Question about Dimplex Heating & Cooling
Electrolog heater stops after 2 minutes
Comes on, but shuts down and smells hot
3 Suggested Answers
SOURCE: I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Posted on Nov 18, 2009
  • 70 Answers
SOURCE: Heater runs for appox 2-4 minutes and then shuts down..
what kind of furnace do you have? Is it electronic or standing pilot? If you have electronic then it could be flame sensor if you have standing pilot and the pilot goes out and you have to relight then it is probably the thermocouple what is going through an 1/2 flex pipe explain this a little more. Have you checked filter.
Posted on Jan 22, 2009
Why does the heater smell and not get hot enough?
The smell is dirt or dust on heating element. If not hot enough it is because the thermostat may be prematurely shutting down.
Nov 22, 2015 | Heating & Cooling
Rinnai RL94i - Produces hot water for 3 minutes, then stops
I just had this exact problem. It kept getting worse until we had no water. Our Rinnai tankless hot water heater started the same way though, with hot water for a few minutes and then would shut off with an error code 10. We just had to shut the hot water off and then back on, wait a minute or so and we had hot water back for a few minutes. Our unit would come on with a loud vibrating noise and remain until it shut off with an error code 10 (air flow fault). The solution was to remove the blower fan and blow out the squirrel cage. Ours had moths in it. We also vacuumed out the fan housing. Be careful to mark any wires you disconnect and take pictures before removal. Our unit is now almost silent when it comes on and supplies endless hot water.
Jun 10, 2014 | Rinnai RL94i Tankless Water Heater
2004 subaru outback, heating system acting up
Thermostat Stuck on warm up & or you have
a possible head gasket failure & I would suspect
a loss of coolant.
If that is the case, you have a ruined exhaust converter &
O2 sensors as well & a $5,000 plus repair bill coming
Mar 05, 2014 | 2004 Subaru Outback 2.5
2002 ford escape periodically over heating
Check the thermostat and the fan too. Overheating nothing to do with the heater core, even if you shut the heat off, the car should not overheat
Mar 20, 2013 | 2002 Ford Escape
Help with error code
Before calling service technician, open following link for Rheem tankless troubleshooting resources including error codes and typical maintenance:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Mar 20, 2012 | Rheem Tankless Hot Water Heater...
My heater runs great for about 15-20 minutes and then raw diesel comes out and it shuts down. I thought maybe the tank vent might not be working right so I tried running it with the tank cap off and it...
The transformer gets hot and stops making spark... then fire goes out....transformer cools down and it works till transformer gets hot...
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 02, 2011 | Reddy R155D Utility Heater
My reddy heater comes on and burns perfectly for up to 30 minutes then it shuts off and blows smoke for a couple of seconds before it completely shuts down.
This doesn't help. There at least 4 60k Reddy Heaters models -some are spark plug heaters, some have the new Hot Surface Ignitor technology. All heaters have specific model. Without you knowing the model I can't help, sorry.
Mar 14, 2010 | Reddy R60A Utility Heater
Oct 19, 2009 | Tower Lasko 30 Inch Ceramic Oscillating...
Marco gas fireplace shuts off
This an easy fix. What you must do is remove the dust from the pilot safety. I use rust buster from ace hardware to gently flush the hole. If ther is no hole just shoot a tiny drop or 2 into the pilot burner where the flame comes out. Blow it out (I use a piece of tubing). The problem is the dust drops the pilot flame to a point where it won't heat the thermocouple hot enough to jold the magnet and after 30 minutes she quits. THIS is a picture of where to clean the ODS pilots in your rig.
Oct 19, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
235 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
