Question about Boss Rc 50
RC-50: Importing wav. files from computer to loop station.
I'm having problems importing wav. files from my computer into the RC-50. I choose a patch, eg patch 6, and set the tempo to that of the wav. file I wish to import. I set this by pressing 'tap tempo' and then adjusting the value dial to the desired tempo, and then I press exit or write - both seem to store the tempo I want. (I tried to follow setting the value dial by tapping the beat on the pedal as told in the manual, but this just seemed to alter the tempo as I couldn't tap exactly to the tempo I'd just set it to be).
After this I connect to my mac., open up the Roland icon, open the Wave folder, and drag the wav. file into the folder, ensuring it has been saved in the correct format (16bit, 44.1KHz, no compression format) and written in the correct format, eg 006_1.wav. I then eject the Roland icon from my computer and remove the usb cable (I found that I had to remove the cable for the RC-50 to recognise disconnection). I then go to play the imported wav. file and notice the time left on the patch is 4 mins less than before (indicating that my 4 min wav. has been successfully imported) but when I press play/rec/overdub pedal, nothing is to be heard and there is only a flat line below the word 'phrase' in the display window, where there should be the small circle which indicates there is a loop stored there.
I have only had success on two occasions, the first time I had to delete the imported wav. because the levels were wrong within the wav. file, and the second time the RC-50 was playing the wav. at a faster tempo than I had set it to. Only a little faster, but fast enough for my voice to slightly resemble a chipmonk. (Which is all well and good, but not the effect I was going for on that particular song.)
Any help would be most appreciated. Many thanks, Louise.
  • 2 more comments
  • Kate MC Feb 09, 2009
    I'm having the same problem Louise, I've ensured that the files are exported and with the correct name and bit rate but when I disonnect the files don't show up in the loop station - can't figure out why either
  • CurtisGeren Mar 03, 2009
    I am having the exact same problem. The manual has to be leaving something out. I've gone through the process a hundred times.
  • anders bjork Mar 23, 2009
    I've had the same problem, maybe it's me but i can't even get mine to play at all. I can't even see that it's there. Shouldn't there be some indicater telling me that the download of my own wave-file are successful.
  • Anonymous Mar 31, 2009
    i have the RC-2, and it wont even work. when i plug the input it, it will turn on and off really quickly.
    if anyone can help, email markmemsic@gmail.com
    (i probably will not check this site any time soon)
    thanks.
    p.s. i know its not the SAME problem, but i've been searching for hours for anyone to help me.
Hi I just got a RC 50 and I face the same problem but looking the content of the data in the Roland folder (after you connect the USB) , I notice the format of the label of each sound's and I understood the problem. So , here it is . Before you connect to USB , you have to choose a patch , let say n.16 OK, now the audio file that you want to import into the data folder must be named in this way "016_1.WAV" ,the 16 refer to the patch number and 1 is the phrase number (if you want to put the audio file into the phrase 1 ,or 2 if 2 ecc.) now disconnect the USB .At this point you just have to increase or decrease the patch number just one time and go back to 16 (it has to refresh the patch info) and you'll find your audio file ready to use in whatever phrase you put it.
have fun
Paolo
Posted on Jun 15, 2009
I had the same problem as you. I finally figured out that even though I was saving the wave as 16 bit I need to record it at 16 bit and not dither it form 24 to 16. I set my DP6 at 44.01 KHz, 16 integer, 30 FPS ND. Also if you are saving to patch 6 set it on patch 1 before connecting the USB, When you are done loading the file close all windows drag the Roland icon to the Trash/eject then press exit on the rc 50 and then write. This has worked for me, I hope it helps you.
Good luck,
Mathew
Posted on Jun 26, 2009
I was having the same exact problem, but recently i figured out what worked for me. for whatever reason, removing the ".WAV" part of the file name made it appear in the play screen as desired. so for patch 1, phrase 1, name the file "001_1" in the 44.1khz, 16bit, uncompressed format. then move it into the 'wave' folder as before, end the usb connection, and it should appear on the rc50.
Posted on Sep 22, 2010
    New Friend:
Is this thread still active?
Upon exporting WAV. files from your chosen DAW, what levels are your audio regions hitting? How are you guys monitoring the volume difference between the WAV. files you pre load into a patch and the instrument you use to live loop on top?
