Question about Indesit 24 in. D61 Free-standing Dishwasher
INDESIT DISHWAHSER DG5100W
WE HAVE JUST REPLACED THE PUMP AND NOW IT WILL NOT FILL PROPERLY AND THE HEATER DOES NOT COME ON
  • 27 Answers
If it does not fill properly to a certain level, the heater will NOT come on, so you need to solve the filling problem. Is the drain hose raised sufficiently? Is the pressure hose blocked? Does it let water in and then just stop? Oshie
Posted on Jun 26, 2007
SOURCE:
I have a indesit iwb71250 that the red door lock light is on constantly but we can open the door and shut although the machine will run it wont fill with water... any ideas
May be the switch is loose try fixing it with ascrew driver or the rubber hose is not fixed properly and the machine pump is taking air or the pump failure
Oct 19, 2014 | Indesit IWB71250 White 60 cm Washer Front...
Tip
List of codes for Hotpoint, Creda, Ariston, Indesit, Cannon
Appliance tagged Hotpoint, Creda, Ariston, Indesit, Cannon are all distributed by the Indesit appliances group.
All this brands share parts, they share the same error code list, and the service is provided by same centres.
I will publish a list of error codes for Hotpoint, Creda, Ariston, Indesit, Cannon.
Washing Machines and Washer Dryers
  • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
  • F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
  • F12 - No mixed fill. It is likely that the water is not turned on at the taps.
  • F13 - Check the water supply, inlet valve and hot and cold hose connections.
  • F14 - A fault with the water heating has occurred
  • F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked
  • F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more.
  • F17 - Door not closed properly. Close door firmly at 3 o'clock position
  • F20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing
  • F30/31 - A motor drive problem has occurred. Try running the programme again. If the problem persists book service
  • F40 - Water below protection level during a heat step
  • F41 - Water level detect sequence incorrect
  • F50/51 - Customer language and wash programme have not been saved. The system will run with default conditions (1000rpm max and English language).
Fault codes for LCD EVO1 Washers
  • F01 - Short circuit motor triac
  • F02 - Motor jammed tacho detached
  • F03 - Wash thermistor open/short circuit
  • F04 - Pressure switch jammed on empty
  • F05 - Pressure switch jammed on full
  • F06 - Program selector error
  • F07 - Heater relay stuck
  • F08 - Heater relay cannot be activated
  • F09 - Incompatible eeprom
  • F10 - Pressure switch not sensing correctly
  • F11 - Pump cannot be activated
  • F12 - Communication error
  • F13 - Dryer fan or dryer thermisotor fault
  • F14 - Dryer element fault
  • F15 - Dryer element relay fault
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock
Fault codes for LCD EVO2 and V4 Washers
  • F01 - Motor traic short circuit
  • F02 - Motor jammed or tacho detached
  • F05 - Pressure switch jammed on full - Check pump for blackages.
  • F08 - Heater relay stuck
  • F09 - Setup error
  • F12 - No communication between cards
  • F13 - Drying thermistor open/short circuit
  • F14 - Drying element faulty
  • F17 - Interlock error
  • F18 - Communication error
  • H20 - Not filling. Check tap, hose and inlet valves
Fridges and Freezers
  • F1 - Freezer thermistor open circuit
  • F2 - Freezer thermistor short circuit
  • F3 - Fridge thermistor open circuit
  • F4 - Fridge thermistor short circuit
  • F7 - Evaporator thermistor open circuit
  • F8 - Evaporator thermistor short circuit
  • F9 - Temperature set switch open circuit
  • FA - No feedback from Baffle
  • FB - Fridge Baffle motor operating continuously
  • FE - Defrost time out
Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level.
  • F20 - Temperature under range
  • F21 - Temperature over range
LCD Dishwasher Models
  • A01 - Float switch
  • A02 - Open/Short circuit heater relay
  • A03 - Short circuit on thermistor or Time-out drain- Check filter for blockages then book a repairif the problem persists.
  • A04 - Unable to reach or sense temperature within 70 minutes
  • A05 - Pressure switch has not been reset
  • A07 - Open/Short circuit wash motor triac
  • A08 - Open/Short circuit auxiliary wash motor triac
  • A09 - Open/Short circuit with main wash traic
  • A10 - Open/Short circuit fill valve traic
  • A11 - Half load valve traic or alternating motor action
  • A12 - Open circuit heater rely
  • A13 - Open/Short circuit dispenser traic
  • A14 - Drain hose too low causing syphoning. Check drain hose.
  • H20 - Check tap and pressure of incoming water.
Hotpoint Tumble Dryers
  • F1 - The level of required dryness has not been reached within the time period. Check that the correct programme has been selected
  • F2 - Thermistor or sensing circuit failure
  • F3 - Heater plate over temperature. Check the filter and vent hose for a possible blockage
...Follows--->
on Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have an indesit 1wb71250, the man on indesit repair said i need a new pump, how do i do i repair that?
unless the pump is just blocked ( remove blockage ) the pump cannot be repaired only replaced with a new one .
Jan 23, 2013 | Indesit W 123 Front Load Washer
Bosch she4am16uc/01 not filling with water, can hear what I think is teh pump starting then it just sits there. Autoclean light just flashes and I cannot reset the dishwahser... any recommendations?
pull the dishwasher out and look inside the pan you more than likley have a leak and this is why it is not filling it has a safety so when it leak it will not fill with any more water.
Dec 27, 2009 | Dishwashers
A05 code
Indesit Error Messages and Error Codes Indesit Dishwashers
  • F11 - Heater timed out. The heater has not reached the required level. Book a service engineer.
  • F20 - Temperature under range. Book a service engineer. .
  • F21 - Temperature over range. Book a service engineer.
Fault codes for Indesit LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
_uacct = "UA-1207243-4";urchinTracker();
Sep 14, 2008 | Indesit 24 in. DE73 Evolution...
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Indesit dishwasher.
It sounds like the anti flood switch is activated, lean the dishwasher back at a 45 degree angle. If water comes out the back you have a leak. Stand it up and try it try dishwasher, if it works this comfirms leak, you will need to find where it is coming from.
Dec 03, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Help with how to use properly a dishwahser.
You either have a blocked drain or pump or check to see if the water tap is turned on. It means that either the water wont pump out or fill with water. Good luck
Sep 27, 2007 | Miele Advanta G2020 Dishwasher
Indesit 24 in. D61 Free-standing Dishwasher Logo
839 people viewed this question
Top Indesit Dishwashers Experts
Marvin
Marvin
Paul Bade
NOEL
NOEL
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
