Question about Kenmore 62882 Electric Dryer
Kenmore dryer ( gas )
Hi My dry starts & runs for about 10 min. and then starts to get cold never turning off just gets cold. but when it satrs its hot.I checked the stat its ok the fuse is ok. The hi limit I checked that works.what would make the dry to stop heating ? Thank you,
  • Randy Henson Jun 29, 2007
    I thank you that repaired it.
    Scholar:
  • 76 Answers
Camaro Most likely the problem is bad gas valve coils located on the top of the gas valve . Unscrew the two screws holding the coil bracket and replace the coils. The part number for the Whirlpool gas valve coils is 279834. Good luck Gendos, post back
Posted on Jun 27, 2007
SOURCE:
The dryer will run fine with no heat but when you try to dry with heat, whether its high or low, it runs for about 5-10 mins, with out getting warm and then shuts off and all the lights flash on it
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 15, 2011 | Kenmore 84152 Electric Dryer
You have answered this question before but does the ignitor stay on during the drying cycle? Kenmore series 80, model 110 72822101 gas, It starts correctly, ignitor glows, gas ignites,run for 5 to 6 min....
yes..
heatman101
Aug 07, 2011 | Kenmore 72802 Gas Dryer
Kenmore gas dryer will heat but not enough to dry anything?
First and foremost check your vent! Make sure it is nice and clean and clear especially if the clothes are coming out warm and damp at the end of the cycle.
If the clothes are cold at the end of the cycle or you find the dryer stops heating about 15 or 20 min after you start it then you will want to replace your gas valve coils.
If you need more help in replacing the coils feel free to ask!
Jun 12, 2010 | Kenmore Dryers
Kenmore mod 110 87870110 gas dryer- at first push
the vent could be plugged and unit is going into thermal overheat if it works in timed dry properly then the moistier sensor is faulty.
Dec 01, 2009 | Kenmore Dryers
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
My kenmore gas dryer turns on and lights runs about five mins. hot and then starts blowing cold air and ignitor keeps glowing on and off but wont light flame
see if the thermal bulb is located in the path of the flame, and if it is you will have to change the gas thermal sensing bulb.
Aug 14, 2009 | Kenmore Dryers
Gas never ignites in any cycle in a 10yr old Kenmore dryer.
Chances are your igniter has gone bad. It must pull atleast 3.2 amps to open the gas valve and ignite the gas. A new igniter could probably purchased for 20 or 30 dollars.
Mar 13, 2009 | Dryers
Kenmore 90 Series Gas Dryer that drys for 10 mins & shuts off...
Check the vent pipe going to the outside of the house, including the vent louver, to make sure the pipe is not partially or fully clogged with lint.
Your symptoms are a classic description of reduced or no airflow from the dryer.
Jan 09, 2009 | Kenmore 62802 Electric Dryer
Kenmore 62882 Electric Dryer Logo
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
