Question about Konica Minolta Bizhub C250 C252 C300 C352 Control Panel - Tested & Working
Bizhub c252 error code c2555
My bizhub c252 displays "Malfunction was Detected " "CS Care will call the service centre" C2555 How can i fix this?
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
Posted on Dec 20, 2007
Cogz
  • 1326 Answers
SOURCE: copier not working
Is the copier a Minolta? If so what model there are different ways to rest code.
Posted on Feb 10, 2008
Nitrotrike
  • 589 Answers
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
  • 6 Answers
SOURCE: bizhubc250
C2555 means yellow TCR sensor problem.
solution, make sure the yellow toner is not empty.
try to pull out the yellow IU then shake it, and put it back.
Posted on Aug 09, 2008
taminol
  • 62 Answers
SOURCE: BizHub C252 - error Code C-2555 (Malfunction Detected)
C-2555 relates to a low toner density in the yellow imaging unit. I'm sure your daughter pressing buttons did not cause it.
I suggest you release the yellow imaging unit (the bottow row of units)
Just realease and pull it out a little way. Then switch the machine on with the door open. It won't start, but will ask you to shut the front door. Reseat the yellow imaging unit and shut the door. The machine should go in to a stabilization mode and then work.
However, if it comes back, I suspect a new yellow imaging unit will be required.
Posted on Feb 07, 2009
Error c2555 in konica minolta c250
I presume that you want to know what this code means rather than just telling us that you have it!! Search online for "error code c2555 Konica Minolta". Try the fourth hit and onwards.
Jul 11, 2015 | Konica Minolta BizHub C252
Where is the ATDC sensor
If you replaced the developer unit then you already replaced the ATDC sensor. using third party toner or KMBS? if so use only KMBS
Jul 25, 2014 | Konica Minolta Bizhub C360...
Error c2555
replace the yellow image unit
Mar 01, 2014 | Konica Minolta bizhub C250 All-In-One...
C2555 solution
C2555: Abnormally low toner density detected yellow TCR sensor
replace yellow imaging unit
Jan 15, 2013 | Konica Minolta Bizhub c203 Copier
Bizhub c450 error c3752 Guillemin
Fuser Heat Error. Sometimes this code can be cleared by using the reset procedure outlined below. If the code returns then you will need to have the unit serviced.
Reset Procedure:
1. Turn main power switch OFF.
2. Turn main power switch ON while pressing the Menu/Select key.
3. Keep pressing the Menu/Select key until the LED turns OFF on the control Panel.
4. Check to make sure that "Trouble Reset" is displayed on the control Panel
after LED turns OFF.
5. Pressing the Menu/Select key.
6. Check to make sure that "OK" is displayed and the it has been reset.
7. Turn main power switch OFF and ON again, and make sure that the machine properly
starts.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 16, 2010 | Konica Minolta bizhub C450P Laser Printer
Konica bizhub 250 error c255c
there is no c255c code but if it is a c2555 c2556 c2557 or any other c255 code it may need a new image unit. please give more info
Oct 08, 2010 | Konica Minolta Bizhub c203 Copier
Our KonicaMinolta Bizhub C280 Internal Error C2555
You didn't mention the size of the job size, but it sounds like a memory problem. If you have a service contract or it's still under warranty, contact your rep before you start opening things up.
The following is if you don't have a service contract. If the bizhub has been working with no problems in the past, try reseating or replacing the RAM. I've had to replace RAM that started causing problems on classroom computers. If you bought it refurbished (used) check to see the 2GB RAM that supposed to come with the bizhub hasn't been removed or replaced with smaller memory.
Feb 14, 2010 | Office Equipment & Supplies
Bizhubc250
Jul 10, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta Bizhub C250 C252 C300 C352 Control Panel - Tested & Working Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