Posted on Feb 03, 2015
    New Friend:
Don't write .wav
Posted on Mar 20, 2013
Have you tried disconnecting USB on the RC50 (in the parameter section, "DISCONNECT" then NO:EXIT YES:WRITE, if I remember rightly. You may find that ejecting on the Mac prevents the RCA50 from completing the data writing correctly.
www.myspace.com/celticjazz
Posted on Apr 12, 2009
Tip
RC looper and DR880 syncing.
RC-50 & DR-880 Setup
Rather than using the RC-50 to change patches on the DR-880, I have connected an FS-6 footswitch to both the RC-50 & DR-880. This gives me control of both units, I can select up & down through the patches easily.
Use a dual TRS connector and 2 stereo "y" cables connected to ports 1,2 & 3.4 on both units.
Once connected, you will need to assign the control function for each control port. I assigned Patch Decrease to CLT 1,2 & Patch Increase to CLT 3,4 on both units.
I then connected a MIDI cable from the RC--u control of start/stop & tempo via the RC-50 footswitches.
on Feb 25, 2015 | Roland Boss RC50 Loop station (with )
Rc-50 recording silent wav files
Perhaps your computer's sound card is unable to play back at the bit rate and kHz you are recording at on your (mobile?) recorder. I'm not familiar with the RC-50 but if you are recording at 24 bit for example and your computer's sound card is only able to play back at 16 bit it may not reprosuce any sound. Usually you will get an error saying so. Have you tried different playback software?
Mar 22, 2014 | Boss Rc 50
My RC-50 suddenly won't power on.
Has the unit ever had another ac adapter plugged into it?
Mar 04, 2013 | Boss Rc 50
Hello - I have a Boss RC-2 Loop Station. While I enjoy the pedal's capabilities, it almost always creates an unwanted hum and sometimes an electronic pulse in every amp I use it with. (I typically keep...
Make sure the power supply for this is powered from the SAME receptacle as your amplifier is powered. Keep the cable from this to the amp fairly short and high quality cable. Keep guitar away from magnetic field sources... the wall wart adapters are notorious for generating magnetic fields.
Jul 20, 2011 | Roland Boss RC-2 Loop Station Stompbox...
Why are my exported wav audio recordings so quiet (almost muted) when i replay it on my computer? It is this way when i record in both stereo and mono. When i export it and then play it on my pc through...
Make sure that the file format is the same, first. If so, try converting the format from wav. to a more recent format type, such as mp3, or mp4 if possible. This may help, as the computer may recognize it better depending on the program you are playing them with.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert, Phone Support @ Fixya.com
Apr 29, 2011 | Boss Rc 50
I was trying to transfer data from the RC-50 to my computer and pulled out the USB cable by mistake from the computer and now the RC-50 says Data Damaged. I think I may have put the file in the trash in...
Usually in any type of situation when data is being transferred and the connection is prematurely lost there is data lost and or file corruption.
My suggestion:
Connect the Boss Rc 50 to your computer and backup its entire contents to your computer if possible.
Next perform a Hard Reset: While simultaneously holding down the "PLAY MODE" and "LOOP SYNC" buttons, turn the power on. Everything should be restored to factory settings.
If your backup was successful, then you can transfer desired files (one at time) to determine if the are usable. If a file causes errors or malfunction, then most likely it is corrupt.
Hope this helps
Apr 05, 2011 | Boss Rc 50
How To Turn Drum Beat Off
From what I remember from my recent tinkering you press the guide select button. Then either use the patch/value know and parameter buttons, OR it may be the guide level knob to switch the volume down until it is off. I believe I then saved the patch to preserve the setting and keep that irritating guide at bay! It really should be more intuitive, ideally knod turned to zero = OFF. But no. Ah well, hope you get it sorted. I have a problem too, maybe you have same one? It may be the unit itself. Search - Beggining of loop missing on FIRST playback - if you get a chance. Let me know if yours does it too?
Mar 06, 2009 | Boss Rc 50
Boss Rc 50 Logo
4,345 people viewed this question
Top Boss Music Experts
Michial Gueffroy
Vito Vacirca Jr.
shaun taylor
Are you a Boss Music Expert? Answer questions, earn points and help others
