Question about Medion md40298 Notebook
Wireless Internet Brought a D-Link router (DIR-615) and is connected to surboard cable modem. My medion (E1210) laptop computer will let me log in to my network but when I go into internet explorer it tells me that it cannot disply the webpage. My home computer is working fine. Optus told me that I need to get my medion laptop configured for wirelss internet.
My Dir 615 router always looses internet connection to my wired computer
Try to upgrade the routers firmware.
http://www.dlink.com/us/en/support/product/dir-615-wireless-n-300-router
Jul 19, 2013 | D-Link Computers & Internet
How to connect TP LINK TL-WA901ND with Dlink DIR 615
Have you set the TP Link TL-WA901ND IP to have 192.168.1.1 as the default gateway ?
Also DHCP server is where ?
IN the TP LINK TL-WA901ND or in DLINK DIR 615
Only have one Router running DHCP and set the default gateway in the leases as 192.168.1.1.
What subnet mask are you using is it the same through out all devices ?
Oct 30, 2017 | TP-LINK TP link TL-WA901ND 300 / 11n...
I'm trying to connect a D-link DIR-615 router to my inlaws computer. They have an old motorola external modem which works fine, the new router is connected properly to the power suppy, ethernet cable from...
You haven't mentioned who is your Internet Service Provider (generally motorola modems are used by cable connections). After connecting the cables properly, you power cycle the modem and the router if this is a cable connection. However, if this is a DSL connection you better contact the ISP and fetch further information. Please contact me again if you need further information.
Apr 24, 2011 | D-Link DIR-615 Wireless Router
I have followed instructions (several times) to connect my dlink router dir-615 and once I unplug the ethernet cable and attach to dlink (blue slot 1) and plug in power to the router....it no longer can...
the blue socket should be connected to your modem, it is this modem that supplies the internet for your router to distribute to your computers so if you disconnect the blue cable from your router you are disconnecting the internet
Apr 17, 2011 | D-Link DIR-615 Wireless Router
I can not make my D Link DIR-615 work with Hughes HN9000 modem. The D Link is located at the PC and Hughes modem location so I can wire 1 PC but need the laptop to connect wireless. I tried both an...
If you connect Modem to your laptop, can you go online?
If you are able to go online like that then log onto www.hnetworking.com and we can take the remote access of your computer and try help you out.
Feb 28, 2011 | D-Link DIR-615 Wireless Router
DIR-615 Wireless Router: i have a d-link wireless router dir 615 that i've ...
if youve changed the password on the router since the other computers logged onto the network, then you need to delete the network history from those computers.
Otherwise those laptops will be trying to connect to the network with the old details.
May 16, 2010 | D-Link DIR-615 Wireless Router
I have a dir-615 router and have been able to establish a wireless network but cannot get the network to connect to the internet.what can I do?
I assume you have a cable or a DSL modem connectec by a LAN cable to the wireless router.
Have you checked you with your ISP to see if the connection yo your modem is OK?
Have you check the LAN cable from the modem to the wireless router is good and it in plugged into the WAN/Internet port on the wireless router?
Have you installed the latest wireless card driver in the computer/laptop?
For instructions on setting up the wireless router and the wireless card in the computer/laptop, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance please leave me a comment.
Dec 23, 2009 | D-Link DIR-615 Wireless Router
Connection, via D-Link Dir 615, lost after restarting computer
Did you tell Vista to "automatically connect to XXXXX network whenever in range" ?
Oct 20, 2009 | D-Link DIR-615 Wireless Router
Using a HN9000 modem and D-Link dir 615 together
change your routers IP address to IP address. 192.168.1.1.
Jun 06, 2009 | D-Link DIR-625 (790069292637) Wireless...
Medion md40298 Notebook Logo
150 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
