exercise & Fitness
Why wont it run?
Is the motor running? If not, is it receiving power? Is the belt slipping? If motor has brushes, they might need replacement.
Nov 18, 2015 | Nordic Track APEX 6100XI TREADMILL Console
Belt stops while using nordic track c2255
this happen to due the lack of maintenance according the schedule manintenance. see the video and proceed.However if after you did, the problem remain,is TIME to replace the old board deck. God bless you
Mar 26, 2013 | Nordic Track NordicTrack A2350 Pro...
Nordic Track T5.3 is does not run only inclines to the highest level and back down, what could be the problem?
please RUN the software calibration and fix it
.God bless you
The Steps for Newer Style Console Calibration
1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10. Press ENTER. You should see "SS" or "55" in the console.
11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Mar 13, 2013 | Nordic Track Exercise & Fitness
The Nordic Track machine's controls seem to be stuck. If I press any button other than "3 mph", it fails to respond and nothing happens. However, when I press the 3 mph button, it will only stay at the 3...
Jul 22, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track C2000 starts and then stops.
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the current over load circuit to activate thus shutting down the unit to prevent further damage, Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit shut down again then you will have replace the running belt and possibly the deck
May 21, 2010 | Exercise & Fitness
My nordic track treadmill's walking belt stops when I start walking on it but the motor is still running although the front roller is not moving when I start walking on the walking belt. Do you think the...
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
May 17, 2010 | Nordic Track Exercise & Fitness
How do i get a nordic track c1800s owner's manual?
Find the complete model number of your treadmill. Lift and lock the walking deck. The model number will be on a decal on the main frame of the machine. Go to iconservice.com, click on manuals, and enter the model number.
Mar 08, 2010 | Exercise & Fitness
Nordic Track NordicTrack Treadmill, A2550 Logo
41 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
