Question about Acer Aspire 5520-5908 Notebook
Turning on wireless acer aspire 5520 - Acer Aspire 5520-5908 Notebook
Have you pressed Fn and F3 simultaneously?
Posted on Jan 03, 2013
  • 4 Answers
SOURCE: acer aspire 5520 ethernet driver
Go to acer.com downloads, all drivers for the 5520 are there.
Posted on Apr 10, 2009
SOURCE: Keyboard broken on my Acer Aspire 5520
For the Acer Aspire 5520 I'm working on, (Acer Aspire 5520-5156, mode nol: ICW50)
Remove the three black screws under the battery, not the silver screws.
VERY carefuly pry off the power button cover. It will make 'snapping' sounds and if you where gentle nothing will be broken.
The keyboard has no screws holding it and can be slid toward the screen and very gently pryed out, taking care not to tear the ribbon cable, as mentioned before.
When the keyboard is out the cable can be released by gently pulling the cable lock on the header toward the cable, the thin (black in this case, it's usualy a different color than the white connector) plastic part of the connector I just use my fingernails, one index finger on each end slowly pulling till it releases.
Pull the cable out using the pull tab. You can just pull the flat cable out with the pull tab without releasing the calbe lock but you stil need to release the cable lock to properly put in the new cable, then push the cable lock back tight to the connector.
Posted on Aug 14, 2009
LaptopExpert
  • 458 Answers
SOURCE: my acer aspire 5520-5334 won't start
Pull The Battery... Unplug The AC Adapter....
Press and Hold The Power On Button For 30 Seconds...
Reinsert The Battery, Plug In Ac Adapter... Attempt to Power On..
Also Try Removing The Battery And Powering Up Using The Power Cord Alone.....
If Still No Power.... Remove and Reseat The Memory Modules...
Still No?
You'll Next Need To Check To See If The DC Jack Is Faulty...
If It's Faulty, You'll Need To Desolder It, Clean The Board, Resolder a New One ON....
Check The Heatsink/Fan Assembly...it might be clogged...
Still No?
Possibly Faulty Video / GPU Chip....Or a Shorted Out Motherboard..
Posted on Dec 01, 2009
  • 341 Answers
SOURCE: My Acer Aspire 5520 blinks the power light when I
It looks like your battery is either discharged or has a short circuit.
Plug the power AC cord in the laptop and let recharge the battery at least 3 hours before you try to start it again. If the computer boots up, enter the BIOS and check to see if you have a "battery check" oprion. If you do, start it and let it run until it is done (it may take several hours to complete). It will check the battery charge cycle.
Posted on Mar 22, 2010
  • 10406 Answers
SOURCE: ethernet-controller drivers for Acer Aspire 5520-5908 XP
Find a USB memory-stick, and find a computer with Internet access and an available USB port.
Put the memory-stick into the USB slot.
Browse to ACER's web-site, and select your specific model of the Aspire line, and select Windows XP, and select network-controllers, and download the device-drivers, and copy them onto the memory-stick,.
Walk the memory-stick to your Acer, and install the device-driver.
Posted on May 07, 2010
How do i enable the internet connection on my acer 5520
Look on both sides and in front of the laptop for the Wireless Switch to turn on.
May 08, 2012 | Acer Aspire 5520-5908 Notebook
I have a acer aspire windws vista i cannot to the internet automatically but know i cannot connect more get the wirelss to turn on can you please help me
the special key to turn the wireless on is Fn + F3. use this special key to turn the wireless on. if in case the wireless switch pops up on your screen but cannot turn it on, the problem is with the driver. you need to reinstall the wireless driver of your computer.
Aug 04, 2011 | Acer Aspire 5520-5908 Notebook
Windows tells me that wireless has been turned off. How do I turn it back on?
usually a hardware switch is your culprit. On the Acer Aspire 5520 the "easy launch buttons" include an enable/disable for the wireless LAN. It is up above the keyboard and unless it has been reprogrammed press the 2nd key from the left on the application buttons (looks like a satellite)b137ae8.png
Aug 28, 2010 | Acer Aspire 5520-5908 Notebook
My acer 5520 will not allow me to access the internet via wifi?
1)Turn ON the wireless feature on your laptop. It will be a combination of function keys.
2)Remove preferred networks
3)Assign DNS server address manually in Wireless Network Connections Properties
4)Try to scan for wireless networks in range now with/without security
5)Try Internet explorer, else mozilla firefox, else google chrome.
It will surely go online wireless
Jan 17, 2010 | Acer Aspire 5520-5908 Notebook
Reinstalled vista home basic on acer aspire 5520 wireless
Do you have a disk or the wireless router? If this hasn't been re-installed then the notebook will have no way of connecting to the net.
Oct 06, 2009 | Acer Aspire 5520-5908 Notebook
Acer aspire 5520 one black screen cursor
TAKE OUT BATTERY, REMOVE MAINS SUPPLY, HOLD POWER BUTTON DOWN FOR 30 SECS PUT POWER SUPPLY IN ONLY DO NOT PUT IN BATTERY TURN ON LAPTOP NOW PUT IN BATTERY
Jun 06, 2009 | Acer Aspire 5520-5908 Notebook
I lost me wireless conection.
there should be...try Fn+F1 to get a list of the other function keys and what they do
Apr 23, 2009 | Acer Aspire 5520-5908 Notebook
Acer 5520 wont connect wirless
Try unistalling the wireless driver and then download the right driver for your wireless card from http://support.acer-euro.com/drivers/notebook/as_5520.html
it might work!!
Feb 05, 2009 | Acer Aspire 5520-5908 Notebook
Acer Aspire 5520-5908 Notebook Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
