Question about Ovens
I have a GE built in oven, model jtp15woa2ww, serial number hz6 860550. It is about 13 years old. The bottom bake element melted yesterday, about four inches. Is the oven worth repairing? Can a r
ranger25
  • 72 Answers
SOURCE: GE Oven bake element not work
It sounds like a problem with the selector switch. You have to remove the back panel to get to the back of the switch in the head unit, and find what wire goes from there to the bake element. With a meter set on 240ACV, or whichever setting is on yours that's HIGHER than that i.e. 400ACV, with the red probe on the terminal and the black one going to ground, see if you are getting 210-240 through it. If so, then it's either a faulty neutral wire connection (the other wire coming out of the element) or the selector switch. Hope this helps.
Posted on Jan 29, 2008
dgjtex
  • 405 Answers
SOURCE: Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Posted on Dec 27, 2008
kachbibi1
  • 979 Answers
SOURCE: Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Posted on Jan 30, 2009
mreid542
  • 166 Answers
SOURCE: We need to replace the baking heating element of
Yes you can - yes it is worth it. First unplug or turn the breaker off to your unit. The bottom bake element is held in by 2 screws at the back of the oven. remove both of them and gently pull out the element a little. there are 2 wires attached to the element either by 2 more screws or push in connectors.
A lot of the time you can see where the element is burned out but sometimes you may have to check it for continuity with an ohm meter to tell if it is bad.
Posted on Jul 20, 2010
Testimonial: "this gives me courage to go the next step! Thanks"
SOURCE: GE Oven JTP15BW Broil Element on, Bake Element off during baking.
I have the same problem. Just swap the 2 wires that are marked as 'broil' and 'bake' on the controller board. But sometimes it switches back, then I have to swap the wires again.
You might want to leave the 'broil' post unconnected to prevent burning food..
Posted on Jul 27, 2010
Hello, I have a GE double oven. Model JKP36 002wh. Tonight the baking element literally burned itself in two and a small part of it is welded to the bottom of the oven. It made a loud pop and then...
This is a common problem as it is the first part that comes up for your model number...
here is the part
http://www.partselect.com/PartDetail.aspx?Inventory=249424&SourceCode=5&ModelNum=jkp36
Those parts do fail and for a few bucks you can be going for another three years or more...
heatman101
Feb 16, 2011 | GE Ovens
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Dec 27, 2008 | GE JKS05 Electric Single Oven
I have a self-cleaning GE Oven, model # jkp06001av, that is about 30 years old. The lower heating element has burned out. I need a part number and a location of the nearest supplier (zip code 30084,...
Hi. Not too familiar with your area, but you could give BOB BAILEY'S TV & APPL.
5100 Hwy 78
Stone Mountain GA 30087
770 979 1077
Approx. 4.7 miles
a try to get your WB44X200 bake element. (Yes, 30 + years,..... had to go bad into the microfische to find that part number) Part is still available and is rather easy to change yourself.
Oct 08, 2008 | GE Profile JTP56 Electric Double Oven
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
97 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
